Sorry if these are newbie questions, but can anyone give me good descriptions of these? The bin splitting is obviously related to the samples per second, the sampling time, and the frequency resolution. It seems related to the number of samples that you fit into the sampling period, but the concept is not totally clear to me. Thanks for any advice.
BIN SPLITTING and MIXED RADIX FFT?
Started by ●September 27, 2007
Reply by ●September 28, 20072007-09-28
On Sep 27, 4:24 pm, Necronomicon <radio...@aol.com> wrote:> Sorry if these are newbie questions, but can anyone give me > good descriptions of these? > > The bin splitting is obviously related to the samples per > second, the sampling time, and the frequency resolution. It > seems related to the number of samples that you fit into > the sampling period, but the concept is not totally clear to me.The term "resolution" may mean different things to different people in different contexts. Under some assumptions, one can get arbitrarily accurate resolution with only 3 samples. Other assumptions may require a lot more samples for a lot less resolution. If you take the DFT of some sufficiently bandlimited signal, any sinusoids which are exact integer multiples of Fs / N are orthogonal and will appear in exactly one complex DFT bin. Sinusoids of *any* other frequencies will appear in potentially *all* of the DFT bins, not just the closest bin (which appears to be some sort of common misconception), and in the shape of the transform of the window (a Sinc function for a rectangular window). Even if a good windowing function is used, a large portion of a sinusoid may appear in 3 or 4 bins; so even is this case, calling it a split between just 2 bins seems to be a bit of a misnomer. If, at the same sampling rate Fs, the number of samples N used in your DFT increases, there will be more potential exact frequencies which will be orthogonal to all other DFT bins, and the central lobe of the Sinc function will get skinnier, making it a bit easier to tell certain pairs of frequencies apart. If you expect certain frequency sinusoids and their harmonics to appear, and are sampling at some fixed rate, it may be possible to choose N (other than a power of 2) such that your frequencies of interest directly hit the orthogonal bins instead of getting spread out among all of them. IMHO. YMMV. -- rhn A.T nicholson d.0.t C-o-m
Ron N. wrote:> On Sep 27, 4:24 pm, Necronomicon <radio...@aol.com> wrote: > > Sorry if these are newbie questions, but can anyone give me > > good descriptions of these? > > > > The bin splitting is obviously related to the samples per > > second, the sampling time, and the frequency resolution. It > > seems related to the number of samples that you fit into > > the sampling period, but the concept is not totally clear to me. > > The term "resolution" may mean different things to different > people in different contexts. Under some assumptions, one > can get arbitrarily accurate resolution with only 3 samples. > Other assumptions may require a lot more samples for a lot > less resolution. > > If you take the DFT of some sufficiently bandlimited signal, > any sinusoids which are exact integer multiples of Fs / N are > orthogonal and will appear in exactly one complex DFT bin. > Sinusoids of *any* other frequencies will appear in potentially > *all* of the DFT bins, not just the closest bin (which appears > to be some sort of common misconception), and in the shape of > the transform of the window (a Sinc function for a rectangular > window). Even if a good windowing function is used, a large > portion of a sinusoid may appear in 3 or 4 bins; so even is > this case, calling it a split between just 2 bins seems to > be a bit of a misnomer. >Understood. Even a Hanning window with a long sampling period would have sidebands.> If, at the same sampling rate Fs, the number of samples N > used in your DFT increases, there will be more potential exact > frequencies which will be orthogonal to all other DFT bins, and > the central lobe of the Sinc function will get skinnier, making > it a bit easier to tell certain pairs of frequencies apart. > > If you expect certain frequency sinusoids and their harmonics > to appear, and are sampling at some fixed rate, it may be > possible to choose N (other than a power of 2) such that your > frequencies of interest directly hit the orthogonal bins > instead of getting spread out among all of them. >After reading this: http://en.wikipedia.org/wiki/Window_function .....it's all clearer. Although they seem to call the increase in the noise floor as "scalloping loss". So it seems the idea is to choose a bin frequency resolution that will be a sub-integer multiple of the main frequency of interest, like: Fo= 100Hz, then pick freq. resolution = 0.5 Hz. The problem situation might be, if you were sampling a signal that had two or more non-harmonically related frequencies, right? Can you give your angle on the "Mixed Radix"? Thanks.....
Necronomicon wrote: ...> Can you give your angle on the "Mixed Radix"?Mixed radius is an implementation detail that affects the efficiency, not the result, of computation. Jerry -- Engineering is the art of making what you want from things you can get. ¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯¯
Reply by ●September 29, 20072007-09-29
On Sep 28, 5:42 pm, Necronomicon <radio...@aol.com> wrote:> So it seems the idea is to choose a bin frequency resolution > that will be a sub-integer multiple of the main frequency of interest, > like: Fo= 100Hz, then pick freq. resolution = 0.5 Hz. > > The problem situation might be, if you were sampling a signal > that had > two or more non-harmonically related frequencies, right?If they are rationally related to each other and to the sampling frequency, then one solution to the problem is left as an exercise for the student.> Can you give your angle on the "Mixed Radix"?A term sometimes used to describe an FFT of a length such that all its factors are not just 2 (possibly also implying having at least two different factors as well). Gives a lot more flexibility in choosing the length of your FFT. IMHO. YMMV.
Reply by ●October 16, 20072007-10-16
Ron N. wrote: The mixed radix algorithm is simply an algorithm for computing a DFT using two smaller DFTs. For example an N point DFT from an M point and K point DFT where M*K=N. Basically, the N input samples are entered into an M row by K column matrix, filling in row-major order. Then M-point transforms are computed down each of the K columns. The results are phase rotated by a angle that depends on the position in the matrix, and the results are put back into the matrix in natural order going down the columns. A second pass then computes the K point transform along each row, again returning the result into the matrix along the row in natural order. Finally, the result is read out of the matrix reading down the columns (column major order) to obtain the FFT result in natural order. If M and K are relative primes, the phase rotation is not necessary, which simplifies the computation (although the underlying DFTs are not as efficient as power of 2 FFTs since at least one does not have a power of two length).
