simple average filters...
Started by Rajoshi September 28, 2007
Consider i have a simple average filter(FIR) of length N. Can I find its
cut-off frequency(rad/sample), if at all this much data is sufficient to
find it, without using any equations?
Regards,
Rakesh.
On Sep 28, 11:19 am, "Rajoshi" <bld....@gmail.com> wrote:
> Consider i have a simple average filter(FIR) of length N. Can I find its > cut-off frequency(rad/sample), if at all this much data is sufficient to > find it, without using any equations? > Regards, > Rakesh.
Does asking someone who does use equations count?
Yes, you can connect the FIR with an A/D and a D/A, and use a network analyzer to measure the frequency response between A/D and D/A.
You would have to define what you mean br "cutoff frequency". The response is a sinc which becomes narrower as N increases. Jerry -- Engineering is the art of making what you want from things you can get. &macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;
Yes.
> Regards, > Rakesh.
Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
> > >Rajoshi wrote: > >> Consider i have a simple average filter(FIR) of length N. Can I find
its
to
>> find it, without using any equations? > >Yes. > >> Regards, >> Rakesh. > >Vladimir Vassilevsky >DSP and Mixed Signal Design Consultant >http://www.abvolt.com > >
True, the response would be a sync and would get narrower as the filter length starts growing. My query was can we intutively guess the cutoff(3db low) freq of the filter? We can get hold of the frequencies which are not passed thr the filter by merely comparing the window length to the period of a sine wave.Does that help in finding the cut off freq? Regards, Rakesh
Rajoshi wrote:
> ... My query was can we intutively guess the cutoff(3db > low) freq of the filter? ...
There is a simple relation between the 3-dBpointand N, normalized to the sample rate, but you need an equation to find it. Intuition won't do. Jerry -- Engineering is the art of making what you want from things you can get. &macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;&macr;
Or could it be a simple scaling factor?
If I change the length of the FIR, the curve just stretches on the sample
axis => the ratio between zero crossings and 3 dB cutoff frequency remains
the same.
I'd say it's around 0.4:
http://www.elisanet.fi/mnentwig/sinc.png
A related question:
Is there an analytical solution to sin(x)=a x , or at least a built-in
function to Matlab etc like for example Bessel functions?
-mn
Rajoshi wrote:
> Consider i have a simple average filter(FIR) of length N. Can I find its > cut-off frequency(rad/sample), if at all this much data is sufficient to > find it, without using any equations? > Regards, > Rakesh. > >
An approximation for the -3dB point is ~ pi*0.88/N
If it's a software routine, you could run a large number of test vectors of various frequencies through the routine, plot the results, and find a spot on the plot that looks like a reasonable cut-off frequency. But even creating test vectors or a plot of the results requires the use of some equations, unless you can find turn-key packages which just happen to have the correct default or auto-adaptive settings. IMHO. YMMV. -- rhn A.T nicholson d.0.t C-o-M
