Hi, Processor : DM642 Tool : CCS3.1 While doing software reset from the CCS3.1, Previously it was working properly and suddenly i am getting error message as Failed Software Reset: Error 0x00000024/-1147 Error during: Register, Execution, It appears that the target is being held in reset. If this is a multi-core system, the master CPU may not be releasing the DSP from reset. Please check your configuration in CCSetup and/or your GEL file to ensure that nothing is blocking the DSP from being released from reset Sequence ID: 16 Error Code: -1147 Error Class: 0x00000024 and the CCS 3.1 hangs. Anyone has face this kind of problem, or what can be the cause of this error and is there any solution for that?
Getting Error message while doing software reset.
Started by ●October 9, 2007
Reply by ●October 10, 20072007-10-10
harshiddh wrote:> Hi, > > Processor : DM642 > Tool : CCS3.1 > > While doing software reset from the CCS3.1, Previously it was working > properly and suddenly i am getting error message as > > Failed Software Reset: Error 0x00000024/-1147 Error during: Register, > Execution, It appears that the target is being held in reset. If this is > a multi-core system, the master CPU may not be releasing the DSP from > reset. Please check your configuration in CCSetup and/or your GEL file to > ensure that nothing is blocking the DSP from being released from reset > Sequence ID: 16 Error Code: -1147 Error Class: 0x00000024 > > and the CCS 3.1 hangs. Anyone has face this kind of problem, or what can > be the cause of this error and is there any solution for that? > > >Have you probed the reset line? Perhaps something actually IS holding the device in reset.
