The answer to this one may be obvious, I dont know, but I still couldnt figure it out, so I had to post. To remove an interfering frequency from a noisy signal, why don't we simply take the FFT and set the interfering frequency value to zero (in the amplitude spectrum), and then take IFFT again? Something similar seems to be done in JPEG (DCT) compression, where the higher frequencies are simply set to zero before the compression. I see a few negatives with this: 1> To implement a running filter, you need to keep taking the FFT and IFFT repeatedly, which may be an unacceptable computation overhead. 2> A finite-length sine wave actually does not produce a single sample in the FFT, but also spills over to adjacent frequencies due to finite length effects. Can someone please clarify on this? thanks in advance,
Why not set unnecessary frequency components to zero in freq domain?
Started by ●October 11, 2007
Reply by ●October 12, 20072007-10-12
"adolf123" <karthickng@ieee.org> writes:> The answer to this one may be obvious, I dont know, but I still couldnt > figure it out, so I had to post. > > To remove an interfering frequency from a noisy signal, why don't we > simply take the FFT and set the interfering frequency value to zero (in > the amplitude spectrum), and then take IFFT again? Something similar seems > to be done in JPEG (DCT) compression, where the higher frequencies are > simply set to zero before the compression. > > I see a few negatives with this: > > 1> To implement a running filter, you need to keep taking the FFT and IFFT > repeatedly, which may be an unacceptable computation overhead.Yes, you've got part of the idea. To use the FFT for linear filtering, you have to take steps to ensure there is no aliasing due to the inherently circular convolution you get with the FFT. Generally, that means you have to ensure a certain number of zero samples in either the impulse response, the input signal, or both. Simply setting a bin to zero is (I think) going to result in a very wide equivalent impulse response, which means it will alias. And if you want to filter indefinitely-lengthed signals using the FFT, you have to split the input into blocks and use a technique like overlap/add or overlap/save.> 2> A finite-length sine wave actually does not produce a single sample in > the FFT, but also spills over to adjacent frequencies due to finite length > effects.I know what you mean, but I wouldn't use the terminology you use. For example, it's not the "finited-ness" of the sine wave that causes the "spilling" but rather the relationship of its frequency to the sample rate and FFT length. In just the right situation, the FFT will yield a perfect "spike" for a finite-lengthed sine wave. To step back a little, notch-filtering an interferer is a filtering operation. If you use an FIR filter, then it can be implemented in the time domain (using a standard convolution sum) or in the frequency domain using FFTs and, e.g., overlap/add. -- % Randy Yates % "Bird, on the wing, %% Fuquay-Varina, NC % goes floating by %%% 919-577-9882 % but there's a teardrop in his eye..." %%%% <yates@ieee.org> % 'One Summer Dream', *Face The Music*, ELO http://www.digitalsignallabs.com
Randy Yates <yates@ieee.org> writes:> [...]PS: Proakis and Manolakis have a very thorough section on the circular convolution property of the DFT and the overlap add/save methods. @BOOK{proakis, title = "{Digital Signal Processing: Principles, Algorithms, and Applications}", author = "John~G.~Proakis and Dimitris~G.~Manolakis", publisher = "Prentice Hall", edition = "third", year = "1996"} PSS: I think there is a more recent edition. -- % Randy Yates % "Rollin' and riding and slippin' and %% Fuquay-Varina, NC % sliding, it's magic." %%% 919-577-9882 % %%%% <yates@ieee.org> % 'Living' Thing', *A New World Record*, ELO http://www.digitalsignallabs.com
On Oct 11, 7:47 pm, "adolf123" <karthic...@ieee.org> wrote:> The answer to this one may be obvious, I dont know, but I still couldnt > figure it out, so I had to post. > > To remove an interfering frequency from a noisy signal, why don't we > simply take the FFT and set the interfering frequency value to zero (in > the amplitude spectrum), and then take IFFT again? Something similar seems > to be done in JPEG (DCT) compression, where the higher frequencies are > simply set to zero before the compression.But note that JPEG (quantized DCT) compression can leave quite visible artifacts in some cases (mosquito noise).> I see a few negatives with this:...> 2> A finite-length sine wave actually does not produce a single sample in > the FFT, but also spills over to adjacent frequencies due to finite length > effects.That is exactly the problem. A finite-length FFT will chop the sine wave into a finite length by sort-of an inherent rectangular window. A rectangular window of a non-exactly periodic (in that window) sinusoid will appear as a sampled Sinc in the FFT result, e.g. portions of the energy will spill into side lobes. If you zero a bin which contains these side lobes, you end up distorting portions of those other non-bin frequencies in addition to the one you are trying to null. e.g. you get distortion. And if the frequency you want to remove isn't exactly periodic in the FFT aperture, then the problem doubles. You end up only remove a portion of the interfering frequencies sampled Sinc spillage by zeroing one bin. So you both distort other frequencies and only partially remove the interfering frequency. When you try to plot the continuous frequency response of zeroing one bin, these effects will cause the response curve to look quite un-flat and very ringy near the bin of interest. A wider, less abrupt, filter will usually cause much less of this type of distortion, contrary to what some DSP novices might first assume. IMHO. YMMV. -- rhn A.T nicholson d.0.t C-o-M
Randy Yates wrote:> "adolf123" <karthickng@ieee.org> writes:(snip)>>2> A finite-length sine wave actually does not produce a single sample in >>the FFT, but also spills over to adjacent frequencies due to finite length >>effects.> I know what you mean, but I wouldn't use the terminology you use. For > example, it's not the "finited-ness" of the sine wave that causes the > "spilling" but rather the relationship of its frequency to the sample > rate and FFT length.A finite length sine as a time domain signal (zero outside the specified time) has a width in frequency space inversely proportional to the length of the sine. More usual are sines multiplied by Gaussians, wave packets, which have a Gaussian width in frequency space.> In just the right situation, the FFT will yield a > perfect "spike" for a finite-lengthed sine wave.The FFT of a finite length signal that is not zero padded gives the result for a periodic infinitely long signal. For sines with the right period, yes, a delta in frequency space.> To step back a little, notch-filtering an interferer is a filtering > operation. If you use an FIR filter, then it can be implemented in > the time domain (using a standard convolution sum) or in the frequency > domain using FFTs and, e.g., overlap/add.Sounds good to me. -- glen
On 12 Okt, 04:47, "adolf123" <karthic...@ieee.org> wrote:> The answer to this one may be obvious, I dont know, but I still couldnt > figure it out, so I had to post. > > To remove an interfering frequency from a noisy signal, why don't we > simply take the FFT and set the interfering frequency value to zero (in > the amplitude spectrum), and then take IFFT again? Something similar seems > to be done in JPEG (DCT) compression, where the higher frequencies are > simply set to zero before the compression.There is one fundamental difference between image processing and analysis of time-series data: In image procesing you have all the data available when you do the processing. One image is all there is, and that's what you have to deal with. In most applications in time series analysis the available data is only a random sample of a stochastic process, which means that one can always aqcuire more data by leaving the recorder running for a bit longer. Of course, one has to stop the recording at one point, which in turn means one always deals with an incomplete data set. Since DSP deals with discrete-time data where one in many applications really is interested in continuous-time data, one ends up with two problems: - One has a finite sample of an infinitely long process - One has discrete-time data and discrete spectra where one really is interested in continuous-time data and contionuous spectra. Since the setting is far more complex in the case of time series analysis, one have to be a lot more careful than one needs to be with image processing.> I see a few negatives with this: > > 1> To implement a running filter, you need to keep taking the FFT and IFFT > repeatedly, which may be an unacceptable computation overhead.No, you don't have to. There are other ways of doing things.> 2> A finite-length sine wave actually does not produce a single sample in > the FFT, but also spills over to adjacent frequencies due to finite length > effects.That's part of the explanation; you just don't know exactly what to remove. In view of what I explained above, that most time series data sets are random samples of stochastic processes, the exact ferquency component available to you depend on the length of the discrete-time data sequence. Remember, with a sequence of length N the Fourier coefficients are located at w_n = 2*pi/(N*T) where T is the sampling period. Change the length of the data sequence from N to N+1 and the Fourier component change with it. There is also a famous theorem (Wiener-Kinchine?) which states that if a spectrum is zero over some non/vanishing bandwidth the time-domain signal will be infinitely long. Which causes all sorts of problems with ringing and wrap-around, if one tries to emulate it in discrete spectra. Rune
I use it all the time in the lab on cyclic signals. But there are a couple of pitfalls in the general case, one of them is ringing in the time domain. Here is an example on an audio file, for experiments. Treating the whole audio file as a cyclic signal means that one has to push the "repeat" button on the CD player after processing, otherwise the spectrum will spill :) http://www.elisanet.fi/mnentwig/webroot/FFT_filter_example/index.html Cheers Markus
adolf123 wrote:> To remove an interfering frequency from a noisy signal, why don't we > simply take the FFT and set the interfering frequency value to zero (in > the amplitude spectrum), and then take IFFT again?(Disclaimer : I know little about noise removal) If you're trying to get rid of noise, there's a way to do (pretty much) this. Just characterise your noise in the frequency domain (get a sample of pure noise, FFT it, take the magnitude of it, smooth it if necessary) then substract the FFT of your signal you want to de-noise with that, and IFFT. I believe it will yield better results than if you arbitrarily set bins to zero in the frequency domain.> Something similar seems > to be done in JPEG (DCT) compression, where the higher frequencies are > simply set to zero before the compression.Yes, but I believe it's done in order to get rid of the least significant frequency-domain information, in order to make the amount of information to save less important.
"adolf123" <karthickng@ieee.org> wrote in message news:4rWdnQyuJODBfZPanZ2dnUVZ_jqdnZ2d@giganews.com...> The answer to this one may be obvious, I dont know, but I still couldnt > figure it out, so I had to post. > > To remove an interfering frequency from a noisy signal, why don't we > simply take the FFT and set the interfering frequency value to zero (in > the amplitude spectrum), and then take IFFT again? Something similar seems > to be done in JPEG (DCT) compression, where the higher frequencies are > simply set to zero before the compression. > > I see a few negatives with this: > > 1> To implement a running filter, you need to keep taking the FFT and IFFT > repeatedly, which may be an unacceptable computation overhead.***Actually this can be faster than time domain convolution.> > 2> A finite-length sine wave actually does not produce a single sample in > the FFT, but also spills over to adjacent frequencies due to finite length > effects.Correct. Another way to look at the operation you suggest is that it identically subtracts a sinusoid of an integral number of cycles in the time domain - without spectral leakage. So, whether that's what you want, that's what you get! Note that you would have to subtract from both the positive and negative frequency values; i.e. a term between 0 and fs/2 and another term between fs and fs/2 by the same distance. Otherwise it doesn't have the desired affect - if then. Fred
