Rip Van Winkle asks "What's with FPGAs" ?
Started by Richard Owlett ●May 3, 2004
Ronald H. Nicholson Jr. wrote:
> In article <109g7scoo3deue4@corp.supernews.com>, > Tim Wescott <tim@wescottnospamdesign.com> wrote: > >>Richard Owlett wrote: >> >>>Following a similar philosophy I would want; >>>1. an USB port for connection to host system for programming FPGA >> >>They don't get programmed that way. You can buy a programming cable >>(basically parallel to JTAG converter) for $99 from Xilinx; Altera would >>be similar. > > > Useless because most typical PC's these days do not include parallel > (or even serial) ports, student laptops in particular. > > I suppose a USB to parallel converted might work. Anyone make a > direct USB to JTAG port for FPGA programming? > > How about FPGA development tools which run under Mac OS X or linux? > > > IMHO. YMMV.
The whole programming dongle industry seems to be a little late going to USB, but it'll happen. Xilinx tools are supposed to work under Linux, but they only offer support for the paid versions. You're on your own with the free. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
I have yet to see a new PC without both a parallel as well as serial port. Perhaps the Dells and Gateways are shipping without these ports these days? I buy Asus motherboards and top notch peripherals from a local computer shop. -- ____________________________________ Christopher R. Carlen Principal Laser/Optical Technologist Sandia National Laboratories CA USA crcarle@sandia.gov
"Chris Carlen" <crcarle@BOGUS.sandia.gov> wrote in message
news:c7bp3q01dj7@news2.newsguy.com...
> Ronald H. Nicholson Jr. wrote: > > In article <109g7scoo3deue4@corp.supernews.com>, > > Tim Wescott <tim@wescottnospamdesign.com> wrote: > > > >>Richard Owlett wrote: > >> > >>>Following a similar philosophy I would want; > >>>1. an USB port for connection to host system for programming FPGA > >> > >>They don't get programmed that way. You can buy a programming cable > >>(basically parallel to JTAG converter) for $99 from Xilinx; Altera would > >>be similar. > > > > > > Useless because most typical PC's these days do not include parallel > > (or even serial) ports, student laptops in particular. > > > > I suppose a USB to parallel converted might work. Anyone make a > > direct USB to JTAG port for FPGA programming? > > > > How about FPGA development tools which run under Mac OS X or linux? > > > > I have yet to see a new PC without both a parallel as well as serial port. > > Perhaps the Dells and Gateways are shipping without these ports these days? > > I buy Asus motherboards and top notch peripherals from a local computer > shop.
Desktops usually have them, it's the laptops that don't. It's quite a problem for us as our older hardware (which we still sell) requires a serial port to communicate with it. There are Ethernet to serial converters and USB to serial converters that we recommend to our customers who have newer laptops with serial ports. Neither of those solutions are ideal, though since they generally increase latency and decrease effective throughput. There are also RS-232 serial port PC cards (aka PCMCIA). Those tend to work a bit better since they skip the extra translation step. Off topic, in our industry, the trend is to leapfrog USB and go to 100Mbit Ethernet. Not only do you get increased speed, but increased distance and networkability.
"Jon Harris" <goldentully@hotmail.com> wrote in message
news:c7btq5$254a2$1@ID-210375.news.uni-berlin.de...
> Desktops usually have [serial ports], it's the laptops that don't.
That's too bad -- I'm going to miss UARTs. The protocol is so simple that you can do stuff without dedicating a CPU or FPGA to it. Is anyone using the same protocol with faster signaling methods like optical or LVDS?
> Off topic, in our industry, the trend is to leapfrog USB and go to 100Mbit > Ethernet. Not only do you get increased speed, but increased distance and > networkability.
Are there any single-chip Ethernet implementations with dead-simple interfaces?
Matt Timmermans wrote:
> "Jon Harris" <goldentully@hotmail.com> wrote in message > news:c7btq5$254a2$1@ID-210375.news.uni-berlin.de... > >>Desktops usually have [serial ports], it's the laptops that don't. > > > That's too bad -- I'm going to miss UARTs. The protocol is so simple that > you can do stuff without dedicating a CPU or FPGA to it. Is anyone using > the same protocol with faster signaling methods like optical or LVDS?
No, the whole idea of the "Universal Serial Bus" was to replace that pesky RS-232 thing.
>>Off topic, in our industry, the trend is to leapfrog USB and go to 100Mbit >>Ethernet. Not only do you get increased speed, but increased distance and >>networkability. > > > Are there any single-chip Ethernet implementations with dead-simple > interfaces? > >
rhn@mauve.rahul.net (Ronald H. Nicholson Jr.) wrote in message news:<c7bm67$32e$1@blue.rahul.net>...
They don't work. A USB to serial gadget is a perfectly good substitute for a serial port on a PC. Actually, its better than the real thing, as most can run a lot faster than a real port. However, USB to parallel port gadgets are quite different. The use of a parallel port for things like JTAG adaptors relies on direct twiddling with the port bits. That is not possible in most cases, using a USB gadget. Even where it is possible, the latency is so high the speed becomes unusable. Parallel port access for JTAG, and a lot of industrial control, is about to die. Regards, Steve
"Steve Underwood" <steveu@coppice.org> wrote in message
news:80bddbd7.0405052149.f0be04f@posting.google.com...
> > I suppose a USB to parallel converted might work. Anyone make a > > direct USB to JTAG port for FPGA programming? > > They don't work. A USB to serial gadget is a perfectly good substitute > for a serial port on a PC. Actually, its better than the real thing, > as most can run a lot faster than a real port.
In my experience, they are worse. First of all, the serial baud rate is the bottleneck anyway, so there is no increased bandwidth. (I'm speaking of the case where you are trying to connect to a "legacy" product with a real RS-232 port from a PC without one.) Second, the added overhead of the conversion actually slows you down slightly because of increased latency. For applications that use many short communication packets, that can make a difference. But for most applications where serial is used, bandwidth isn't all that important and the USB gadgets work well.
"Tim Wescott" <tim@wescottnospamdesign.com> wrote in message
news:109jcsglr7c81a8@corp.supernews.com...
> Matt Timmermans wrote: > > > "Jon Harris" <goldentully@hotmail.com> wrote in message > > news:c7btq5$254a2$1@ID-210375.news.uni-berlin.de... > > > >>Desktops usually have [serial ports], it's the laptops that don't. > > > > > > That's too bad -- I'm going to miss UARTs. The protocol is so simple that > > you can do stuff without dedicating a CPU or FPGA to it. Is anyone using > > the same protocol with faster signaling methods like optical or LVDS? > > No, the whole idea of the "Universal Serial Bus" was to replace that > pesky RS-232 thing.
For PC-centric applications, USB offers many advantages over RS-232 besides just speed: ability to provide power, simple to set-up (no baud rate/start bits/stop bits/flow control to set up), plug and play support, etc.. There are some chips out there that provide a UART to USB interface so you can fairly painlessly add USB to your product. It looks just like a UART to the FPGA/microcontroller.
"Matt Timmermans" <mt0000@sympatico.nospam-remove.ca> wrote in message
news:Dzgmc.45089$ZJ5.1445121@news20.bellglobal.com...
> > "Jon Harris" <goldentully@hotmail.com> wrote in message > news:c7btq5$254a2$1@ID-210375.news.uni-berlin.de... > > > Off topic, in our industry, the trend is to leapfrog USB and go to 100Mbit > > Ethernet. Not only do you get increased speed, but increased distance and > > networkability. > > Are there any single-chip Ethernet implementations with dead-simple > interfaces?
I've heard of microcontrollers coming with software Ethernet stacks built in, but even then there is significantly more complexity than with serial.
"Jon Harris" <goldentully@hotmail.com> wrote in message news:<2fvdmkF2p0nbU1@uni-berlin.de>...
> "Steve Underwood" <steveu@coppice.org> wrote in message > news:80bddbd7.0405052149.f0be04f@posting.google.com... > > rhn@mauve.rahul.net (Ronald H. Nicholson Jr.) wrote in message > news:<c7bm67$32e$1@blue.rahul.net>... > > > I suppose a USB to parallel converted might work. Anyone make a > > > direct USB to JTAG port for FPGA programming? > > > > They don't work. A USB to serial gadget is a perfectly good substitute > > for a serial port on a PC. Actually, its better than the real thing, > > as most can run a lot faster than a real port. > > In my experience, they are worse. First of all, the serial baud rate is the > bottleneck anyway, so there is no increased bandwidth. (I'm speaking of the case > where you are trying to connect to a "legacy" product with a real RS-232 port > from a PC without one.) Second, the added overhead of the conversion actually > slows you down slightly because of increased latency. For applications that use > many short communication packets, that can make a difference. But for most > applications where serial is used, bandwidth isn't all that important and the > USB gadgets work well.
I've been bitten by the latency issue before, so I should have commented on it. I do find the speed of the USB-serial gadgets very useful though. 921K bps is often fast enough to stream ADC data from a target board to a host for analysis. :-) Regards, Steve
