"Steve Underwood" <steveu@coppice.org> wrote in message news:80bddbd7.0405071946.b9ba69f@posting.google.com...> "Jon Harris" <goldentully@hotmail.com> wrote in messagenews:<2fvdmkF2p0nbU1@uni-berlin.de>...> > "Steve Underwood" <steveu@coppice.org> wrote in message > > news:80bddbd7.0405052149.f0be04f@posting.google.com... > > > rhn@mauve.rahul.net (Ronald H. Nicholson Jr.) wrote in message > > news:<c7bm67$32e$1@blue.rahul.net>... > > > > I suppose a USB to parallel converted might work. Anyone make a > > > > direct USB to JTAG port for FPGA programming? > > > > > > They don't work. A USB to serial gadget is a perfectly good substitute > > > for a serial port on a PC. Actually, its better than the real thing, > > > as most can run a lot faster than a real port. > > > > In my experience, they are worse. First of all, the serial baud rate is the > > bottleneck anyway, so there is no increased bandwidth. (I'm speaking of thecase> > where you are trying to connect to a "legacy" product with a real RS-232port> > from a PC without one.) Second, the added overhead of the conversionactually> > slows you down slightly because of increased latency. For applications thatuse> > many short communication packets, that can make a difference. But for most > > applications where serial is used, bandwidth isn't all that important andthe> > USB gadgets work well. > > I've been bitten by the latency issue before, so I should have > commented on it. I do find the speed of the USB-serial gadgets very > useful though. 921K bps is often fast enough to stream ADC data from a > target board to a host for analysis. :-)Which USB-serial gadget works at 921K bps?
Rip Van Winkle asks "What's with FPGAs" ?
Started by ●May 3, 2004
Reply by ●May 10, 20042004-05-10
TUSB3410 "Jon Harris" <goldentully@hotmail.com> wrote in message news:2ga8g2Fgqm2U1@uni->> Which USB-serial gadget works at 921K bps? > >
"Jon Harris" <goldentully@hotmail.com> wrote in message news:<2ga8g2Fgqm2U1@uni-berlin.de>...> "Steve Underwood" <steveu@coppice.org> wrote in message > news:80bddbd7.0405071946.b9ba69f@posting.google.com... > > "Jon Harris" <goldentully@hotmail.com> wrote in message > news:<2fvdmkF2p0nbU1@uni-berlin.de>... > > > "Steve Underwood" <steveu@coppice.org> wrote in message > > > news:80bddbd7.0405052149.f0be04f@posting.google.com... > > > > rhn@mauve.rahul.net (Ronald H. Nicholson Jr.) wrote in message > news:<c7bm67$32e$1@blue.rahul.net>... > > > > > I suppose a USB to parallel converted might work. Anyone make a> > > > > direct USB to JTAG port for FPGA programming? > > > > > > > > They don't work. A USB to serial gadget is a perfectly good substitute > > > > for a serial port on a PC. Actually, its better than the real thing, > > > > as most can run a lot faster than a real port. > > > > > > In my experience, they are worse. First of all, the serial baud rate is the > > > bottleneck anyway, so there is no increased bandwidth. (I'm speaking of the > case > > > where you are trying to connect to a "legacy" product with a real RS-232 > port > > > from a PC without one.) Second, the added overhead of the conversion > actually > > > slows you down slightly because of increased latency. For applications that > use > > > many short communication packets, that can make a difference. But for most > > > applications where serial is used, bandwidth isn't all that important and > the > > > USB gadgets work well. > > > > I've been bitten by the latency issue before, so I should have > > commented on it. I do find the speed of the USB-serial gadgets very > > useful though. 921K bps is often fast enough to stream ADC data from a > > target board to a host for analysis. :-) > > Which USB-serial gadget works at 921K bps?Every one I have tried, which means several designs based on several chips. The commonest chip I see is the Prolific one. That does it. So does the TI TUSB3410. I think this speed is the usual maximum. Regards, Steve
Reply by ●May 11, 20042004-05-11
Steve Underwood wrote:> "Jon Harris" <goldentully@hotmail.com> wrote in message news:<2ga8g2Fgqm2U1@uni-berlin.de>......>>Which USB-serial gadget works at 921K bps? > > > > Every one I have tried, which means several designs based on several > chips. The commonest chip I see is the Prolific one. That does it. So > does the TI TUSB3410. > I think this speed is the usual maximum.How does a number like 921 (= 37*5*3*2) worm its way into a spec or become a "usual maximum"? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Steve Underwood wrote:> "Jon Harris" <goldentully@hotmail.com> wrote in message news:<2ga8g2Fgqm2U1@uni-berlin.de>......>>Which USB-serial gadget works at 921K bps? > > > > Every one I have tried, which means several designs based on several > chips. The commonest chip I see is the Prolific one. That does it. So > does the TI TUSB3410. > I think this speed is the usual maximum.How does a number like 921 (= 3*307) worm its way into a spec or become a "usual maximum"? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
"Steve Underwood" <steveu@coppice.org> wrote in message news:80bddbd7.0405101806.7e95d064@posting.google.com...> "Jon Harris" <goldentully@hotmail.com> wrote in messagenews:<2ga8g2Fgqm2U1@uni-berlin.de>...> > "Steve Underwood" <steveu@coppice.org> wrote in message > > news:80bddbd7.0405071946.b9ba69f@posting.google.com... > > > "Jon Harris" <goldentully@hotmail.com> wrote in message > > > I've been bitten by the latency issue before, so I should have > > > commented on it. I do find the speed of the USB-serial gadgets very > > > useful though. 921K bps is often fast enough to stream ADC data from a > > > target board to a host for analysis. :-) > > > > Which USB-serial gadget works at 921K bps? > > Every one I have tried, which means several designs based on several > chips. The commonest chip I see is the Prolific one. That does it. So > does the TI TUSB3410. > I think this speed is the usual maximum.Thanks for the pointer Steve. In my case, the target device I'm talking too is limited to 115.2K anyway (it's a physical RS-232 port). To Jerry, the actual speed is 921.6K which is 8x 115.2K, a common PC RS-232 data rate. However, I don't know why PC RS-232 uses the frequencies 1200, 4800, 9600, 19.2K, 38.4K, 57.6K, 115.2K, etc.. Must be based on some crystal reference.
Jon Harris wrote:> "Steve Underwood" <steveu@coppice.org> wrote in message > news:80bddbd7.0405101806.7e95d064@posting.google.com... > >>"Jon Harris" <goldentully@hotmail.com> wrote in message > > news:<2ga8g2Fgqm2U1@uni-berlin.de>... > >>>"Steve Underwood" <steveu@coppice.org> wrote in message >>>news:80bddbd7.0405071946.b9ba69f@posting.google.com... >>> >>>>"Jon Harris" <goldentully@hotmail.com> wrote in message >>>>I've been bitten by the latency issue before, so I should have >>>>commented on it. I do find the speed of the USB-serial gadgets very >>>>useful though. 921K bps is often fast enough to stream ADC data from a >>>>target board to a host for analysis. :-) >>> >>>Which USB-serial gadget works at 921K bps? >> >>Every one I have tried, which means several designs based on several >>chips. The commonest chip I see is the Prolific one. That does it. So >>does the TI TUSB3410. >>I think this speed is the usual maximum. > > > Thanks for the pointer Steve. In my case, the target device I'm talking too is > limited to 115.2K anyway (it's a physical RS-232 port). > > To Jerry, the actual speed is 921.6K which is 8x 115.2K, a common PC RS-232 data > rate. However, I don't know why PC RS-232 uses the frequencies 1200, 4800, > 9600, 19.2K, 38.4K, 57.6K, 115.2K, etc.. Must be based on some crystal > reference.8 x 115.2 explains it! Like good programming, good detective work depends heavily on good factoring. The speeds you cite evolved from Teletypes, Telex, and earlier 5-bit Baudot-code machines. The trusty ASR 35 ran at 110 Baud and 11 bits per character. (Two stop bits reduced timing sensitivity in an era before the grid when even synchronous motors couldn't be counted on to track exactly.) I still have a working TI thermal "KSR" with built-in acoustic coupler that runs at 300 Baud. Timing advances allowed 10 bits to do the work of 11, so it runs at three times the speed of a TTY. From there, most speed improvements went by powers of two, leading to the line speeds you cite. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
