"Greg Berchin" <gberchin@comicast.net> wrote in message news:1k15i3l9ccr1mtsa84i60apo2e32fvlt82@4ax.com...> > FDLS requires phase information in addition to magnitude; not always > easy to come by. You can derive the minimum phase characteristic from > the magnitude, however, and FDLS should work fine with that.Greg, Is the result of FLDS always a stable function? VLV
Any shape IIR Filter
Started by ●October 26, 2007
Reply by ●October 28, 20072007-10-28
On Sun, 28 Oct 2007 07:35:25 -0600, "Vladimir Vassilevsky" <antispam_bogus@hotmail.com> wrote:>Is the result of FLDS always a stable function?In general, the model has the same stability as the prototype. Exceptions occur when a pole pair is very near the unit circle, in which case the least squares nature of the fit can push them "over the edge". It's rare, but it does happen. Also, and this part got cut out of the magazine article, if you use sine waves instead of cosine waves to fill the matrices, you're almost guaranteed to get a pole at or near z=-1 (often outside the unit circle). This happens because sampling a sine wave of frequency Fs/2 only catches the zero-crossings. The interpretation is a "zero-input/nonzero-output" situation, and the mathematics therefore place a pole at half the sampling frequency. The cure for this is to use only cosines in the implementation. (It can be shown that the cosine formulation models only the real part of the frequency response, and that the sine formulation models only the imaginary part. If you use only the cosine formulation, you can gain access to the imaginary part by artificially introducing some delay into the system.) Greg
Reply by ●November 1, 20072007-11-01
Hi Jeff, Here is one way: use a neural net learning algorithm to match the desired response. See page 476 of Chapter 26 in my free on-line DSP book: www.DSPguide.com. Regards, Steve Smith
SteveSmith wrote:> Hi Jeff, > Here is one way: use a neural net learning algorithm to match the desired > response. See page 476 of Chapter 26 in my free on-line DSP book: > www.DSPguide.com.Thanks for that on-line book. It's been a great help to many. Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
On Nov 1, 8:28 am, "SteveSmith" <Steve.Smi...@SpectrumSDI.com> wrote:> Here is one way: use a neural net learning algorithm to match the desired > response. See page 476 of Chapter 26 in my free on-line DSP book:www.DSPguide.com.There are also genetic optimization algorithms that have been applied to IIR and FIR filter design, such as "differential evolution". IMHO. YMMV. -- rhn A.T nicholson d.0.t C-o-M
Ron N. wrote:> On Nov 1, 8:28 am, "SteveSmith" <Steve.Smi...@SpectrumSDI.com> wrote: > >>Here is one way: use a neural net learning algorithm to match the desired >>response. See page 476 of Chapter 26 in my free on-line DSP book:www.DSPguide.com. > > > There are also genetic optimization algorithms > that have been applied to IIR and FIR filter design, > such as "differential evolution". >How many pompous buzzwords were invented to describe a dumb search by brute force :) VLV
Reply by ●November 2, 20072007-11-02
On Nov 1, 8:00 pm, Vladimir Vassilevsky <antispam_bo...@hotmail.com> wrote:> Ron N. wrote: > > On Nov 1, 8:28 am, "SteveSmith" <Steve.Smi...@SpectrumSDI.com> wrote: > > >>Here is one way: use a neural net learning algorithm to match the desired > >>response. See page 476 of Chapter 26 in my free on-line DSP book:www.DSPguide.com. > > > There are also genetic optimization algorithms > > that have been applied to IIR and FIR filter design, > > such as "differential evolution". > > How many pompous buzzwords were invented to describe a dumb search by > brute force :)well, pompous or not, i like genital optimization algorithms. -- Emily Litella
robert bristow-johnson wrote:> On Nov 1, 8:00 pm, Vladimir Vassilevsky <antispam_bo...@hotmail.com> > wrote: >> Ron N. wrote: >>> On Nov 1, 8:28 am, "SteveSmith" <Steve.Smi...@SpectrumSDI.com> wrote: >>>> Here is one way: use a neural net learning algorithm to match the desired >>>> response. See page 476 of Chapter 26 in my free on-line DSP book:www.DSPguide.com. >>> There are also genetic optimization algorithms >>> that have been applied to IIR and FIR filter design, >>> such as "differential evolution". >> How many pompous buzzwords were invented to describe a dumb search by >> brute force :) > > well, pompous or not, i like genital optimization algorithms.I get at least a hundred spam e-mails a day offering that. Would you like me to forward them to you? Steve
Steve Underwood wrote:>>>> There are also genetic optimization algorithms >>>> that have been applied to IIR and FIR filter design, >>>> such as "differential evolution". >>> >>> How many pompous buzzwords were invented to describe a dumb search by >>> brute force :) >> >> >> well, pompous or not, i like genital optimization algorithms. > > > I get at least a hundred spam e-mails a day offering that. Would you > like me to forward them to you?You might want to look at this: www.spampal.org Seriously speaking, the name of the Greg Berchin should be placed in the pantheon somewhere in between Parks and McClellan :) Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
On Nov 2, 11:27 am, Vladimir Vassilevsky <antispam_bo...@hotmail.com> wrote:> Seriously speaking, the name of the Greg Berchin should be placed in the > pantheon somewhere in between Parks and McClellan :)Whoa; I'm seriously flattered, but I took a class from Tom Parks a long, long time ago and I don't think that I could even tie his shoes, metaphorically speaking. I take it, then, that you've had success with the algorithm? There is so much about that algorithm that never got published. Problem is, it's been so long since I studied it that I don't remember most of it. Greg
