View and manipulate signal as vector?
Started by zqchen ●November 5, 2007
It's said signal may be viewed and manipulated as vetctor. Any
reference or tutorials on this? E-copy is preferred. Thanks!
On Mon, 05 Nov 2007 04:06:08 +0000, zqchen wrote:
> It's said signal may be viewed and manipulated as vetctor. Any > reference or tutorials on this? E-copy is preferred. Thanks!
No reference or tutorial, but an insight: In sampled time, a signal s_k can be treated as a vector, possibly infinitely long, of discrete values (s_0, s_1, s_2, and so on). If you're intrepid, you can extend this to a continuous-time signal, although it's usually easier to go back to treating it as a function of time. -- Tim Wescott Control systems and communications consulting http://www.wescottdesign.com Need to learn how to apply control theory in your embedded system? "Applied Control Theory for Embedded Systems" by Tim Wescott Elsevier/Newnes, http://www.wescottdesign.com/actfes/actfes.html
Viewing signals as vectors is very natural - it only causes confusion if one is blinded by the analogy of vectors and arrows ("a signal is an arrow?"). One can add signals, distributively multiply them with scalars, etc. You can easily verfy the vector space axioms for any signal space (discrete or continuous): http://en.wikipedia.org/wiki/Vector_space A simple example of viewing signals as vectors is the signal space of discrete periodic functions with period N (assuming a sampling period of T = 1). One basis for this vector space are the "time"-vectors {(1,0,0,..,0), (0,1,0,...,0), ..., (0,0,...,1)} (N of them, as the vector space is N-dimensional). Another basis are the "frequency"-vectors consisting of the sampled sin() and cos()- functions with a period that is an integer fraction of N: {sin(2 pi k /N, cos(2 pi k /N)}, k=0,1,...,N/2 or (N-1)/2, depending if N is even or odd. There are also N of them. The basis transform map that takes the "time"-basis to the "frequency"-basis is the DFT. Regards, Andor
Forgot the time index. This should be {sin(2 pi k n /N), cos(2 pi n k /N)}, k=0,1,...,N/2 or (N-1)/2, and n=0,1,...,N.
>I wrote: >... >> {sin(2 pi k /N, cos(2 pi k /N)}, k=0,1,...,N/2 or (N-1)/2, > >Forgot the time index. This should be >{sin(2 pi k n /N), cos(2 pi n k /N)}, k=0,1,...,N/2 or (N-1)/2, and >n=0,1,...,N. > >
passing thoughts.. If I blindly assume all vectors have "direction", can I go ahead and apply "curl" concept on a sample of 2 dimensional sampled set, (x0, x1) (x2, x3) etc? wiki says curl is "Measures a vector field's tendency to rotate about a point" . can I take 2 cosecutive samples of sine data and get a good measure of curl? By the way my real question was if any one can explain the procedure to measure gradient in LMS equation . (it takes gradient of the set of tap weights and tries to minimize error-squared)
zqchen <zhiqun.chen@gmail.com> writes:
Since the concept of "signal as vector" is pretty easy to see for discrete signals, I'll assume you are asking about continuous-time signals, or more formally, *functions*. A function defined on a domain (i.e., a function f:[a,b]-->R, a,b \in R) is a non-countably infinite-dimensional vector in the sense that it has a non-countably infinte number of components, namely the values of the function f(x), a <= x <= b. We can define a "dot product" for such functions as f\dot g = \int_{a}^{b} f(t)*g(t) dt and this can be used very much like the dot product for the more familiar, finite vectors. For example, two functions are *orthogonal* if their dot product (as defined above) is zero. An excellent reference for this (sorry, but you'll have to actually get up from your computer and go to a library) is [spiegel]. --Randy @BOOK{spiegel, title = "{Applied Differential Equations}", author = "{Murray~R.~Spiegel}", publisher = "Prentice Hall", edition = "third", year = "1981"} -- % Randy Yates % "Rollin' and riding and slippin' and %% Fuquay-Varina, NC % sliding, it's magic." %%% 919-577-9882 % %%%% <yates@ieee.org> % 'Living' Thing', *A New World Record*, ELO http://www.digitalsignallabs.com
On 5 Nov, 10:19, "pal.debabrata123" <pal.debabrata...@gmail.com>
wrote:
> >I wrote: > >... > >> {sin(2 pi k /N, cos(2 pi k /N)}, k=0,1,...,N/2 or (N-1)/2, > > >Forgot the time index. This should be > >{sin(2 pi k n /N), cos(2 pi n k /N)}, k=0,1,...,N/2 or (N-1)/2, and > >n=0,1,...,N. > > passing thoughts.. > If I blindly assume all vectors have "direction",
The have. Try to compute the inner product between x and -x.
> can I go ahead and apply > "curl" concept on a sample of 2 dimensional sampled set, (x0, x1) (x2, x3) > etc?
I don't know. Curl includes the cross product between two vectors, and it is not obvious (to me, at least) how to compute the vector cross product in dimensons different from 3.
> By the way my real question was if any one can explain the procedure to > measure gradient in LMS equation . (it takes gradient of the set of tap > weights and tries to minimize error-squared)
Read any text on optimizatiom methods. The books I have are by Luenberger, and Nocedal and Wright. Rune
On Nov 5, 8:29 am, Rune Allnor <all...@tele.ntnu.no> wrote:
> On 5 Nov, 10:19, "pal.debabrata123" <pal.debabrata...@gmail.com> > wrote: > > > >I wrote: > > >... > > >> {sin(2 pi k /N, cos(2 pi k /N)}, k=0,1,...,N/2 or (N-1)/2, > > > >Forgot the time index. This should be > > >{sin(2 pi k n /N), cos(2 pi n k /N)}, k=0,1,...,N/2 or (N-1)/2, and > > >n=0,1,...,N. > > > passing thoughts.. > > If I blindly assume all vectors have "direction", > > The have. Try to compute the inner product between x and -x. > > > can I go ahead and apply > > "curl" concept on a sample of 2 dimensional sampled set, (x0, x1) (x2, x3) > > etc? > > I don't know. Curl includes the cross product between two > vectors, and it is not obvious (to me, at least) how to > compute the vector cross product in dimensons different > from 3. >
Hello Rune et al, You can do a generalized cross product where you need n-1 basis vectors when you are working in "n" dimensions. Basically fill in the bottom n-1 rows of a matrix with the "basis" functions and expand along the top row by minors. For the curl just fill in the 1st row with a bunch of partial derivative symbols. I.e., d/da, d/db, d/dc, d/ dd, ... d/dz for the correct number of dimensions. This is a natural extension to how one finds a vector orthogonal to two other 3-D vectors. If you recall the technique of filling the the 1st row of a matrix with "i" "j", and "k" and the using the other two vectors to fill in rows 2 and 3. Then one finds the determinant. But recalling one may find the determinant by "minors", then write out the expansion for the determinant of the n by n matrix in terms of the 1st row. So each component of the curl can be find by the determinant of its corresponding n-1 by n-1 matrix. Now the real question becomes what is the physical meaning of such a curl? Which vector identities still hold? In 3-D if a non zero force has a zero curl, then the force is conservative. Stokes and/or Green's theorems can show this. But what > 3 dimensions? Special relativity gives us 4-vectors and their associated idenities. Curl in 83 dimensions? Your guess is as good as mine. I'll have to ponder this. IHTH, Clay
On Nov 5, 12:42 pm, Clay <phys...@bellsouth.net> wrote:
> On Nov 5, 8:29 am, Rune Allnor <all...@tele.ntnu.no> wrote: > > > > > > > On 5 Nov, 10:19, "pal.debabrata123" <pal.debabrata...@gmail.com> > > wrote: > > > > >I wrote: > > > >... > > > >> {sin(2 pi k /N, cos(2 pi k /N)}, k=0,1,...,N/2 or (N-1)/2, > > > > >Forgot the time index. This should be > > > >{sin(2 pi k n /N), cos(2 pi n k /N)}, k=0,1,...,N/2 or (N-1)/2, and > > > >n=0,1,...,N. > > > > passing thoughts.. > > > If I blindly assume all vectors have "direction", > > > The have. Try to compute the inner product between x and -x. > > > > can I go ahead and apply > > > "curl" concept on a sample of 2 dimensional sampled set, (x0, x1) (x2, x3) > > > etc? > > > I don't know. Curl includes the cross product between two > > vectors, and it is not obvious (to me, at least) how to > > compute the vector cross product in dimensons different > > from 3. > > Hello Rune et al, > > You can do a generalized cross product where you need n-1 basis > vectors when you are working in "n" dimensions. Basically fill in the > bottom n-1 rows of a matrix with the "basis" functions and expand > along the top row by minors. For the curl just fill in the 1st row > with a bunch of partial derivative symbols. I.e., d/da, d/db, d/dc, d/ > dd, ... d/dz for the correct number of dimensions. > > This is a natural extension to how one finds a vector orthogonal to > two other 3-D vectors. If you recall the technique of filling the the > 1st row of a matrix with "i" "j", and "k" and the using the other two > vectors to fill in rows 2 and 3. Then one finds the determinant. But > recalling one may find the determinant by "minors", then write out the > expansion for the determinant of the n by n matrix in terms of the 1st > row. So each component of the curl can be find by the determinant of > its corresponding n-1 by n-1 matrix. > > Now the real question becomes what is the physical meaning of such a > curl? Which vector identities still hold? In 3-D if a non zero force > has a zero curl, then the force is conservative. Stokes and/or > Green's theorems can show this. But what > 3 dimensions? Special > relativity gives us 4-vectors and their associated idenities. Curl in > 83 dimensions? Your guess is as good as mine. I'll have to ponder > this. > > IHTH, > > Clay- Hide quoted text - > > - Show quoted text -
Let correct a slight error. For finding a generalized cross product, use n-1 basis vectors. For the curl, use n-2 basis vectors. So for both cases think about "i", "j","k",... on the 1st row. And for the curl fill in the partial derivative symbols on the 2nd row. Then fill in the remaining rows with the basis vectors. I hope this clarifies things. Clay
huh, looks like i missed a lot of important things in the past.
Then i can think of signal as a point in the space, right?
Then what convolution does to this vector?
