Hi, I am new to CCS 3.3 and want to learn C62 now. For the cache tune function with the example mat_oprn_1.c, it shows the cache conflicts. On the cache tune window, there are icons: L1D Hits, L1D Hits/Misses and L1D Misses. It indeed the yellow Hits/Misses is the cross-section of Hits and Misses. The problem is I don't know what is the meaning of Hits/Misses? It literally contradicts from the two words. I don't find the answer from the pdf file and web site. Could you explain it to me? Thanks in advance
What is the meaning of L1D Hits/Misses in CCS 3.3
Started by ●November 5, 2007
Reply by ●November 5, 20072007-11-05
fl wrote:> Hi, > I am new to CCS 3.3 and want to learn C62 now. For the cache tune > function with the example mat_oprn_1.c, it shows the cache conflicts. > On the cache tune window, there are icons: L1D Hits, L1D Hits/Misses > and L1D Misses. It indeed the yellow Hits/Misses is the cross-section > of Hits and Misses. The problem is I don't know what is the meaning of > Hits/Misses? It literally contradicts from the two words. I don't find > the answer from the pdf file and web site. Could you explain it to me? > Thanks in advanceHits Rewrite Hits/Misses as ---------. does that help? Misses Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
On 5 nov, 11:58, Jerry Avins <j...@ieee.org> wrote:> fl wrote: > > Hi, > > I am new to CCS 3.3 and want to learn C62 now. For the cache tune > > function with the example mat_oprn_1.c, it shows the cache conflicts. > > On the cache tune window, there are icons: L1D Hits, L1D Hits/Misses > > and L1D Misses. It indeed the yellow Hits/Misses is the cross-section > > of Hits and Misses. The problem is I don't know what is the meaning of > > Hits/Misses? It literally contradicts from the two words. I don't find > > the answer from the pdf file and web site. Could you explain it to me? > > Thanks in advance > > Hits > Rewrite Hits/Misses as ---------. does that help? > Misses >Sorry, I still don't know. What's the relationship? "And"? "Or"? Please go further.> Jerry > -- > Engineering is the art of making what you want from things you can get. > =AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF==AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF= =AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF=AF
fl wrote:> On 5 nov, 11:58, Jerry Avins <j...@ieee.org> wrote: >> fl wrote: >>> Hi, >>> I am new to CCS 3.3 and want to learn C62 now. For the cache tune >>> function with the example mat_oprn_1.c, it shows the cache conflicts. >>> On the cache tune window, there are icons: L1D Hits, L1D Hits/Misses >>> and L1D Misses. It indeed the yellow Hits/Misses is the cross-section >>> of Hits and Misses. The problem is I don't know what is the meaning of >>> Hits/Misses? It literally contradicts from the two words. I don't find >>> the answer from the pdf file and web site. Could you explain it to me? >>> Thanks in advance >> Hits >> Rewrite Hits/Misses as ---------. does that help? >> Misses >> > > Sorry, I still don't know. What's the relationship? "And"? "Or"? > Please go further.1 Ratio. That was intended to show a fraction bar. 1/2 = --- 2 Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
