Hello, I'm looking for a good book on the topic of motor control with microcontrollers, with emphasis on PWM algorithms. I'm interested more in the PWM side of things than in control theory (PID), as the motor I need to control is an AC motor that only has to be speed-controlled (it's a big ventilation fan). From searching the net it appears that this is a topic with a lot of ad-hoc solutions, so I would really love to hear recommendations of books and/or good online resources for learning the topic. Thanks in advance, R
Book recommendations about PWM motor control
Started by ●November 5, 2007
Reply by ●November 5, 20072007-11-05
richard.melikson@gmail.com wrote:> Hello, > > I'm looking for a good book on the topic of motor control with > microcontrollers, with emphasis on PWM algorithms. I'm interested more > in the PWM side of things than in control theory (PID), as the motor I > need to control is an AC motor that only has to be speed-controlled > (it's a big ventilation fan). From searching the net it appears that > this is a topic with a lot of ad-hoc solutions, so I would really love > to hear recommendations of books and/or good online resources for > learning the topic. > > Thanks in advance, > R >In addition to looking for books, you may want to look for white papers on the web sites of microcontroller manufacturers. ADI, TI, and Freescale all make DSP chips with 3-phase PWM outputs that are optimized for driving motors -- you should find interesting material there. If this is for a one-off application, you may find that you'll do better finding an off-the-shelf variable frequency drive rather than reinventing the wheel. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" gives you just what it says. See details at http://www.wescottdesign.com/actfes/actfes.html
> I'm looking for a good book on the topic of motor control with > microcontrollers, with emphasis on PWM algorithms. I'm interested more > in the PWM side of things than in control theory (PID), as the motor I > need to control is an AC motor that only has to be speed-controlled > (it's a big ventilation fan).I don't think there is such thing as PWM algorithm - there might be PID algortithm with PWM output I guess. Anyway I belive you will not get away from PID in this case especially if it's big fan with long response time and inertion. You just won't be able to run it at constant speed either using PWM or by other means. Anyway coding PID is not a rocket science should give it a try.
Tim Wescott wrote:> richard.melikson@gmail.com wrote: > >> Hello, >> >> I'm looking for a good book on the topic of motor control with >> microcontrollers, with emphasis on PWM algorithms. I'm interested more >> in the PWM side of things than in control theory (PID), as the motor I >> need to control is an AC motor that only has to be speed-controlled >> (it's a big ventilation fan).So you are designing a Full 3 Phase AC Motor (variable Freq/Variabe Voltage) controller, or something a little simpler ?>> From searching the net it appears that >> this is a topic with a lot of ad-hoc solutions, so I would really love >> to hear recommendations of books and/or good online resources for >> learning the topic. >> >> Thanks in advance, >> R >> > In addition to looking for books, you may want to look for white papers > on the web sites of microcontroller manufacturers. ADI, TI, and > Freescale all make DSP chips with 3-phase PWM outputs that are optimized > for driving motors -- you should find interesting material there.Good suggestion - Also look at Infineon, they have some 8 bit uC with Motor control extensions, which may be all you need for a Fan Speed control. -jg
richard.melikson@gmail.com wrote:> Hello, > > I'm looking for a good book on the topic of motor control with > microcontrollers, with emphasis on PWM algorithms. I'm interested more > in the PWM side of things than in control theory (PID), as the motor I > need to control is an AC motor that only has to be speed-controlled > (it's a big ventilation fan). From searching the net it appears that > this is a topic with a lot of ad-hoc solutions, so I would really love > to hear recommendations of books and/or good online resources for > learning the topic.If book you feel you need then I suggest:- "Electrical Drives and Their Controls" by Richard M. Crowder Oxford Science Publications; ISBN 0-19-856565-8 Tim Wescott's suggestion of also searching out the white papers and application notes of device manufacturers is also a good one. Try these ones:- <http://www.ibiblio.org/obp/electricCircuits/AC/AC_10.html> <http://www.analog.com/en/app/0,3174,999%255F1114,00.html> <http://www.freescale.com/files/dsp/doc/app_note/AN1958.pdf> -- ******************************************************************** Paul E. Bennett...............<email://Paul_E.Bennett@topmail.co.uk> Forth based HIDECS Consultancy Mob: +44 (0)7811-639972 Tel: +44 (0)1235-811095 Going Forth Safely ..... EBA. www.electric-boat-association.org.uk.. ********************************************************************
Tim Wescott wrote:> DJ wrote: >> >>> I'm looking for a good book on the topic of motor control with >>> microcontrollers, with emphasis on PWM algorithms. I'm interested more >>> in the PWM side of things than in control theory (PID), as the motor I >>> need to control is an AC motor that only has to be speed-controlled >>> (it's a big ventilation fan). >> >> I don't think there is such thing as PWM algorithm - there might be >> PID algortithm with PWM output I guess. >> Anyway I belive you will not get away from PID in this case especially >> if it's big fan with long response time and inertion. You just won't >> be able to run it at constant speed either using PWM or by other >> means. Anyway coding PID is not a rocket science should give it a try. > > Whether you need a PID controller depends on what you're trying to do. > An induction machine will give you about 500 RPM of slip; if you only > need to be that close then you don't need the PID controller.%oo 5pm at what frequency? How many poles? Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
DJ wrote:> >> I'm looking for a good book on the topic of motor control with >> microcontrollers, with emphasis on PWM algorithms. I'm interested more >> in the PWM side of things than in control theory (PID), as the motor I >> need to control is an AC motor that only has to be speed-controlled >> (it's a big ventilation fan). > > I don't think there is such thing as PWM algorithm - there might be PID > algortithm with PWM output I guess. > Anyway I belive you will not get away from PID in this case especially > if it's big fan with long response time and inertion. You just won't be > able to run it at constant speed either using PWM or by other means. > Anyway coding PID is not a rocket science should give it a try.Whether you need a PID controller depends on what you're trying to do. An induction machine will give you about 500 RPM of slip; if you only need to be that close then you don't need the PID controller. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" gives you just what it says. See details at http://www.wescottdesign.com/actfes/actfes.html
Jerry Avins wrote: ...> %oo 5pm at what frequency? How many poles?^Capital '5'. :-) Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●November 6, 20072007-11-06
Jerry Avins wrote:> Tim Wescott wrote: >> DJ wrote: >>> >>>> I'm looking for a good book on the topic of motor control with >>>> microcontrollers, with emphasis on PWM algorithms. I'm interested more >>>> in the PWM side of things than in control theory (PID), as the motor I >>>> need to control is an AC motor that only has to be speed-controlled >>>> (it's a big ventilation fan). >>> >>> I don't think there is such thing as PWM algorithm - there might be >>> PID algortithm with PWM output I guess. >>> Anyway I belive you will not get away from PID in this case >>> especially if it's big fan with long response time and inertion. You >>> just won't be able to run it at constant speed either using PWM or by >>> other means. Anyway coding PID is not a rocket science should give it >>> a try. >> >> Whether you need a PID controller depends on what you're trying to do. >> An induction machine will give you about 500 RPM of slip; if you only >> need to be that close then you don't need the PID controller. > > %oo 5pm at what frequency? How many poles? >I was thinking someone was going to ding me on pole count when I wrote that. "About" 500RPM. So, anything from 0 to 750, or more. That should cover any number of poles. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com Do you need to implement control loops in software? "Applied Control Theory for Embedded Systems" gives you just what it says. See details at http://www.wescottdesign.com/actfes/actfes.html
On Nov 5, 7:49 pm, richard.melik...@gmail.com wrote:> Hello, > > I'm looking for a good book on the topic of motor control with > microcontrollers, with emphasis on PWM algorithms. I'm interested more > in the PWM side of things than in control theory (PID), as the motor I > need to control is an AC motor that only has to be speed-controlled > (it's a big ventilation fan). From searching the net it appears that > this is a topic with a lot of ad-hoc solutions, so I would really love > to hear recommendations of books and/or good online resources for > learning the topic. > > Thanks in advance, > RFor the PWM side of things check for SPRA524 application note on TI's site Regarda Mitja
