Book recommendations about PWM motor control
Started by Unknown November 5, 2007
Related, although not on the theory side:
Hobby shops sell motor controllers for RC planes for a couple of $
(so-called "brushless" motors, three phase).
Might be useful as reference.
The smaller ones manage for example 10 amps at 8..15 V. I've got one of
those in my heli :)
-mn
On Nov 6, 7:49 am, richard.melik...@gmail.com wrote:
> Hello, > > I'm looking for a good book on the topic of motor control with > microcontrollers, with emphasis on PWM algorithms. I'm interested more > in the PWM side of things than in control theory (PID), as the motor I > need to control is an AC motor that only has to be speed-controlled > (it's a big ventilation fan). From searching the net it appears that > this is a topic with a lot of ad-hoc solutions, so I would really love > to hear recommendations of books and/or good online resources for > learning the topic. > > Thanks in advance, > R
PWM is for dc motor control. The average level gets applied to the motor. If you want to control the speed of an ac motor then you can use other methods.You could synthesis your own variable frequency AC but that's not PWM. Hardy
HardySpicer wrote:
> On Nov 6, 7:49 am, richard.melik...@gmail.com wrote: >> Hello, >> >> I'm looking for a good book on the topic of motor control with >> microcontrollers, with emphasis on PWM algorithms. I'm interested more >> in the PWM side of things than in control theory (PID), as the motor I >> need to control is an AC motor that only has to be speed-controlled >> (it's a big ventilation fan). From searching the net it appears that >> this is a topic with a lot of ad-hoc solutions, so I would really love >> to hear recommendations of books and/or good online resources for >> learning the topic. >> >> Thanks in advance, >> R > > PWM is for dc motor control. The average level gets applied to the > motor. If you want to control the speed of an ac motor then you can > use other methods.You could synthesis your own variable frequency AC > but that's not PWM.
Someone can correct me if I'm wrong. As the speed of an AC motor approaches zero, you must somehow reduce the amplitude of the waveform to limit current draw. This likely would involve PWM modulation to generate a reduced amplitude sine wave.
Jim Stewart wrote:
> HardySpicer wrote: > >> On Nov 6, 7:49 am, richard.melik...@gmail.com wrote: >> >>> Hello, >>> >>> I'm looking for a good book on the topic of motor control with >>> microcontrollers, with emphasis on PWM algorithms. I'm interested more >>> in the PWM side of things than in control theory (PID), as the motor I >>> need to control is an AC motor that only has to be speed-controlled >>> (it's a big ventilation fan). From searching the net it appears that >>> this is a topic with a lot of ad-hoc solutions, so I would really love >>> to hear recommendations of books and/or good online resources for >>> learning the topic. >>> >>> Thanks in advance, >>> R >> >> >> PWM is for dc motor control. The average level gets applied to the >> motor. If you want to control the speed of an ac motor then you can >> use other methods.You could synthesis your own variable frequency AC >> but that's not PWM. > > > Someone can correct me if I'm wrong. > > As the speed of an AC motor approaches > zero, you must somehow reduce the amplitude > of the waveform to limit current draw. This > likely would involve PWM modulation to > generate a reduced amplitude sine wave.
The relation of motor voltage and rotation speed applies to all electric motors, but certain motors do not follow the input voltage alone. If you have a shaded-pole induction AC motor, the motor creates the torque for running from the lag between the feed AC frequency and the rotation speed of the rotor. When the lag grows, the motor quickly loses the torque and becomes essentially a shorted transformer. The only way to safely control the rotation speed of an induction motor is to control the frequency and feed voltage synchronized to each other. If you simply drop the input energy by clipping a part of the feed AC off, the motor quickly stalls when you're getting more than a couple of then of percent off the nominal speed. Maybe the best way to control an induction motor is a DSP method, called rotor vector synthesis. -- Tauno Voipio tauno voipio (at) iki fi
Dont waste your time, modern inverters use a vector control algorithm, but if you must IR "power train" development kits are available as well as a Fujitsu starter kit for inverters.
Tauno Voipio wrote:
> The only way to safely control the rotation speed > of an induction motor is to control the frequency > and feed voltage synchronized to each other. > > If you simply drop the input energy by clipping a > part of the feed AC off, the motor quickly stalls > when you're getting more than a couple of then of > percent off the nominal speed. > > Maybe the best way to control an induction motor > is a DSP method, called rotor vector synthesis.
The book (whose details I have already posted) calls it "Full Vector Control" but is as you describe, controlling the applied voltage and the frequency of operation. The following papers look interesting:- <http://www.eu.necel.com/_pdf/U16483EE1V0AN00.PDF> <http://www.iee.or.jp/trans/pdf/2000/0010D_1165.pdf> <http://www.elkraft.ntnu.no/norpie/10956873/Final Papers/030 - Salomaki.pdf> -- ******************************************************************** Paul E. Bennett...............<email://Paul_E.Bennett@topmail.co.uk> Forth based HIDECS Consultancy Mob: +44 (0)7811-639972 Tel: +44 (0)1235-811095 Going Forth Safely ..... EBA. www.electric-boat-association.org.uk.. ********************************************************************
