Hi, I'm trying to understand how synchronision might work in an OFDM receiver with respect to the consequences it has for how the baseband or IF signal is sampled. I have tried to read widely, but the IEEE literature around OFDM synchronisation never seems to mention the sample rate or the hardwarey aspects. Below is brief background to try and illustrate where I am coming from, followed by three specific questions that I am finding it difficult to answer. Background Broadly speaking, my understanding is that there are 3 "aspects" that need to be synchronised in the receiver. 1) Timing synchronisation - the receiver needs to know the time instant when the symbol starts. (I have seen various correlation based methods for this). 2) Carrier Frequency Offset (CFO) - Assuming a hetrodyne receiver there will be a local oscilator (LO) mixing the incoming signal down to an IF. The LO will have some frequency offset compared to the transmitter. For OFDM this offset causes a loss of orthogonality for the subcarriers, so the CFO must be corrected for. 3) Carrier phase offset. The Question: 1) Once the Carrier Frequency Offset has been estimated, how do we correct for it? Once the LO has mixed the signal down it seems to me that orthogonality has been lost and little can be done. So does the receiver modify the frequency of the LO to ensure it is kept frequency locked to the transmitter carrier frequency? Practically speaking how could the LO frequency be changed? I suppose standard frequency synthesis techniques are used (e.g. PLL, NCO...) 2) If my digital receiver is sampling the baseband signal, I'm beginning to think this sampling rate is completely independent of the synchronisation issues mentioned in 1,2,3. The key is to sample at more than twice the nyquist rate, and that is all I have to do to reconstruct the baseband signal? The sampling rate has nothing to do with synchronisation? 3) What about if my digital receiver is sampling at IF, again is the only requirement that I sample at the Nyquist rate? I don't need to somehow change my sample rate based on the CFO estimated by my digital processing in the receiver? Regards Andrew
Relationship (if any?) between OFDM receiver synchronisation and IF or baseband sampling rate
Started by ●November 5, 2007
Reply by ●November 6, 20072007-11-06
>The Question: >1) Once the Carrier Frequency Offset has been estimated, how do we >correct for it?Simply multiply the IQ sample stream with exp(-i*omega*t), a rotating unity phasor. Nothing is lost, in theory you can recover from CFO without information loss and in reality it may be only limited by the quality of the CFO estimate.> 2) If my digital receiver is sampling the baseband signal, I'm > beginning to think this sampling rate is completely independent ofthe... It's purely an implementation question. Any rate will do, that has an integer number of samples per symbol. Essentially, higher rate gives zero padding in the frequency domain. But some oversampling is needed, because you cannot suppress adjacent channels sufficiently in the analog domain.>3) What about if my digital receiver is sampling at IF, again is the >only requirement that I sample at the Nyquist rate? I don't need to >somehow change my sample rate based on the CFO estimated by my digital >processing in the receiver?No, you don't need to. Just run at a fixed rate. Note that "Nyquist rate" relates to the bandwidth, not the frequency (i.e. for a 1 MHz wide signal at 70 MHz IF the limit is 1M complex samples/s - bandpass sampling). In reality one needs oversampling, as mentioned. -mn PS: This may clarify or confuse, don't know: When the receiver moves at extremely high speeds (for example) towards the transmitter, the symbol duration will in fact shorten. Then one would need to adapt the rate to get the desired number of samples per symbol. So the idea of changing the rate is not completely unfounded. But AFAIK this effect is so small that it is negligible.
On Nov 5, 7:59 pm, Andrew FPGA <andrew.newsgr...@gmail.com> wrote:> Hi, > I'm trying to understand how synchronision might work in an OFDM > receiver with respect to the consequences it has for how the baseband > or IF signal is sampled. I have tried to read widely, but the IEEE > literature around OFDM synchronisation never seems to mention the > sample rate or the hardwarey aspects. Below is brief background to try > and illustrate where I am coming from, followed by three specific > questions that I am finding it difficult to answer. > > Background > Broadly speaking, my understanding is that there are 3 "aspects" that > need to be synchronised in the receiver. > 1) Timing synchronisation - the receiver needs to know the time > instant when the symbol starts. (I have seen various correlation based > methods for this). > 2) Carrier Frequency Offset (CFO) - Assuming a hetrodyne receiver > there will be a local oscilator (LO) mixing the incoming signal down > to an IF. The LO will have some frequency offset compared to the > transmitter. For OFDM this offset causes a loss of orthogonality for > the subcarriers, so the CFO must be corrected for. > 3) Carrier phase offset. > > The Question: > 1) Once the Carrier Frequency Offset has been estimated, how do we > correct for it? Once the LO has mixed the signal down it seems to me > that orthogonality has been lost and little can be done. So does the > receiver modify the frequency of the LO to ensure it is kept frequency > locked to the transmitter carrier frequency? Practically speaking how > could the LO frequency be changed? I suppose standard frequency > synthesis techniques are used (e.g. PLL, NCO...) > > 2) If my digital receiver is sampling the baseband signal, I'm > beginning to think this sampling rate is completely independent of the > synchronisation issues mentioned in 1,2,3. The key is to sample at > more than twice the nyquist rate, and that is all I have to do to > reconstruct the baseband signal? The sampling rate has nothing to do > with synchronisation? > > 3) What about if my digital receiver is sampling at IF, again is the > only requirement that I sample at the Nyquist rate? I don't need to > somehow change my sample rate based on the CFO estimated by my digital > processing in the receiver? > > Regards > AndrewHave you forgotten that the sample rate of the Rx and Tx must match as well? If they don't then the carriers in the OFDM symbol lose orthogonality in your FFT. The systems I've worked on also had a synchronization & tracking loop in the Rx to align the sample rates. EB
Reply by ●November 7, 20072007-11-07
>>Have you forgotten that the sample rate of the Rx and Tx must match aswell? No, that is not true. I need an integer number of samples per period, everything else just ends up as zero-padding inside the FFT. -mn
Hi Mn, Thanks for your post. It has exposed me to a different view so that is great, and has really got me thinking.> Simply multiply the IQ sample stream with exp(-i*omega*t), a rotating > unity phasor.Ok, I think the following is a another graphical way of thinking about this: the rx LO with omega CFO will downconvert the passband signal to baseband - but the now baseband frequency spectrum will not quite be centered around DC, it will be centered around omega rad/s. So you are saying to correct for the CFO we simply down-convert again, but this time do it digitally i.e. as part of the baseband processing? no? (assuming we have an estimate for the CFO, correcting for the CFO sounds easy - I'm not saying estimating CFO is easy, leave that problem for later).> Any rate will do, that has an > integer number of samples per symbol. > Essentially, higher rate gives zero padding in the frequency domain.Why does the sample rate need to be an integer number of samples per OFDM symbol? and what does this really mean given that symbol duration will be spread in time by the channel? If I think in terms of the fourier transform and spectral leakage, I suppose I can see that a non-integer number of samples will cause spectral leakage - which is effectively one sub-carrier spreading into all others. So practically speaking, and in general terms how does one ensure we sample at a rate that is an integer number of samples per OFDM symbol? Your zero padding comment makes perfect sense! I buy it because I am familiar with zero padding in the time domain causing higher rate of sampling of the frequency domain, and by considering Fourier Transform's duality principle.> But some oversampling is needed, because you cannot suppress adjacent > channels sufficiently in the analog domain.I don't understand how oversampling helps to suppress adjacent channels. By oversampling we are just extending the frequency range which we are observing with the demod FFT. The resultant frequency domain zero padding just extends into the adjacent channel - so in fact we may not see zeros there - we may see energy from the adjacent channel. If energy from adjacent channels spills into our channel bandwidth, I can't see how sampling faster would help to remove it? Cheers Andrew
>Ok, I think the following is a another graphical wayYes, that's the way I see it (or upconversion, depending on the sign).>Why does the sample rate need to be an integer number of samples per >OFDM symbol? and what does this really mean given that symbol duration >will be spread in time by the channel?Let me put it in other words: You want an integer number of samples for each OFDM symbol. Otherwise there is not a full symbol length inside the FFT, and orthogonality suffers....>... >that a non-integer number of samples will cause >spectral leakage - which is effectively one sub-carrier spreading into >all others.right.>So practically speaking, and in general terms how does one ensure we >sample at a rate that is an integer number of samples per OFDM symbol?As above, have a full OFDM symbol inside the FFT. Sorry if I made up a complicated explanation for something very simple :)>I don't understand how oversampling helps to suppress adjacent >channels.The more oversampling I have, the more bins will I use in the FFT (which is BTW quite expensive). So adjacent channels (neighboring frequencies) will show up in the FFT as subcarriers that I'm not interested in. With a lower rate they alias on top of my signal, even before the FFT.>>we may see energy from the adjacent channel.That is correct... Zero-padding wasn't accurate, but I think it's clear. In an implementation I'd use a digital filter before the FFT, and decimate, since I don't care about the information in the adjacent channels.>If energy from adjacent channels spills into our channel bandwidth, I >can't see how sampling faster would help to remove it?That's just plain old aliasing problem, as in any other non-OFDM system. Cheers Markus
Reply by ●November 8, 20072007-11-08
On Nov 7, 12:38 am, "mnentwig" <mnent...@elisanet.fi> wrote:> >>Have you forgotten that the sample rate of the Rx and Tx must match as > > well? > No, that is not true. I need an integer number of samples per period, > everything else just ends up as zero-padding inside the FFT. > > -mnI'm interested in exploring this further because it seems to be a fundamental misunderstanding on my part. It seems to me that if you're trying to optimize the hardware for an OFDM system, you will want to closely match the number of carriers in your symbol (guard + pilot + information) to the size of your FFT. With that understood, it seems that in order to minimize interference between the carriers due to spectral leakage, you need to ensure that they are orthogonal in the FFT size - ie, you have an integer number of _cycles_ of each carrier in the transformed symobl. To achieve this, you need to match the sample rate of the received symbol to the sample rate of the transmitted symbol. This is usually done with some sort of clock tracking loop and resampling/interpolation since you can't rely on the TX and RX rates to match in the face of manufacturing variations, temperature differences and doppler effects. OTOH, if hardware efficiency is not one of your goals and you have processing to spare, then you can afford to oversample your recieved symbol and throw it (with padding) into a huge DFT. In that case the oversampling will provide some buffer between the carriers, although I think you may still see spectral leakage if the TX and RX aren't related by integer ratios. EB
On Nov 5, 6:59 pm, Andrew FPGA <andrew.newsgr...@gmail.com> wrote:> Hi, > I'm trying to understand how synchronision might work in an OFDM > receiver with respect to the consequences it has for how the baseband > or IF signal is sampled. I have tried to read widely, but the IEEE > literature around OFDM synchronisation never seems to mention the > sample rate or the hardwarey aspects. Below is brief background to try > and illustrate where I am coming from, followed by three specific > questions that I am finding it difficult to answer. > > Background > Broadly speaking, my understanding is that there are 3 "aspects" that > need to be synchronised in the receiver. > 1) Timing synchronisation - the receiver needs to know the time > instant when the symbol starts. (I have seen various correlation based > methods for this). > 2) Carrier Frequency Offset (CFO) - Assuming a hetrodyne receiver > there will be a local oscilator (LO) mixing the incoming signal down > to an IF. The LO will have some frequency offset compared to the > transmitter. For OFDM this offset causes a loss of orthogonality for > the subcarriers, so the CFO must be corrected for. > 3) Carrier phase offset. > > The Question: > 1) Once the Carrier Frequency Offset has been estimated, how do we > correct for it? Once the LO has mixed the signal down it seems to me > that orthogonality has been lost and little can be done. So does the > receiver modify the frequency of the LO to ensure it is kept frequency > locked to the transmitter carrier frequency? Practically speaking how > could the LO frequency be changed? I suppose standard frequency > synthesis techniques are used (e.g. PLL, NCO...) > > 2) If my digital receiver is sampling the baseband signal, I'm > beginning to think this sampling rate is completely independent of the > synchronisation issues mentioned in 1,2,3. The key is to sample at > more than twice the nyquist rate, and that is all I have to do to > reconstruct the baseband signal? The sampling rate has nothing to do > with synchronisation? > > 3) What about if my digital receiver is sampling at IF, again is the > only requirement that I sample at the Nyquist rate? I don't need to > somehow change my sample rate based on the CFO estimated by my digital > processing in the receiver? > > Regards > AndrewThe July 2007 IEEE Proceedings issue has a tutorial article on OFDM synchronization. It might be useful to look at it. Particularly for the strategies used in implementations, even if you don't take the time to follow the details of every equation. For example, one of the motivations for using OFDM is to be able to perform equalization as N simple one-tap equalizers instead of a single time domain N-tap equalizer implemented at N**2 or N**3 complexity. Given the simple equalization structure, it is feasible to only make coarse frequency and delay corrections explicitly and let the one-tap equalizer make the final fine corrections. This becomes even more important in multi- user MIMO implementations which require different corrections in different user's bins. Dale B. Dalrymple http://dbdimages.com Http://stores.lulu.com/dbd
Reply by ●November 10, 20072007-11-10
> It seems to me that if you're trying to optimize the hardware for an > OFDM system, you will want to closely match the number of carriers in > your symbol (guard + pilot + information) to the size of your FFT.Why? The FFT size can't be smaller than the number of data symbols per OFDM symbol, but I can't see why the FFT couldn't be larger. FFT larger means zero padding in the frequency domain, which is oversampling in the time domain. That seems fine to me? (sure it means an FFT thats larger than necessary, so wasted computation. Oh, hang on, opps, I reread your question and you said "optimise the hardware", so I think this was actually what you were saying, in which case I agree!)> With that understood, it seems that in order to minimize interference > between the carriers due to spectral leakage, you need to ensure that > they are orthogonal in the FFT size - ie, you have an integer number > of _cycles_ of each carrier in the transformed symobl. To achieve > this, you need to match the sample rate of the received symbol to the > sample rate of the transmitted symbol. This is usually done with some > sort of clock tracking loop and resampling/interpolation since you > can't rely on the TX and RX rates to match in the face of > manufacturing variations, temperature differences and doppler effects.I reckon in order to demodulate properly you need to estimate the carrier frequency offset, be phase locked to the carrier(required for coherent detection), and know when the ofdm symbol starts in time. One may also need to correct for distortions added by the channel (equalisation). But bugger me if I can see the link between that, and choosing a sampling rate that is an integer multiple of the ofdm symbol duration. I mean, I'm totally convinced that an integer ratio is what you need to demod the ofdm symbol with least loss of orthogonality, but how do you figure out how to change the sampling rate such that an integer ratio is achieved? Regards Andrew
On Nov 10, 1:52 am, Andrew FPGA <andrew.newsgr...@gmail.com> wrote:> I mean, I'm totally convinced that an integer ratio > is what you need to demod the ofdm symbol with least loss of > orthogonality, but how do you figure out how to change the sampling > rate such that an integer ratio is achieved?Sample rate mismatches will have the effect of stretching/shrinking the symbol in the FFT bins, and will introduce a predictably varying phase error in each carrier across the symbol. By examining this phase error you can infer the sample rate error and correct it in a closed loop. EB
