Hi all, I want to compute the noise figure and the noise floor for my reciever. for the NF i use the Friss equation. But for the noise floor i d'ont found any formula. With an amplifier the No floor is : Noise output = Noise input + Gain + NF But with an rf attenuators the NF is equal to the attenuation value. So Noise output = Noise input + Gain + NF don't work when Noise input > -174dBm/Hz Someone can help me ? For example input signal : power -50 dBm / noise floor -174 dbm/Hz first amplifier Gain 30dB NF 1.25dB second attenuators Gain -3dB NF 3dB third amplifier Gain 10dB NF 0.8dB what is the final noise floor ?
Noise Figure and Noise Floor
Started by ●November 7, 2007
Reply by ●November 7, 20072007-11-07
>So >Noise output = Noise input + Gain + NF don't work when Noise input > > -174dBm/HzActually it does. Personally I believe that everybody who does receiver system design has to fall into that pit once. There is one equation I have to remember, I can derive everything else incl. Friis' formula from it: ------------------------------------------------------------------------ Input-referred noise contribution by the device is (F-1) kBT referred to the input ------------------------------------------------------------------------ F: noise figure (linear scale) k: 1.3806e-23 J/K T: Temperature, and assume for simplicity's sake that the source temperature is the same as the attenuator. The INPUT-REFERRED noise contribution of the attenuator is (F-1) kBT. The source noise is kBT. So the total input-referred noise is F kBT. Example: Let's consider a 20 dB attenuator: F is 100. The INPUT-REFERRED noise contribution is 99 kBT, the source contributes 1 kBT => total 100. The attenuator scales it down by a factor of 100. The total output noise is kBT, as thermodynamics demand for matter at temperature T. To answer your example question, calculate for example as follows: - Determine the equivalent noise figure using Friis' equation - Determine the INPUT-REFERRED noise contribution and add 1 (kBT) - Scale with the gain and you've got the noise floor at any point in the chain. Hope that clarifies. Cheers Markus PS: The reason why I have capitalized "input-referred" three times: it is REFERRED to the input, although this number is a power / power density, it is NOT a physical quantity I could measure with a power meter.
Reply by ●November 8, 20072007-11-08
thanks for your answer, i've understood now "mnentwig" <mnentwig@elisanet.fi> a �crit dans le message de news: 6u-dnZ5ETJpNsK_anZ2dnUVZ_gudnZ2d@giganews.com...> >So >>Noise output = Noise input + Gain + NF don't work when Noise input >> > -174dBm/Hz > > Actually it does. Personally I believe that everybody who does receiver > system design has to fall into that pit once. > > There is one equation I have to remember, I can derive everything else > incl. Friis' formula from it: > > ------------------------------------------------------------------------ > Input-referred noise contribution by the device is (F-1) kBT > referred to the input > ------------------------------------------------------------------------ > F: noise figure (linear scale) > k: 1.3806e-23 J/K > T: Temperature, and assume for simplicity's sake that the source > temperature is the same as the attenuator. > > The INPUT-REFERRED noise contribution of the attenuator is (F-1) kBT. The > source noise is kBT. So the total input-referred noise is F kBT. > > Example: Let's consider a 20 dB attenuator: F is 100. The INPUT-REFERRED > noise contribution is 99 kBT, the source contributes 1 kBT => total 100. > The attenuator scales it down by a factor of 100. The total output noise > is kBT, as thermodynamics demand for matter at temperature T. > > To answer your example question, calculate for example as follows: > - Determine the equivalent noise figure using Friis' equation > - Determine the INPUT-REFERRED noise contribution and add 1 (kBT) > - Scale with the gain and you've got the noise floor at any point in the > chain. > > Hope that clarifies. > > Cheers > > Markus > > PS: The reason why I have capitalized "input-referred" three times: it is > REFERRED to the input, although this number is a power / power density, it > is NOT a physical quantity I could measure with a power meter. > >
