Hi, I have a question about the time scaling property of the Fourier transform. One can find two different formulas of the time scaling property in the literature. These formulas are: 1. x(at) <-> 1/|a| X(f/a) 2. x(at) <-> 1/a X(f/a) The first formula uses the absolute value for 1/a, the second one does not use the absolute value for 1/a. In fact, when I try to prove this property using the substitution rule in the integral I obtain the second formula. Could somebody explain me please where the absolute value for 1/a comes from in the first formula. Anatol
Time scaling property of Fourier transform
Started by ●November 11, 2007
Reply by ●November 12, 20072007-11-12
Check hyopthesis.. Anatol ha scritto:> Hi, > > I have a question about the time scaling property of the Fourier > transform. > One can find two different formulas of the time scaling property in the > literature. These formulas are: > 1. x(at) <-> 1/|a| X(f/a) > 2. x(at) <-> 1/a X(f/a) > The first formula uses the absolute value for 1/a, the second one does > not use the absolute value for 1/a. > > In fact, when I try to prove this property using the substitution rule in > > the integral I obtain the second formula. Could somebody explain me > please where the absolute value for 1/a comes from in the first formula. > > Anatol > > >
Hi Anatol, The first equation can't be correct as written, since it would mean: x(at) <-> 1/|a| X(f/a) = 1/|-a| X(f/a) <-> x(-at) That is, x(at)is not equal to x(-at). My guess is that the author of this equation was referring to the magnitude of the Fourier Transform, and was ignoring the phase. You can make the equation correct by including the statement that the sign of the phase must be changed if a < 0. That is, If x(t) <-> Mag X(f) and Phase X(f) then x(-t) <-> Mag X(f) and -Phase X(f) Hope this helps. Regards, Steve Smith
On Nov 11, 9:52 pm, "Anatol" <uana...@yahoo.com> wrote:> > I have a question about the time scaling property of the Fourier > transform. > One can find two different formulas of the time scaling property in the > literature. These formulas are: > 1. x(at) <-> 1/|a| X(f/a) > 2. x(at) <-> 1/a X(f/a) > The first formula uses the absolute value for 1/a, the second one does > not use the absolute value for 1/a. > > In fact, when I try to prove this property using the substitution rule in > the integral I obtain the second formula. Could somebody explain me > please where the absolute value for 1/a comes from in the first formula. >On Nov 12, 8:08 pm, "SteveSmith" <Steve.Smi...@SpectrumSDI.com> wrote:> Hi Anatol, > The first equation can't be correct as written, since it would mean: > > x(at) <-> 1/|a| X(f/a) = 1/|-a| X(f/a) <-> x(-at) >no, the first one *is* correct (and appears as so in every communications text i have in my possession). when "a" is negative when you substitute the variable of integration, the limits of the Fourier Transform integral gets swapped (it becomes an integral from +inf to -inf) and you need to swap them back to fit the definition of the continuous Fourier Transform. r b-j
Reply by ●November 13, 20072007-11-13
robert bristow-johnson wrote:> On Nov 11, 9:52 pm, "Anatol" <uana...@yahoo.com> wrote:(snip)>>x(at) <-> 1/|a| X(f/a) = 1/|-a| X(f/a) <-> x(-at)> no, the first one *is* correct (and appears as so in every > communications text i have in my possession). when "a" is negative > when you substitute the variable of integration, the limits of the > Fourier Transform integral gets swapped (it becomes an integral from > +inf to -inf) and you need to swap them back to fit the definition of > the continuous Fourier Transform.Somehow this reminds me that the Dirac delta function is even. delta(at) = delta(t)/|a| (for constant a). -- glen
>On Nov 11, 9:52 pm, "Anatol" <uana...@yahoo.com> wrote: >> >> I have a question about the time scaling property of the Fourier >> transform. >> One can find two different formulas of the time scaling property inthe>> literature. These formulas are: >> 1. x(at) <-> 1/|a| X(f/a) >> 2. x(at) <-> 1/a X(f/a) >> The first formula uses the absolute value for 1/a, the second one does >> not use the absolute value for 1/a. >> >> In fact, when I try to prove this property using the substitution rulein>> the integral I obtain the second formula. Could somebody explain me >> please where the absolute value for 1/a comes from in the firstformula.>> > >On Nov 12, 8:08 pm, "SteveSmith" <Steve.Smi...@SpectrumSDI.com> wrote: >> Hi Anatol, >> The first equation can't be correct as written, since it would mean: >> >> x(at) <-> 1/|a| X(f/a) = 1/|-a| X(f/a) <-> x(-at) >> > >no, the first one *is* correct (and appears as so in every >communications text i have in my possession). when "a" is negative >when you substitute the variable of integration, the limits of the >Fourier Transform integral gets swapped (it becomes an integral from >+inf to -inf) and you need to swap them back to fit the definition of >the continuous Fourier Transform. > >r b-j >Thanks, The limits swapping explains the equation x(at) <-> 1/|a| X(f/a) for me now. However, one can get very easely confused with the proof the authors provide in their textbooks. The variable substitution rule they use is based on substituting differentials by expressions on differentials. For example, they substitute (dt) by (du/a). The situation when (du/a) is negative creates the impression that the limits swapping is already included in the equation. In my opinion, the proof of this property is much more easy to follow if one uses this variable substitution rule, \int g(t) du/dt dt = \int g(u) du. For this property, we have to apply the substitution rule given above rule for (u = at) and (du/dt = a). For that, we mupltiply first the Fourier transform by the neutral expression ((1/a)(a)), or equivalently by (1/a du/dt). In this way, we introduce (du/dt) in the Fourier integral and we can apply the variable substitution rule. Now, since we substitute (dt) by (du) and not by the expression (du/a), one is no more confused by the sign of (du/a). That is, he has always to consider the integral limits modifications because of the variable substition. Anatol
Hi Anatol, Sorry for the misinformation-- I missed a sign in my previous response, and it is not correct. I agree that the first equation (with the absolute value)is correct. You can derive it from two other properties: if x(t) <=> X(f), then, x(at) <=> 1/a X(f/a), where a > 0 and also, x(-t) <=> X(-f) combining, x(-at) <=> 1/a X(-f/a), where a > 0 which means, x(at) <=> 1/|a| X(f/a), where a > 0 or a < 0 Regards, Steve Smith
>Hi Anatol, >Sorry for the misinformation-- I missed a sign in my previous response, >and it is not correct. I agree that the first equation (with theabsolute>value)is correct. You can derive it from two other properties: > >if x(t) <=> X(f), > >then, x(at) <=> 1/a X(f/a), where a > 0 > >and also, x(-t) <=> X(-f) > >combining, > >x(-at) <=> 1/a X(-f/a), where a > 0 > >which means, > >x(at) <=> 1/|a| X(f/a), where a > 0 or a < 0 > >Regards, >Steve Smith >Hi Steve, Thank you for the posting. Your proof is nice. The only problem I see here is the fact that to prove x(-t) <=> X(-f) we have to use the variable substitution rule that caused to me initially a lot of confusion because of isolated differentials used out of their natural context. Regards, Anatol
On Nov 12, 7:44 pm, robert bristow-johnson <r...@audioimagination.com> wrote:> no, the first one *is* correct (and appears as so in every > communications text i have in my possession). when "a" is negative > when you substitute the variable of integration, the limits of the > Fourier Transform integral gets swapped (it becomes an integral from > +inf to -inf) and you need to swap them back to fit the definition of > the continuous Fourier Transform.Now that we have that worked out, here is another puzzler. Let I = integral from -1 to +1 of 2/(1+x^2) dx and J = integral from -1 to +1 of -2/(1+y^2) dy so that J = -I. Now, since the integrand is the derivative of 2.arctan(x), it is easy to work out that I = pi and therefore J = -pi. But, the substitution y = 1/x transforms I into J and so J = pi. We conclude that pi = -pi so it must be that pi = 0, which simplifies many of the equations used in this group!
On Nov 13, 4:34 pm, "sarw...@YouEyeYouSee.edu" <dvsarw...@gmail.com> wrote:> > Now that we have that worked out, here is another puzzler. Let > > I = integral from -1 to +1 of 2/(1+x^2) dx and J = integral from -1 to > +1 of -2/(1+y^2) dy > > so that J = -I. Now, since the integrand is the derivative of > 2.arctan(x), it is easy to > work out that I = pi and therefore J = -pi. But, the substitution y > = 1/xbecause division by zero is a problem, you have to bust the J integral into two integrals (from -1 to 0 and from 0 to +1) when you make that particular substitution and transform the limits of the integral in accordance to the substitution. r b-j
