Steve Underwood wrote:> Richard Owlett wrote: >> Steve Underwood wrote: >>> Jerry Avins wrote: >>> >>>> robert bristow-johnson wrote: >>>> >>>>> On Nov 12, 9:45 pm, Jerry Avins <j...@ieee.org> wrote: >>>>> >>>>>> I have been assigned the task of briefly resuscitating a recently >>>>>> deceased professor so that we can learn the whereabouts of his >>>>>> marking >>>>>> book. Can someone point me to Java or C++ code on the web? TIA >>>>>> >>>>>> Diggory Down >>>>> >>>>> >>>>> >>>>> Digg, if you ain't spoofing Jerry, then can you please lemme know >>>>> whatever the hay-ell you be talking about? >>>>> >>>>> if you *are* someone else spoofing Jerry, then take 3 running steps >>>>> and get the flying fuck outa here. >>>> >>>> >>>> It was me. I tried to parody some of the off-the-wall code requests >>>> we see. >>>> >>>> Jerry >>> >>> >>> Parody doesn't work with this stuff. The real requests are more wacky >>> than anything you could think up. >>> >>> "I've been tasked with building an entire UMTS basestation, and I was >>> wondering if someone could help me. What exactly is 2 + 2?" >>> >>> Steve >> >> I'll "see your parody" and "raise you real world". >> >> I was an Instrument Technician for the Cornell Chemistry Dept in the >> mid-60's. We got a brand spanking new post-doc, ink still wet on >> diploma. He was going be working with our brand new high resolution >> mass spec. He was to select a new electrometer amplifier to increase >> its sensitivity. He brought the info on his selection to the shop. At >> maximum gain it had a bandwidth of 10 Hz. I could not convince him >> that it was overkill. While operating well within the linear region of >> the built in electron multiplier, the system would be able to measure >> 1/10 of an electron/second at 10 Hz. Gain bandwidth product was to >> difficult a concept I guess. >> > My comment wasn't intended to be a parody. Its pretty darned close to > some of the messages here recently. > > SteveThe good grammar and politeness was a give-away. Jerry should have phrased it something like this: Subject line: HELP!!!!!!!! Message: i hav 2 wake up a ded prof 2 find his marks book send java or c++ code 2 do this URGENT!!!!!! also xplain ffts to me Regards, John
Resuscitation
Started by ●November 12, 2007
Reply by ●November 14, 20072007-11-14
On Mon, 12 Nov 2007 23:09:44 -0500, Jerry Avins wrote:> robert bristow-johnson wrote: >> On Nov 12, 9:45 pm, Jerry Avins <j...@ieee.org> wrote: >>> I have been assigned the task of briefly resuscitating a recently >>> deceased professor so that we can learn the whereabouts of his marking >>> book. Can someone point me to Java or C++ code on the web? TIA >>> >>> Diggory Down >> >> >> Digg, if you ain't spoofing Jerry, then can you please lemme know >> whatever the hay-ell you be talking about? >> >> if you *are* someone else spoofing Jerry, then take 3 running steps >> and get the flying fuck outa here. > > It was me. I tried to parody some of the off-the-wall code requests we see. > > JerryYou lose considerably verisimilitude with the "TIA" -- it should be something like "and make it snappy!" -- Tim Wescott Control systems and communications consulting http://www.wescottdesign.com Need to learn how to apply control theory in your embedded system? "Applied Control Theory for Embedded Systems" by Tim Wescott Elsevier/Newnes, http://www.wescottdesign.com/actfes/actfes.html
