Hi! I made a code to transfer from external (SDRAM) to internal memory using "memory to memory" mode in DMA. Now I need to use a circular buffer using chained DMA but... it doesn =B4t work! That's part of the code: ----------------------- .=2E.. //Proceed from Block A to Block C TCB_Block_A[0] =3D (int) TCB_Block_C + 3 + PCI ; TCB_Block_A[3] =3D (unsigned int) Block_A + PCI;//- OFFSET; //Proceed from Block B to Block A TCB_Block_B[0] =3D (int) TCB_Block_A + 3 + PCI ; TCB_Block_B[3] =3D (unsigned int) Block_B + PCI;// - OFFSET ; //Proceed from Block C to Block B TCB_Block_C[0] =3D (int) TCB_Block_B + 3 + PCI ; TCB_Block_C[3] =3D (unsigned int) Block_C + PCI;// - OFFSET ; // Enabling Chaining // Block A will be filled first *pCPEP0 =3D (unsigned int) TCB_Block_A - OFFSET + 3 ; *pCPEP1 =3D (unsigned int) TCB_Block_C - OFFSET + 3 ; *pEBEP0 =3D (unsigned int) imgOriginal; *pEBEP1 =3D (unsigned int) imgFinal; *pELEP0 =3D sizeof(unsigned int) * COLUMNA; *pELEP1 =3D sizeof(unsigned int) * COLUMNA; // Now setup the DMA control registers *pDMAC1 =3D DEN | TRAN | CHEN | CBEN; //DMADR / TRAN is "1" : Write to External Memory // Now setup the DMA control registers *pDMAC0 =3D DEN | CHEN | CBEN; //DMADR is "0" : Write to Internal Memory .=2E. ---------- Do you see the problem? I didn't found too much information about this... and no examples... :( Thanks!
DMA Chaining SHARC ADSP-21369
Started by ●November 14, 2007
