Hello, I am using CCS 3.3 and try to use Host Channels (for input, dataflow is Host->Target). Therefore I created in the BIOS a new HST. Mode is input, bufseq is DDR2, bufalign is 4, framesize (words) is 1 and numframes is 1. The HST uses RTDX, which is enabled. The I try to bind the HST to a file. The file created with the following c-code: FILE *f=fopen("data.dat", "wb"); int size=1; short *dat = new short[size]; dat[i]=1; fwrite(dat, sizeof(short), size, f); delete [] dat; But whe I try to bind thefile to the HST I get this error message: --------------------------- DSP/BIOS --------------------------- Unable to bind "data.dat" --------------------------- OK --------------------------- What could be the problem? Thanks and bye.
[CCS] HSC - unable to bind
Started by ●November 16, 2007
