PWM trick
Started by Jim Thomas November 16, 2007
Something looks wrong there...
Jim Thomas wrote:
> Vladimir Vassilevsky wrote: >> This is what delta sigma is for. >> >> Noise shaping 1: >> >> for(;;) >> { >> x = sample + carry_over; >> if(x & 0x80) set_bit(); >> else clr_bit(); >> carry_over = x&0x7F; >> }
So far, so good. Basic first order, fraction saving, whatever you want to call it. The integer part is always 0 or 1, which is output, and the fraction is saved. Result happiness.
>> Noise shaping 2: >> >> for(;;) >> { >> x = sample + (carry_over0<<1) - carry_over1; >> if(x & 0x80) set_bit(); >> else clr_bit(); >> carry_over1 = carry_over0; >> carry_over0 = x&0x7F; >> }
That is not so good. The second order version produces an integer part which is 0, 1 or -1, but it is being treated as though it can only produce 0 or 1. Result misery.
>> The noise shapings of the higher order are less interesting because >> they require multiplication. > > That's pretty cool Vladimir. Thanks for the reply. If this ever comes > up again, I'll try it this way.
Regards, Steve
Wow. Eagle's eye :-) After the posting, I noticed that the 2nd order function was wrong, but I didn't expect anyone to recognize.
>>> for(;;) >>> { >>> x = sample + (carry_over0<<1) - carry_over1; >>> if(x & 0x80) set_bit(); >>> else clr_bit(); >>> carry_over1 = carry_over0; >>> carry_over0 = x&0x7F; >>> } > > > That is not so good. The second order version produces an integer part > which is 0, 1 or -1, but it is being treated as though it can only > produce 0 or 1. Result misery.
You are right. The calculations should be in signed 10 bits and X should be compared as higher or lower then 128, not just checked the bit. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Scott Seidman wrote:
> Jim Thomas <jthomas@bittware.com> wrote in news:13kll479jpttd22 > @corp.supernews.com: > >> Since the PWM was the only thing going on at the time, I don't think an >> IRQ would make it go any faster - especially when the context switching >> overhead is taken into account. > > > You're doing 2 comparisons, 1 increment, and a set or clear bit every pass > through your loop! Compare this to two set or clear for each PWM period. > You should be able to go many times faster, at least, using a timer, > context switching or no. >
Ah... I see what you're getting at now. Your approach is more like my first stab with two transitions per PWM period. Also, I didn't really implement the PWM as posted (that was supposed to be illustrative). In the test application I actually had to generate four different voltages at the same time. All these voltages were output on pins from a single port. I ended up pre-computing the values I needed and then blasted them out: for(i=0; i<sizeof(pwm_bits); i++) { PORTF = pwm_bits[i]; } There are still sizeof(pwm_bits) compares per PWM period (i.e., the check for loop termination), so perhaps using a timer would have been faster. -- Jim Thomas Principal Applications Engineer Bittware, Inc jthomas@bittware.com http://www.bittware.com (603) 226-0404 x536 A pessimist sees the glass as half-empty. An optimist sees it as half-full. An engineer sees it as oversized by 74%, allowing for a 15% margin of error.
