Dirk Bruere at NeoPax wrote:>> It turns out that it is absolutely unnecessary to have 30 biquad >> sections; somewhat 7-8 sections will do quite well for pretty much any >> practical case. > > > Except where the "practical case" is a graphics equaliser in the home or > studio.Let's wait till you will grow wiser. I will keep you plonked you until then, OK? VLV
Interpolated Constant-Q Equalizer
Started by ●November 20, 2007
Reply by ●December 11, 20072007-12-11
On Dec 11, 11:06 am, Vladimir Vassilevsky <antispam_bo...@hotmail.com> wrote:> Dirk Bruere at NeoPax wrote: > > >> It turns out that it is absolutely unnecessary to have 30 biquad > >> sections; somewhat 7-8 sections will do quite well for pretty much any > >> practical case. > > > Except where the "practical case" is a graphics equaliser in the home or > > studio. > > Let's wait till you will grow wiser. I will keep you plonked you until > then, OK?seems to me to be pretty small potatoes (30 vs. 8 sections), quite unworthy of plonking. personally, i like the idea of 1/3 octave graphic rather than 1 octave spacing, just because i like to think of myself as a mathematical control freak (i.e. the more controllable parameters, the better). but practically you're probably right, Vladimir. r b-j
robert bristow-johnson wrote:>>>> It turns out that it is absolutely unnecessary to have 30 biquad >>>>sections; somewhat 7-8 sections will do quite well for pretty much any >>>>practical case.> personally, i like the idea of 1/3 octave graphic rather than 1 octave > spacing,No spacing. Graphic is just the way of representation of the frequency response. You can have 65536 sliders; that doesn't make any difference in the concept.> just because i like to think of myself as a mathematical > control freak (i.e. the more controllable parameters, the better).Then you should like it: 8 biquads = 33 parameters.> but practically you're probably right, Vladimir.The goal is to approximate the desired response, and the function of the 16th order will do that pretty well for any reasonable EQ curve. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
On Dec 11, 9:57 am, robert bristow-johnson <r...@audioimagination.com> wrote:> On Dec 11, 11:06 am, Vladimir Vassilevsky <antispam_bo...@hotmail.com> > wrote: > > > Dirk Bruere at NeoPax wrote: > > > >> It turns out that it is absolutely unnecessary to have 30 biquad > > >> sections; somewhat 7-8 sections will do quite well for pretty much any > > >> practical case. > > > > Except where the "practical case" is a graphics equaliser in the home or > > > studio. > > > Let's wait till you will grow wiser. I will keep you plonked you until > > then, OK? > > seems to me to be pretty small potatoes (30 vs. 8 sections), quite > unworthy of plonking. > > personally, i like the idea of 1/3 octave graphic rather than 1 octave > spacing, just because i like to think of myself as a mathematical > control freak (i.e. the more controllable parameters, the better).Even if you want 30 or so sections, one isn't likely to need to set the controls so that there are more than 8 or so moveable inflection points that create an audible difference. As long as the number of inflection points is reasonable, it might not matter how many control points are being interpolated (1/12th octave or whatever) in the frequency domain by a smaller number of parametric biquads. (Of course, all bets are off if one is (mis)using a graphics equalizer to create bizarre timbres so that, say, a producer can create a "new" sound to help make their cookie cutter pop star sound different from all the others.) IMHO. YMMV.
Vladimir Vassilevsky wrote:> > > Dirk Bruere at NeoPax wrote: > > >>> It turns out that it is absolutely unnecessary to have 30 biquad >>> sections; somewhat 7-8 sections will do quite well for pretty much >>> any practical case. >> >> >> Except where the "practical case" is a graphics equaliser in the home >> or studio. > > Let's wait till you will grow wiser. I will keep you plonked you until > then, OK? > > VLV >I know you - you're Phil Allison! -- Dirk http://www.transcendence.me.uk/ - Transcendence UK Remote Viewing classes in London
robert bristow-johnson wrote:> On Dec 10, 9:13 pm, Jerry Avins <j...@ieee.org> wrote: >> robert bristow-johnson wrote: >>> ... (a.k.a. "bandaxall") ... >> Should that be "Baxendall" or is that something else? >> > > no, you're virtually correct, Jerry: > > http://www.schmarder.com/radios/tech/tone.htm > > but it's amazing how many google hits you get with "bandaxall" and get > references to guitar amp tone controls. > > anyway, i misused the term. i first heard it in reference to the > standard *shelving* filters, not peaking EQ, but i swapped it in my > memory for lack of a fresh reference.Well, I built my first James circuit around i952. The response has "lumps": if you set the bass control to full boost, there's a slight dip just above the frequency where the boost begins. With full cut, there's a slight dip. The same action is reflected in the treble control. You'll see it again if you convert the basic circuit to a feedback (i.e. Baxendall) control. The effect isn't mitigated by separating the base and treble sections by a buffer stage. Around 1960, I showed how to eliminate the effect by using center-tapped pots and connecting the sliders to the center taps. Although it nearly mimics a two-break circuit -- start of slope/end of slope -- it is actually a four-break circuit with one pole /nearly/ canceling one of the zeros. The further from flat the control is set, the more the cancellation is upset. Tying slider to the center tap keeps pole and zero aligned. I doubt that anyone alive can gear the dip, but I can measure it, so my heart rejoices when I know it's gone. :-) The pictures in the cited article is a common cheat; it doesn't show a lump. You'll see it clearly with one control set to flat and the other to full boost (or cut). Jerry -- Engineering is the art of making what you want from things you can get. �����������������������������������������������������������������������
Reply by ●December 13, 20072007-12-13
> Well, if you find a way to do it let me know because I am trying to create > a low noise third octave graphics equalizer. Hence my other question to > the NG about the overhead in doing 64 bit v 32 bit float on SHARC. I could > code it and measure it but was hoping somebody could give me a rough > estimate so I could know whether it's worth the effort.Dirk, I think I should have replied on your other thread, but here it goes anyway: Why do not you use the 40 bit floating point in SHARC? This would be NO overhead at all, still you get 32 bits precision (mantissa) and 8 bit exponent. Regards, -- Jaime Andres Aranguren C. SanJaaC Electronics Soluciones en DSP www.sanjaac.com -- Posted via a free Usenet account from http://www.teranews.com
