Hi, i'm relatively new to dsp and matlab.I currently have 2 waveforms read into Matlab from my oscilloscope,for example waveform A and waveform B. I want to to perform a search for a similiar match of waveform A in waveform B. I believe its poossible to do this using the xcorr function in matlab but I'm having difficulties in getting this to work. I want to plot my results so that a "correlation spike" indicates the place in waveform B where a match occurs.Any suggestions please? Thanks John
cross correlation
Started by ●November 21, 2007
Reply by ●November 21, 20072007-11-21
On Nov 21, 12:41 pm, "john1985" <murray_1...@hotmail.com> wrote:> Hi, > i'm relatively new to dsp and matlab.I currently have 2 waveforms read > into Matlab from my oscilloscope,for example waveform A and waveform B. I > want to to perform a search for a similiar match of waveform A in waveform > B. I believe its poossible to do this using the xcorr function in matlab > but I'm having difficulties in getting this to work. I want to plot my > results so that a "correlation spike" indicates the place in waveform B > where a match occurs.Any suggestions please? > Thanks > JohnThe xcorr function is straightforward. Here is a Matlab m-file code snippet: load waveform.mat; %load waveform load crossWave.mat; %loads pattern to cross correlate against into "crossWave" corr = xcorr(waveform, crossWave); % cross correlates waveform to crossWave figure; plot(waveform); hold on; plot(corr((length(waveform) - length(crossWave)) +1:length(corr)),'r'); hold off; title('Correlation Detect');
Reply by ●November 23, 20072007-11-23
On Nov 21, 1:41 pm, "john1985" <murray_1...@hotmail.com> wrote:> Hi, > i'm relatively new to dsp and matlab.I currently have 2 waveforms read > into Matlab from my oscilloscope,for example waveform A and waveform B. I > want to to perform a search for a similiar match of waveform A in waveform > B. I believe its poossible to do this using the xcorr function in matlab > but I'm having difficulties in getting this to work. I want to plot my > results so that a "correlation spike" indicates the place in waveform B > where a match occurs.Any suggestions please? > Thanks > JohnThere are spikes and then there are spikes. Periodic signals (of the same period) will give you a periodic cross correlation. Try using xcorr on your reference signal to get an idea of what you can expect to see.
Hello, here... http://www.dsprelated.com/showarticle/26.php .. and here ... http://www.elisanet.fi/mnentwig/webroot/fit_signal/index.html I have some code that probably does exactly what you want, with subsample accuracy. For someone who wants to use it as a "black box" (without understanding the gory details), one could explain as follows: It finds the timing offset and scaling coefficient between two cyclic signals, that gives the best match in a least squares sense (the "energy" of the residual sum((sig1-sig2_scaled_and_shifted)^2) is minimized. Hope that's useful. There is BTW crosscorrelation inside, implemented via FFT. -mn
