Been looking at the ADI library, specifically fir_decima FIR-based decimation filter Synopsis #include <filter.h> float *fir_decima (const floatinput[], floatoutput[], const float pmcoefficients[], floatdelay[], intnum_output_samples, intnum_coeffs, intdecimation_index); Description The fir_decima function implements a finite impulse response (FIR) filter defined by the coefficients and the delay line that are supplied in the call of fir_decima. The function produces the filtered response of its input data and then decimates. The size of the output vector output is specified by the argument num_output_samples, which specifies the number of output samples to be input should contain generated. The input vector input should contain decimation_index*num_output_samples samples, where decimation_index represents the decimation index. What is the relationship between the number of input and output samples and ticksize, since the numbers are different? Dirk
ADI decimation function
Started by ●November 22, 2007
