linking filters to its basic concept in delays
Started by inblo0m ●November 23, 2007
hi,
im new here and i would like to ask some questions about this topic;
linking filters to its basic concept in delays. are there any notes that i
can get from you guys? in the net? any theory about it? if there is, can
you share it? thank you so much...;)
inblo0m wrote:
> hi, > > im new here and i would like to ask some questions about this topic; > linking filters to its basic concept in delays. are there any notes that i > can get from you guys? in the net? any theory about it? if there is, can > you share it? thank you so much...;) > >
From a fellow newbie, the short answer will be yes. Some useful links are: http://www.bdti.com/faq/dsp_faq.htm http://www.dspguide.com/ http://www.dspguru.com/info/tutor/index.htm http://www.bores.com/courses/intro/ They should assist you in rephrasing your question.
Taking a stab in the dark, there might be two directions you could look at
1) an "analog" (continuous-time) filter is described by its impulse
response
2) an "analog" (continuous-time) signal can be represented by a series of
samples
Combining 1) and 2) leads to finite impulse response (FIR) filters.
-mn
PS: Using the word "analog" as above is forbidden without a valid permit
(i.e. having passed the Turing test)
Check out Leander: "On the relation between the wavefront speed and the group velocity concept" The Journal of the Acoustical Society of America, Volume 100, Issue 6, December 1996, pp.3503-3507 The author discusses various concepts relating to wave speed in acoustic media, where the maths is very similar to time delays through a filter. "Group velocity" in acoustics corresponds directly to "group delay" in a filter, and similar for "phase velcity" and "phase delay." Rune
On 23 Nov, 14:58, "mnentwig" <mnent...@elisanet.fi> wrote:
> Taking a stab in the dark, there might be two directions you could look at > 1) an "analog" (continuous-time) filter is described by its impulse > response > 2) an "analog" (continuous-time) signal can be represented by a series of > samples > > Combining 1) and 2) leads to finite impulse response (FIR) filters.
You are *that* sure the OP is a troll? Rune
Nope, sorry. My answer was genuine.
Maybe you do understand the question better than I do, though.
-mn
Rune Allnor wrote:
(snip)
> The author discusses various concepts relating to wave speed in > acoustic media, where the maths is very similar to time delays > through a filter. "Group velocity" in acoustics corresponds directly > to "group delay" in a filter, and similar for "phase velcity" and > "phase delay."
I would say "group delay" is distance divided by "group velocity", similar for "phase delay" and "phase velocity." That makes them inversely proportional. -- glen
On 24 Nov, 01:36, glen herrmannsfeldt <g...@ugcs.caltech.edu> wrote:
> Rune Allnor wrote: > > (snip) > > > The author discusses various concepts relating to wave speed in > > acoustic media, where the maths is very similar to time delays > > through a filter. "Group velocity" in acoustics corresponds directly > > to "group delay" in a filter, and similar for "phase velcity" and > > "phase delay." > > I would say "group delay" is distance divided by "group velocity", > similar for "phase delay" and "phase velocity."
Careful! Stating the obvious would amount to belittle the OP's intelligence. I was accused of that only a couple of days ago. Rune
thank you so much guys...;)
Louie, I've read several responses from other people who seem to understand (or think they understand) what your question means. I don't. I can't guess what "the basic concept [of a filter] in delays" might mean to you. I don't want to imply that it has no meaning; it just doesn't mean anything to me. Maybe the question is based on an assumption that I don't recognize. Would you mind expanding on what you're trying to grok? Jerry -- Engineering is the art of making what you want from things you can get.
