Does MP3 allow uncompressed audio to be stored with 1:1 ratio ? Kind regards, Yuri
Min MP3 compression ratio
Started by ●November 25, 2007
Reply by ●November 25, 20072007-11-25
ytregubov@yahoo.com wrote:> Does MP3 allow uncompressed audio to be stored with 1:1 ratio ? >No. Mpeg 1 Layer 3 specifies the max. bitrate of 320kbps. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
ytregubov@yahoo.com wrote:> yes, that's the right term, "max bitrate"You should keep in mind that Layer 2 audio performs better at that high bitrates than Layer 3. So in general at 256kbps and above, Mpeg 1 Layer 2 is the better choice. At 384kbps the same applies to Layer 2 versus Layer 1. The latter is nearly lossless in the most cases. Marcel
