time difference between two acoustic sine waves
Started by rashdk ●November 26, 2007
i have two physically separated acoustic sensors to pick up acoustic
signals..when they pick up a signal , due to differences in distance
covered , there is a phase difference for the corresponding time delay..As
of now I am using correlation in time domain to calculate the time delay
..But i want to explore the method of Zero crossing for the same or fine
tune the correlation method..Can someone please guide me on this...thanks
and regards
dks
On Nov 26, 10:37 am, "rashdk" <sing...@rediffmail.com> wrote:
> i have two physically separated acoustic sensors to pick up acoustic > signals..when they pick up a signal , due to differences in distance > covered , there is a phase difference for the corresponding time delay..As > of now I am using correlation in time domain to calculate the time delay > ..But i want to explore the method of Zero crossing for the same or fine > tune the correlation method..Can someone please guide me on this...thanks > and regards > > dks
The only place that I know of where a clipped correlator works better is when your noise is highly impulsive, like under deep pack ice. If you really want to look at clipped correlators, you should look at old JASA stuff, late 50's to mid 60's.
In time domain you can only locate a correlation peak or a zero crossing to within one sample period, T. If you want better location in time you might want to try to estimate the slope of the phase of the cross spectrum. You would need a broad-band signal for that, though. Rune
dks Once you have properly sampled your signals, you can use those samples to reconstruct the signals at other points in time. If you resample your signals at smaller intervals, picking the sample time when the signal is nearest to zero will give the opportunity to pick at smaller intervals. This can reduce the error in estimation of zero crossing time due to the time quantization of your original samples. It will not reduce the error in estimation of zero crossing time due to limited signal to noise ratio of your original samples. Time samples at smaller intervals can also be used to produce correlation estimates at smaller intervals. This can reduce the error in estimation of correlation peak time due to the time quantization of your original samples. It will not reduce the error in estimation of correlation peak time due to limited signal to noise ratio of your original samples. There are also methods that can be used to estimate the location of zero crossings (or correlation peaks) from samples near the zero crossing (or peak). These usually require additional knowledge of the signal. For example,if you know the signal is a pure large sine wave, samples near the zero crossing may be approximately linear. For correlation peaks a parabolic interpolation might be used. Transform domain techniques exist that can provide efficient implementations of the resampling. Ask google. Good luck, Dale B. Dalrymple http://dbdimages.com http://stores.lulu.com/dbd
On 27 Nov, 07:03, dbd <d...@ieee.org> wrote:
> Transform domain techniques exist that can provide efficient > implementations of the resampling.
You wouldn't happen to be thinking about something like this: %%%%%%%%%%%%%%%%%%%%%%%%%%%%%% T1 = 1; P = 8; T2 = T1/P; N = 8; t = 0:(N-1)*T1; f=1/8; % with this f the results look nice %f = 1/10; % with this f the results look...? s = sin(2*pi*f*t); S = fft(s); M = P*N-floor(N/2)-1; Si = [S(1:floor(N/2)+1),zeros(1,M)]; si = 2*real(ifft(Si)); ti = (0:N*P-1)*T2; clf s1=stem(t,s); set(s1,'color','blue') hold on s2=stem(ti,si);set(s2,'color','red') %%%%%%%%%%%%%%%%%%%%%%%%%% Rune
On Nov 27, 12:21 am, Rune Allnor <all...@tele.ntnu.no> wrote:
> On 27 Nov, 07:03, dbd <d...@ieee.org> wrote: > > > Transform domain techniques exist that can provide efficient > > implementations of the resampling. > > You wouldn't happen to be thinking about something like this: > > %%%%%%%%%%%%%%%%%%%%%%%%%%%%%% > T1 = 1; > P = 8; > T2 = T1/P; > > N = 8; > t = 0:(N-1)*T1; > f=1/8; % with this f the results look > nice > %f = 1/10; % with this f the results look...? > > s = sin(2*pi*f*t); > > S = fft(s); > M = P*N-floor(N/2)-1; > Si = [S(1:floor(N/2)+1),zeros(1,M)]; > si = 2*real(ifft(Si)); > ti = (0:N*P-1)*T2; > > clf > s1=stem(t,s); set(s1,'color','blue') > hold on > s2=stem(ti,si);set(s2,'color','red') > > %%%%%%%%%%%%%%%%%%%%%%%%%% > > Rune
Rune I would never call you google. Or do dks' homework. Dale B. Dalrymple
While it's topic may seem completely different from what you are asking for
you should have a look at
tda.jpl.nasa.gov/progress_report/42-121/121G.pdf
and specially at the simple math presented in the appendices A, B and C.
Regards
Ulrich Bangert
"rashdk" <singhdk@rediffmail.com> schrieb im Newsbeitrag
news:9uqdncgm9uPYddfanZ2dnUVZ_saknZ2d@giganews.com...
> i have two physically separated acoustic sensors to pick up acoustic > signals..when they pick up a signal , due to differences in distance > covered , there is a phase difference for the corresponding time delay..As > of now I am using correlation in time domain to calculate the time delay > .But i want to explore the method of Zero crossing for the same or fine > tune the correlation method..Can someone please guide me on this...thanks > and regards > > dks
I have some code for the correlation method here:
http://www.dsprelated.com/showarticle/26.php
Not sure if it qualifies as "fine-tuned", but it reaches accuracy of
10e-10 sample time if the signal is noise free.
-mn
On 28 Nov, 12:02, "mnentwig" <mnent...@elisanet.fi> wrote:
> I have some code for the correlation method here: > > http://www.dsprelated.com/showarticle/26.php > > Not sure if it qualifies as "fine-tuned", but it reaches accuracy of > 10e-10 sample time if the signal is noise free.
Very intersting page. You probably don't know it (or you would have referenced it already) but this stuff is treated in Bendat & Piersol: "Random Data", Wiley, 20090, which is a classic in data analysis. Rune
>You probably don't know it (or you >would have referenced it already) but this stuff is treated in
Thanks for the reference, and no, I didn't know it. I'll add it to the blog. Cheers Markus
