I've heard that there is a way to essentially double the sampling rate of a complex input signal into a real FFT by alternating the real and imaginary signals in time (given that the I and Q are sampled independently)? Does this really work? If it does, are there only certain conditions (relationships between sample time and frequency) where it does? Thanks Much!
Nyquist and the Complex-Real FFT
Started by ●November 28, 2007
Reply by ●November 28, 20072007-11-28
On Wed, 28 Nov 2007 10:20:58 -0600, vanlansl wrote:> I've heard that there is a way to essentially double the sampling rate of a > > complex input signal into a real FFT by alternating the real and imaginary > > signals in time (given that the I and Q are sampled independently)? Does > > this really work? If it does, are there only certain conditions > > (relationships between sample time and frequency) where it does? > > Thanks Much!You could, if I'm not mistaken, use a real FFT that way, then peel out what would be the result of a complex FFT from the result. But I suspect that you'd use up just as much or more computation time than doing a complex FFT. You should also be able to do a real FFT on the real part, then a real FFT on the imaginary part, and combine the answers. No, I'm not sure what's the right way to do this off the top of my head, but if you start with the properties of the Fourier transform you can figure it out. -- Tim Wescott Control systems and communications consulting http://www.wescottdesign.com Need to learn how to apply control theory in your embedded system? "Applied Control Theory for Embedded Systems" by Tim Wescott Elsevier/Newnes, http://www.wescottdesign.com/actfes/actfes.html
On Nov 28, 12:55 pm, Tim Wescott <t...@seemywebsite.com> wrote:> On Wed, 28 Nov 2007 10:20:58 -0600, vanlansl wrote: > > I've heard that there is a way to essentially double the sampling rate of a > > > complex input signal into a real FFT by alternating the real and imaginary > > > signals in time (given that the I and Q are sampled independently)? Does > > > this really work? If it does, are there only certain conditions > > > (relationships between sample time and frequency) where it does? > > > Thanks Much! > > You could, if I'm not mistaken, use a real FFT that way, then peel out > what would be the result of a complex FFT from the result. > > But I suspect that you'd use up just as much or more computation time than > doing a complex FFT.there *are* real to complex FFTs that take N *real* samples going in and return N/2 complex values (where the Hermitian symmetry is implied) and i thought they were meant to be more efficient than an N point complex FFT where you started with all of the imaginary parts zeroed and ended up with that conjugate symmetry explicit (thus a little redundancy). for the first case, since the DC and Nyquist components *have* to be purely real, what they usually do is put the real part of the Nyquist component in the imaginary part of X[0] (which would otherwise be known to be zero) so they can pack all of the information into N/2 complex values.> > You should also be able to do a real FFT on the real part, then a real FFT > on the imaginary part, and combine the answers. No, I'm not sure what's > the right way to do this off the top of my head,i've gone through it once here on comp.dsp. it was laborious and long ago. imagine a regular old N/2 point complex-in, complex-out DFT. define the input signal such that the real parts of the input are the even samples of an N point real sequence and that the imaginary parts are the odd samples of the N point real sequence and "go to town" with it. then see what you have to do to untangle the results you want from it. have fun. r b-j
"vanlansl" <svan2@excite.com> writes:> I've heard that there is a way to essentially double the sampling rate of a > complex input signal [...]So you'd like to interpolate a complex signal by two? I'm sorry - I'm not sure what your question is, and I'm not sure Tim's or Robert's answer addresses it. -- % Randy Yates % "How's life on earth? %% Fuquay-Varina, NC % ... What is it worth?" %%% 919-577-9882 % 'Mission (A World Record)', %%%% <yates@ieee.org> % *A New World Record*, ELO http://www.digitalsignallabs.com
On Nov 28, 2:28 pm, Randy Yates <ya...@ieee.org> wrote:> "vanlansl" <sv...@excite.com> writes: > > I've heard that there is a way to essentially double the sampling rate of a > > complex input signal [...] > > So you'd like to interpolate a complex signal by two? > > I'm sorry - I'm not sure what your question is, and I'm not sure Tim's or > Robert's answer addresses it. > -- > % Randy Yates % "How's life on earth? > %% Fuquay-Varina, NC % ... What is it worth?" > %%% 919-577-9882 % 'Mission (A World Record)', > %%%% <ya...@ieee.org> % *A New World Record*, ELOhttp://www.digitalsignallabs.comI've seen this more often the other way, from real to half frequency complex by making even samples real, odd samples imaginary. Adjacent input samples become a complex sample and alternate complex samples are multiplied by -1. This is based on complex demodulation by one forth the sample frequency where the cosine terms are 1 0 -1 0... and the sine terms are 0 1 0 -1... and the adjacent samples are summed as a crude desampling filter. The signal should be prefiltered to a bandpass that is much narrower than the Nyquist limit. Try this process in reverse. Dale B. Dalrymple http://dbdimages.com http://stores.lulu.com/dbd
Reply by ●November 29, 20072007-11-29
On Nov 28, 10:50 pm, dbd <d...@ieee.org> wrote: ...> The signal should be prefiltered to a bandpass that > is much narrower than the Nyquist limit.hmmmm. the thing i was thinking about was "merely" using an N/2 complex-in, complex-out DFT to perform an N-point DFT with real input and where the output only contains half of the conjugate symmetric output that you would get with a regular N-point DFT. now, to do the "untangling", you would need an addition N/4 twiddle factors that the N/2 point complex DFT did not use (but a regular N-point *does* use), but there was no restriction of the bandwidth or frequency content of the input data. the only restriction was that the imaginary part of each sample is assumed zero (and not granted any space). r b-j
vanlansl wrote:> I've heard that there is a way to essentially double the sampling rate of a > complex input signal into a real FFT by alternating the real and imaginary > signals in time (given that the I and Q are sampled independently)? Does > this really work? If it does, are there only certain conditions > (relationships between sample time and frequency) where it does? > > Thanks Much! > >Sure. The only tool you need to understand this trick is linear superposition. i.e. f + K*g <==> F + K*G ^^^^ ^^^^^ time domain frequency domain Split the complex vector into the real part and the imaginary part ( in the above nomenclature: f==real part, g=image part, K=j ) so FFT(real + j*imag) == FFT(real) + j*FFT(imag) One caveat: most real FFTs return only the half-spectrum, since the other half is conjugate symmetric. You'll need both halves. -- Mark
