hi all DSP giants and experts, i am struggling on one problem..lemme share with you people.. Thanks in advance for all answers its like this i have OFDM Symbols say 256 ifft which has a cylic prefix of 32 say a system is taking fft at some sample offset..i need to know..at what sample offset from start. the FLOW is like this step1-========================================== assume there are 5 OFDM symbols (so overall 5*288 complex samples) ----------------------------------------------------------------------------------------- | CP SYM | CP SYM | CP SYM | CP SYM | CP SYM | | 32 256 | 32 256 | 32 256 | 32 256 | 32 256 | ---------------------------------------------------------------------------------------- step2 ========================================= assume a front end is picking up fft at say X samples before the actual start of the SYM example...if X = 11 so the fft window will take fft[11(CP)+245(SYM)] (means it is picking up 11 samples from CP and remaining 245 samples from OFDM SYMbol making it overall 256 and then it will take FFT window on the extracted 256 complex samples) step3========================================== now if i want to find out what is that X options which i have are, go for phaseramp stuff to decode what is that X.. QUESTION====================================== is there any ROBUST method apart from PHASERAMP related Estimation method which will give me answer..lemme clarify again..i dont want ..any phaseramp..related method to find out that.. thanks in advance again particlereddy
How can i verify how many samples have i skipped (OFDM QUESTION)
Started by ●December 4, 2007
Reply by ●December 4, 20072007-12-04
onemore small clarification.. plz understand that the frontend is like blackbox to me..donno what is happening inside thanks again particlereddy On Dec 4, 8:09 pm, "PARTICLEREDDY (STRAYDOG)" <particlere...@gmail.com> wrote:> hi all DSP giants and experts, > i am struggling on one > problem..lemme share with you people.. > > Thanks in advance for all answers > > its like this > > i have OFDM Symbols say 256 ifft which has a cylic prefix of 32 > > say a system is taking fft at some sample offset..i need to know..at > what sample offset from start. > > the FLOW is like this > > step1-========================================== > > assume there are 5 OFDM symbols (so overall 5*288 complex samples) > ------------------------------------------------------------------------------------------ > | CP SYM | CP SYM | CP SYM | CP SYM | CP SYM | > | 32 256 | 32 256 | 32 256 | 32 256 | 32 256 > | > ----------------------------------------------------------------------------------------- > > step2 ========================================= > > assume a front end is picking up fft at say X samples before the > actual start of the SYM > > example...if X = 11 so the fft window will take fft[11(CP)+245(SYM)] > (means it is picking up 11 samples from CP and remaining 245 samples > from OFDM SYMbol making it overall 256 and then it will take FFT > window on the extracted 256 complex samples) > > step3========================================== > now if i want to find out what is that X > > options which i have are, go for phaseramp stuff to decode what is > that X.. > > QUESTION====================================== > > is there any ROBUST method apart from PHASERAMP related Estimation > method which will give me answer..lemme clarify again..i dont > want ..any phaseramp..related method to find out that.. > > thanks in advance again > particlereddy
