Satellite Range
Started by Philip Newman April 28, 2004
I know this isn't directly linked with DSP, but it is telecommunications,
and someone should know the answer to this!
Assume a ground-station has a longitude of 5.17degW and a latitude of
50.05degN
There is an Atlantic Ocean Satellite with longitude 30.00degW.
How can I calculate the range of the satellite from the earth station?
I have had a look at some literature, but nothing seems to be what I need.
What equations do I need?
Phil
Are you just trying to find the distance between the two points?  Knowing
the radius of the earth and the geosych orbit, you can find 3D polar coords
of the two points, using the center of the earth as the origin of the polar
coord system.  Then you can convert those polar coords to cartesian coords.
This is pretty easy and you can find the conversions in a calculus book.
Then you have two cartesian vectors; subtract one from the other and find
the magnitude of the result.
-Kevin
"Philip Newman" <nojunkmail@ntlworld.com> wrote in message
news:atRjc.79$RI.28@newsfe1-win...
> I know this isn't directly linked with DSP, but it is telecommunications, > and someone should know the answer to this! > > Assume a ground-station has a longitude of 5.17degW and a latitude of > 50.05degN > There is an Atlantic Ocean Satellite with longitude 30.00degW. > > How can I calculate the range of the satellite from the earth station? > > I have had a look at some literature, but nothing seems to be what I need. > What equations do I need? > > Phil > >
"Kevin Neilson" <kevin_neilson@removethiscomcast.net> wrote in message
news:jCRjc.6205$RE1.758298@attbi_s54...
> Are you just trying to find the distance between the two points? Knowing > the radius of the earth and the geosych orbit, you can find 3D polar
coords
polar
coords.
> This is pretty easy
go on then!
> and you can find the conversions in a calculus book. > Then you have two cartesian vectors; subtract one from the other and find > the magnitude of the result. > -Kevin
thanks Phil
> > "Philip Newman" <nojunkmail@ntlworld.com> wrote in message > news:atRjc.79$RI.28@newsfe1-win... > > I know this isn't directly linked with DSP, but it is
telecommunications,
> > and someone should know the answer to this! > > > > Assume a ground-station has a longitude of 5.17degW and a latitude of > > 50.05degN > > There is an Atlantic Ocean Satellite with longitude 30.00degW. > > > > How can I calculate the range of the satellite from the earth station? > > > > I have had a look at some literature, but nothing seems to be what I
need.
> > What equations do I need? > > > > Phil > > > > > >
Philip,
Why not just call Goonhilly and ask them? Or do you have to show your
workings in your homework answer? ;-)
Cheers, Syms.
"Symon" <symon_brewer@hotmail.com> wrote in message
news:c6op0i$dqv33$1@ID-212844.news.uni-berlin.de...
> Philip, > Why not just call Goonhilly and ask them? Or do you have to show your > workings in your homework answer? ;-) > Cheers, Syms. > >
Someone knows their Satellites! I do believe I get extra marks for showing workings! I think I got it, not sure though. Thanks Phil
"Philip Newman" <nojunkmail@ntlworld.com> writes:
There's not enough information here to compute this geometrically, is there? I'm not up on these coordinate systems, but is it not true that "longitude 30.00 degrees West" only specifies the longitude of the satellite and not the altitude? Thus the range cannot be computed. Perhaps they want you to be a little creative with a respone like "ping it and look for the time of return?" -- Randy Yates Sony Ericsson Mobile Communications Research Triangle Park, NC, USA randy.yates@sonyericsson.com, 919-472-1124
"Randy Yates" <randy.yates@sonyericsson.com> wrote in message
news:xxphdv4t0gj.fsf@usrts005.corpusers.net...
> "Philip Newman" <nojunkmail@ntlworld.com> writes: > > > I know this isn't directly linked with DSP, but it is
telecommunications,
need.
> > What equations do I need? > > There's not enough information here to compute this geometrically, is
there?
> I'm not up on these coordinate systems, but is it not true that "longitude > 30.00 degrees West" only specifies the longitude of the satellite and not > the altitude? Thus the range cannot be computed. > > Perhaps they want you to be a little creative with a respone like "ping it > and look for the time of return?" > -- > Randy Yates > Sony Ericsson Mobile Communications > Research Triangle Park, NC, USA > randy.yates@sonyericsson.com, 919-472-1124
I assume that the latitude of the satellite is zero - that is it is in line with the earths equator, and the point of origin is the earth's centre. Phil
telecommunications,
need.
there?
I assumed if the longitude was given without the latitude, this implies it's geosynchronous and then the latitude and altitude are known. It is a big assumption, though. -Kevin
"Randy Yates" <randy.yates@sonyericsson.com> wrote in message > Perhaps they
Sounds like it could be a job for a Barometer.... Cheers, Syms.
Assuming the satellite is in geostationary orbit at 0 deg latitude and 35786 km altitude, the azimuth, elevation and range are give below: Azimuth(deg) Elevation(deg) Range(m) 148.8678406 27.99588761 38784989.47 These results come from the freely-available ArrayTran software application. OUP
