On Dec 23, 11:35 am, "ssohaib" <ssoh...@gmail.com> wrote:> Good to see your reply. Could you plz eleborate how can i quntize the I and > Q seperatly. Lets spoose after noise we have some thing like > 0.807-0.984j. How can i qunatize 0.807 and -0.984j in to 8 levels? > > Waiting.I think you mentioned Matlab, in which case the function 'vitdec' is what you will probably use. There are examples of how to use it on www.mathworks.com, just type 'vitdec' into the search box. You have specifiy the soft I and Q values as K bit integers from 0 to (2^K)-1. Let's say K is 3. Then you must map the floating point I and Q samples to integers in [0,7]. If you expect a range of floating point values from -sqrt(2) to +sqrt(2), with nominal values -sqrt(2)/2 and +sqrt(2)/ 2, then the soft decisions would be: Isd = 4+floor(4*I/sqrt(2)) Qsd = 4+floor(4*Q/sqrt(2)) Happy Holidays, John
Soft Decision Viterbi Decoding?
Started by ●December 19, 2007
Reply by ●December 23, 20072007-12-23
Reply by ●December 24, 20072007-12-24
Hi, Thanks for your kind reply. Could you please explain me if I quantize real and imaginary part of my received coded QPSK separately how can I use these 3 bits from real and 3 bits from imaginary part in Viterbi soft decoding? P.S. I have looked on internet for it but couldn’t get any answer, so if you know any website kindly forward its address. Also I would be grateful if you send me any solved example of Viterbi decoding of QPSK coded signal. Bye
On Dec 24, 8:32 am, "ssohaib" <ssoh...@gmail.com> wrote:> Hi, > Thanks for your kind reply. Could you please explain me if I quantize real > and imaginary part of my received coded QPSK separately how can I use these > 3 bits from real and 3 bits from imaginary part in Viterbi soft decoding? > > P.S. I have looked on internet for it but couldn't get any answer, so if > you know any website kindly forward its address. Also I would be grateful > if you send me any solved example of Viterbi decoding of QPSK coded > signal. > > ByeJust feed them into the decoder: Isd Qsd Isd Qsd ... etc John
Reply by ●December 25, 20072007-12-25
Hi, I would be grateful if you please explain me how do u get these following expressions: Isd = 4+floor(4*I/sqrt(2)) Qsd = 4+floor(4*Q/sqrt(2)) Thanks.
On Dec 25, 8:26 pm, "ssohaib" <ssoh...@gmail.com> wrote:> Hi, > I would be grateful if you please explain me how do u get these following > expressions: > > Isd = 4+floor(4*I/sqrt(2)) > Qsd = 4+floor(4*Q/sqrt(2)) > > Thanks.I don't care to spoon feed this to you any more. I suggest you hire a tutor. John
