Hello, Supose you need to compress two independent video streams, each one being 4-CIF (704 x 480) at 15 fps for a surveillance application, and that they (both) need to be steramed thru the same network but the max bitrate that you have for that streaming function is 2 Mbps. Which one of the following codecs would you use? - H.264 Baseline Profile - MPEG-4 Simple Profile - MPEG-4 Advanced Simple Profile Is the max bit rate dependent on the processor used for compression (or FPGA or whatever), or is it dependent on the codec itself? Regards, -- Jaime Andres Aranguren C. SanJaaC Electronics Soluciones en DSP www.sanjaac.com -- Posted via a free Usenet account from http://www.teranews.com
H.264 vs. MPEG-4 for Surveillance
Started by ●December 18, 2007
