Hi There, Is there a difference between the two algoririthms regarding performance? Do both the algorithms correct all correctable errors and erasures (d_{min} >= 2s + e, s - errors, e - erasures)? When would one use the one algorithm instead of the other? Kind Regards, Jaco
Reed-Solomon decoding: Euclidean vs Massey-Berlekamp
Started by ●December 20, 2007
Reply by ●December 20, 20072007-12-20
On Dec 20, 9:20 am, jaco.versf...@gmail.com wrote:> Hi There, > > Is there a difference between the two algoririthms regarding > performance? Do both the algorithms correct all correctable errors > and erasures (d_{min} >= 2s + e, s - errors, e - erasures)? > > When would one use the one algorithm instead of the other? > > Kind Regards, > JacoThe fact that the Reed-Solomon code can correct both errors and erasures simultaneously has to do with the code being maximum distance separable. Both algorithms can be used to the find error locator polynomials but the Euclidean (Sugiyama-Kasahara-Hirasawa-Namekawa) algorithm is much easier to understand, learn and teach, at least in my experience. There are claims that the Berlekamp-Massey is somewhat more computationally efficient but that may have to do with being much older and most programmers are lazy to rework something that already is doing a good enough job.
