>In a live audio streaming system, audio pops are caused by network >packet delay. How to smooth the sharp decay, and what stuff should be >filled in the empty buffer? >Are temporay mutes acceptable for your application? Sometimes you can size them so that they are so small a human may not easily detect it. For example keep a 100ms buffer between input and output and put a timer on your input. Once you determine the input pack is late (you define this) you can start appling a exponential mute (RC) to your outgoing samples. Since you have a 100ms in the pipe, you could adjust your rate so that it is attentuated to -80dB (assuming a full-scale input) at around 50ms. This time amount is key because anything less than ~30ms rate will be preceived as a pop. If the input packet comes back right after your mute is complete: you fill the buffer back up and start your unmute process after the buffer is full again. If you're lucky your packet delay is less than 50ms and the amplitude will drop temporarily and go back up to unity and hardly anyone will be able to distinguish that. Worst case is a several-hundred-ms mute which is a little annoying but far less discernable than a pop [my opinion]. Just an idea... - Jeff
Audio pops in live audio streaming system.
Started by ●December 23, 2007
Reply by ●December 26, 20072007-12-26
