Could anyone tell me if my understanding for the acronym of ICI is right or not? There are 2 types of ICI, one is Inter Carrier Interference which is caused by the frequency offset between transmitter and receiver in OFDM system, and another is Inter Code Interference which is caused by the Code Divison Multiplexing in OFDM-CDM system.
question of ICI in OFDM system
Started by ●December 26, 2007
Reply by ●December 26, 20072007-12-26
On Dec 26, 9:48�pm, "totohaha" <wuxian...@hotmail.com> wrote:> Could anyone tell me if my understanding for the acronym of ICI is right or > not? > > There are 2 types of ICI, one is Inter Carrier Interference which is > caused by the frequency offset between transmitter and receiver in OFDM > system, and another is Inter Code Interference which is caused by the Code > Divison Multiplexing in OFDM-CDM system.ICI - Inter Carrier Interference (Comes in OFDM) ICI Cancellation Methods are :- - Self Cancellation - Maximum Likelihood - KalmanFiltering ICI - Inter-Code Interference related with MC-CDMA (Comes in System based on OFDM - That is, at a bit higher level. MIMO Multicode MC- CDMA is problematic has two interferences, one from inter- code interference between the multicode under the multipath fading channel, and a second from inter-antenna interference caused from an independent stream of different antennas. ) Cancellation Methods include the following :- -multi-stage parallel interference cancellation (FD-MSPIC). -Partially Parallel Interference Cancellation (PPIC) algorithm (MC-CDMA - Multi-carrier code division multiple access is a multiple access technology used in telecommunication systems based on OFDM. - A variant of the mobile communication standard CDMA2000 ) Karthik Balaguru
Reply by ●December 28, 20072007-12-28
so I am concerned about the Inter-Code Cancellation. for example, if the transmitted x=[-1 -1 -1 +1] and walsh matrix as C=[1 1 1 1;1 -1 1 -1;1 1 -1 -1;1 -1 -1 1], and so the multiplexed signal s=C*x=[-2 -2 -2 2]. then after channel distortion, the received signal y=[-2.3 -1.5 -0.8 1.2]. how I should do the Inter-Code Cancellation?
