I have came across a so-called soft symbol mapper in OFDM system, which I understand it is modulation by soft values, but how to do it? for example, QPSK modulation will make [0 0] [0 1] [1 0] [1 1] to [-0.7071-0.7071i] [-0.7071+0.7071i] [+0.7071-0.7071i] [+0.7071+0.7071i], how about soft symbol mapper?
question about soft symbol mapper
Started by ●December 30, 2007
Reply by ●December 31, 20072007-12-31
anybody answer me?>I have came across a so-called soft symbol mapper in OFDM system, whichI>understand it is modulation by soft values, but how to do it? forexample,>QPSK modulation will make [0 0] [0 1] [1 0] [1 1] to [-0.7071-0.7071i] >[-0.7071+0.7071i] [+0.7071-0.7071i] [+0.7071+0.7071i], how about soft >symbol mapper? >
"totohaha" <wuxianguk@hotmail.com> wrote in message news:r46dnXdaDqH-eOranZ2dnUVZ_h2pnZ2d@giganews.com...> I have came across a so-called soft symbol mapper in OFDM system, which I > understand it is modulation by soft values, but how to do it? for example, > QPSK modulation will make [0 0] [0 1] [1 0] [1 1] to [-0.7071-0.7071i] > [-0.7071+0.7071i] [+0.7071-0.7071i] [+0.7071+0.7071i], how about soft > symbol mapper?Usually it is just a look up table. If the I and Q values are 16 bit, for example, a 4x32 memory can implement this function for you. Typically it is a dual port memory so that the values can be reloaded on one port while the data is processed on the other port. -Clark
"totohaha" <wuxianguk@hotmail.com> writes:> I have came across a so-called soft symbol mapper in OFDM system, which I > understand it is modulation by soft values, but how to do it? for example, > QPSK modulation will make [0 0] [0 1] [1 0] [1 1] to [-0.7071-0.7071i] > [-0.7071+0.7071i] [+0.7071-0.7071i] [+0.7071+0.7071i], how about soft > symbol mapper?Perhaps they're implementing some sort of predistortion? -- % Randy Yates % "And all that I can do %% Fuquay-Varina, NC % is say I'm sorry, %%% 919-577-9882 % that's the way it goes..." %%%% <yates@ieee.org> % Getting To The Point', *Balance of Power*, ELO http://www.digitalsignallabs.com
