hi, i am trying to use any dsp public peripheral(ex. McBsp1),in a DSP only configuration on OSK5912. but when ever i am loading my application, getting error like " can not run target CPU - processor timed out- reset emulator ". but applications with out using peripherals, is working fine. now my main doubt is can i use even dsp public peripherals also with out the intervention of GPP. can any one suggest me regarding this.
how to use McBsp (dsp only)OMAP5912
Started by ●December 31, 2007
Reply by ●December 31, 20072007-12-31
On Dec 31, 11:07�am, "sujitm_nist" <sujit.mahapa...@cranessoftware.com> wrote:> hi, > i am trying to use any dsp public peripheral(ex. McBsp1),in a DSP only > configuration on OSK5912. > but when ever i am loading my application, getting error like " can not > run target CPU - processor timed out- reset emulator ". > but applications with out using peripherals, is working fine. > > now my main doubt is can i use even dsp public peripherals also with out > the intervention of GPP. > > can any one suggest me regarding this.It has TMS320C55x and DSP stuffs are very similar to it w.r.t DSP part. What do you perform in the initialisation code ? How do you boot up ? How have you configured the interrupts ? What is the memor mapping ? These can help to find the location of problem. Karthik Balaguru
