OT Digital TV
Started by Jerry Avins ●January 3, 2008
Richard Owlett wrote:
> HardySpicer wrote: >> On Jan 4, 5:27 am, Jerry Avins <j...@ieee.org> wrote: >> >>> I was in a "warehouse" store recently where there were a few dozen TV >>> sets on display, fed in banks from three different canned feeds. All >>> suffered from ghost images and the ghosts from any one feed seemed >>> identical. Can there be digital ghosts? If yes, how? Were the ghosts >>> originally analog, then digitized? If yes, do producers of TV demos >>> typically do it so sloppily? >>> >>> Jerry >>> -- >>> Engineering is the art of making what you want from things you can get. >>> &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295; >> >> >> Multi-path doesn't care whether you transmit analog or digital. There >> are some digital systems that pretend to have fixed the problem but as >> you see it is still a major problem. OFDM is supposed to have it fixed >> but I hear that isn't true either. >> >> >> Hardy > > Does that imply that digital TV is no _more_ susceptible to multipath > related problems than analog. That is, currently having an acceptable > picture, will I have an acceptable picture without upgrading my antenna?
That depends on what you're willing to accept. If you now get a snowy and heavily ghosted picture, a digital transmission won't likely produce anything you can recognize. If your analog picture if fairly clean with only faint ghosts, you will probably get a perfect digital picture. Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
On Thu, 03 Jan 2008 18:01:04 -0500, Jerry Avins <jya@ieee.org> wrote:
>Richard Owlett wrote: >> HardySpicer wrote: >>> On Jan 4, 5:27 am, Jerry Avins <j...@ieee.org> wrote: >>> >>>> I was in a "warehouse" store recently where there were a few dozen TV >>>> sets on display, fed in banks from three different canned feeds. All >>>> suffered from ghost images and the ghosts from any one feed seemed >>>> identical. Can there be digital ghosts? If yes, how? Were the ghosts >>>> originally analog, then digitized? If yes, do producers of TV demos >>>> typically do it so sloppily? >>>> >>>> Jerry >>>> -- >>>> Engineering is the art of making what you want from things you can get. >>>> &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295; >>> >>> >>> Multi-path doesn't care whether you transmit analog or digital. There >>> are some digital systems that pretend to have fixed the problem but as >>> you see it is still a major problem. OFDM is supposed to have it fixed >>> but I hear that isn't true either. >>> >>> >>> Hardy >> >> Does that imply that digital TV is no _more_ susceptible to multipath >> related problems than analog. That is, currently having an acceptable >> picture, will I have an acceptable picture without upgrading my antenna? > >That depends on what you're willing to accept. If you now get a snowy >and heavily ghosted picture, a digital transmission won't likely produce >anything you can recognize. If your analog picture if fairly clean with >only faint ghosts, you will probably get a perfect digital picture.
I've bought a digital HDTV, and am trying to get off-air digital because I don't want to be ripped off by a cable company. I live in a valley about 25 miles south of St. Louis, MO. I'm at the north end of the valley. Without a directional antenna, I get stronger reflected TV signals from the south wall of the valley than I do right from the station, at about a 20 us delay, and there can be very strong ghosts, worse in winter than summer because the reflections aren't absorbed by foliage. The UHF stations are worst, and, unfortunately, all the digital broadcasts are in the UHF band. My experience with receiving digital signals is this - whenever I can get anything at all, the picture is perfect except for occasional breakup. I'm about as likely to get a good digital signal pointing the antenna at the reflected signal as at the direct signal. The problem is that there is multi-path either way, and while I can get a stable picture by re-aiming the antenna for each station in calm weather, if there is any wind, the multi-path is re-shuffled enough that the signal is lost every few seconds. There is no ghosting on digital, of course, since the video is compressed* and there's no simple mapping from signal delay to video delay, and there's no snow, per se. When I can get a stable signal, the picture is perfect and beautiful, and when it's actually a high definition source, it's really impressive. I'm thinking of buying a tower and putting a couple of antennas on it, maybe with a rotor. * In fact, several stations broadcast two to four channels on one UHF carrier. -- John
John O'Flaherty <quiasmox@yeeha.com> writes:
> On Thu, 03 Jan 2008 18:01:04 -0500, Jerry Avins <jya@ieee.org> wrote: > >>Richard Owlett wrote: >>> HardySpicer wrote: >>>> On Jan 4, 5:27 am, Jerry Avins <j...@ieee.org> wrote: >>>> >>>>> I was in a "warehouse" store recently where there were a few dozen TV >>>>> sets on display, fed in banks from three different canned feeds. All >>>>> suffered from ghost images and the ghosts from any one feed seemed >>>>> identical. Can there be digital ghosts? If yes, how? Were the ghosts >>>>> originally analog, then digitized? If yes, do producers of TV demos >>>>> typically do it so sloppily? >>>>> >>>>> Jerry >>>>> -- >>>>> Engineering is the art of making what you want from things you can get. >>>>> &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295; >>>> >>>> >>>> Multi-path doesn't care whether you transmit analog or digital. There >>>> are some digital systems that pretend to have fixed the problem but as >>>> you see it is still a major problem. OFDM is supposed to have it fixed >>>> but I hear that isn't true either. >>>> >>>> >>>> Hardy >>> >>> Does that imply that digital TV is no _more_ susceptible to multipath >>> related problems than analog. That is, currently having an acceptable >>> picture, will I have an acceptable picture without upgrading my antenna? >> >>That depends on what you're willing to accept. If you now get a snowy >>and heavily ghosted picture, a digital transmission won't likely produce >>anything you can recognize. If your analog picture if fairly clean with >>only faint ghosts, you will probably get a perfect digital picture. > > I've bought a digital HDTV, and am trying to get off-air digital > because I don't want to be ripped off by a cable company. I live in a > valley about 25 miles south of St. Louis, MO. I'm at the north end of > the valley. Without a directional antenna, I get stronger reflected TV > signals from the south wall of the valley than I do right from the > station, at about a 20 us delay, and there can be very strong ghosts, > worse in winter than summer because the reflections aren't absorbed by > foliage. The UHF stations are worst, and, unfortunately, all the > digital broadcasts are in the UHF band. > My experience with receiving digital signals is this - whenever I > can get anything at all, the picture is perfect except for occasional > breakup. I'm about as likely to get a good digital signal pointing the > antenna at the reflected signal as at the direct signal. The problem > is that there is multi-path either way, and while I can get a stable > picture by re-aiming the antenna for each station in calm weather, if > there is any wind, the multi-path is re-shuffled enough that the > signal is lost every few seconds. > There is no ghosting on digital, of course, since the video is > compressed* and there's no simple mapping from signal delay to video > delay, and there's no snow, per se. When I can get a stable signal, > the picture is perfect and beautiful, and when it's actually a high > definition source, it's really impressive. > I'm thinking of buying a tower and putting a couple of antennas on > it, maybe with a rotor.
How about a UHF horn? :) -- % Randy Yates % "I met someone who looks alot like you, %% Fuquay-Varina, NC % she does the things you do, %%% 919-577-9882 % but she is an IBM." %%%% <yates@ieee.org> % 'Yours Truly, 2095', *Time*, ELO http://www.digitalsignallabs.com
On Thu, 03 Jan 2008 21:17:00 -0500, Randy Yates <yates@ieee.org>
wrote:
>John O'Flaherty <quiasmox@yeeha.com> writes: > >> On Thu, 03 Jan 2008 18:01:04 -0500, Jerry Avins <jya@ieee.org> wrote: >> >>>Richard Owlett wrote: >>>> HardySpicer wrote: >>>>> On Jan 4, 5:27 am, Jerry Avins <j...@ieee.org> wrote: >>>>> >>>>>> I was in a "warehouse" store recently where there were a few dozen TV >>>>>> sets on display, fed in banks from three different canned feeds. All >>>>>> suffered from ghost images and the ghosts from any one feed seemed >>>>>> identical. Can there be digital ghosts? If yes, how? Were the ghosts >>>>>> originally analog, then digitized? If yes, do producers of TV demos >>>>>> typically do it so sloppily? >>>>>> >>>>>> Jerry >>>>>> -- >>>>>> Engineering is the art of making what you want from things you can get. >>>>>> &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295; >>>>> >>>>> >>>>> Multi-path doesn't care whether you transmit analog or digital. There >>>>> are some digital systems that pretend to have fixed the problem but as >>>>> you see it is still a major problem. OFDM is supposed to have it fixed >>>>> but I hear that isn't true either. >>>>> >>>>> >>>>> Hardy >>>> >>>> Does that imply that digital TV is no _more_ susceptible to multipath >>>> related problems than analog. That is, currently having an acceptable >>>> picture, will I have an acceptable picture without upgrading my antenna? >>> >>>That depends on what you're willing to accept. If you now get a snowy >>>and heavily ghosted picture, a digital transmission won't likely produce >>>anything you can recognize. If your analog picture if fairly clean with >>>only faint ghosts, you will probably get a perfect digital picture. >> >> I've bought a digital HDTV, and am trying to get off-air digital >> because I don't want to be ripped off by a cable company. I live in a >> valley about 25 miles south of St. Louis, MO. I'm at the north end of >> the valley. Without a directional antenna, I get stronger reflected TV >> signals from the south wall of the valley than I do right from the >> station, at about a 20 us delay, and there can be very strong ghosts, >> worse in winter than summer because the reflections aren't absorbed by >> foliage. The UHF stations are worst, and, unfortunately, all the >> digital broadcasts are in the UHF band. >> My experience with receiving digital signals is this - whenever I >> can get anything at all, the picture is perfect except for occasional >> breakup. I'm about as likely to get a good digital signal pointing the >> antenna at the reflected signal as at the direct signal. The problem >> is that there is multi-path either way, and while I can get a stable >> picture by re-aiming the antenna for each station in calm weather, if >> there is any wind, the multi-path is re-shuffled enough that the >> signal is lost every few seconds. >> There is no ghosting on digital, of course, since the video is >> compressed* and there's no simple mapping from signal delay to video >> delay, and there's no snow, per se. When I can get a stable signal, >> the picture is perfect and beautiful, and when it's actually a high >> definition source, it's really impressive. >> I'm thinking of buying a tower and putting a couple of antennas on >> it, maybe with a rotor. > >How about a UHF horn? :)
Then I might need a precision rotor... -- John
On Thu, 03 Jan 2008 22:08:56 -0600, John O'Flaherty
<quiasmox@yeeha.com> wrote:
>On Thu, 03 Jan 2008 21:17:00 -0500, Randy Yates <yates@ieee.org> >wrote: > >>John O'Flaherty <quiasmox@yeeha.com> writes: >> >>> On Thu, 03 Jan 2008 18:01:04 -0500, Jerry Avins <jya@ieee.org> wrote: >>> >>>>Richard Owlett wrote: >>>>> HardySpicer wrote: >>>>>> On Jan 4, 5:27 am, Jerry Avins <j...@ieee.org> wrote: >>>>>> >>>>>>> I was in a "warehouse" store recently where there were a few dozen TV >>>>>>> sets on display, fed in banks from three different canned feeds. All >>>>>>> suffered from ghost images and the ghosts from any one feed seemed >>>>>>> identical. Can there be digital ghosts? If yes, how? Were the ghosts >>>>>>> originally analog, then digitized? If yes, do producers of TV demos >>>>>>> typically do it so sloppily? >>>>>>> >>>>>>> Jerry >>>>>>> -- >>>>>>> Engineering is the art of making what you want from things you can get. >>>>>>> &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295; >>>>>> >>>>>> >>>>>> Multi-path doesn't care whether you transmit analog or digital. There >>>>>> are some digital systems that pretend to have fixed the problem but as >>>>>> you see it is still a major problem. OFDM is supposed to have it fixed >>>>>> but I hear that isn't true either. >>>>>> >>>>>> >>>>>> Hardy >>>>> >>>>> Does that imply that digital TV is no _more_ susceptible to multipath >>>>> related problems than analog. That is, currently having an acceptable >>>>> picture, will I have an acceptable picture without upgrading my antenna? >>>> >>>>That depends on what you're willing to accept. If you now get a snowy >>>>and heavily ghosted picture, a digital transmission won't likely produce >>>>anything you can recognize. If your analog picture if fairly clean with >>>>only faint ghosts, you will probably get a perfect digital picture. >>> >>> I've bought a digital HDTV, and am trying to get off-air digital >>> because I don't want to be ripped off by a cable company. I live in a >>> valley about 25 miles south of St. Louis, MO. I'm at the north end of >>> the valley. Without a directional antenna, I get stronger reflected TV >>> signals from the south wall of the valley than I do right from the >>> station, at about a 20 us delay, and there can be very strong ghosts, >>> worse in winter than summer because the reflections aren't absorbed by >>> foliage. The UHF stations are worst, and, unfortunately, all the >>> digital broadcasts are in the UHF band. >>> My experience with receiving digital signals is this - whenever I >>> can get anything at all, the picture is perfect except for occasional >>> breakup. I'm about as likely to get a good digital signal pointing the >>> antenna at the reflected signal as at the direct signal. The problem >>> is that there is multi-path either way, and while I can get a stable >>> picture by re-aiming the antenna for each station in calm weather, if >>> there is any wind, the multi-path is re-shuffled enough that the >>> signal is lost every few seconds. >>> There is no ghosting on digital, of course, since the video is >>> compressed* and there's no simple mapping from signal delay to video >>> delay, and there's no snow, per se. When I can get a stable signal, >>> the picture is perfect and beautiful, and when it's actually a high >>> definition source, it's really impressive. >>> I'm thinking of buying a tower and putting a couple of antennas on >>> it, maybe with a rotor. >> >>How about a UHF horn? :) > >Then I might need a precision rotor...
And you might get an even less reliable signal. Multipath helps if your equalizer is good enough to take advantage of it. Think of it this way, if 80% of the impinging power at the antenna location is in the strongest ray and 10% of the power is in the second strongest, an omnidirectional or wide-beam antenna that admits both, along with an equalizer that integrates them, will be able to exploit at -least- 90% of the available energy (plus however many other smaller rays can be integrated). If the high-gain antenna rejects all of the reflections but the strongest ray, i.e., you've done a good job of pointing the horn at the strongest reflection, if no other reflections come from that direction you only have 80% of the available energy to use. This might reduce the SNR enough to put you closer to or below the threshold of watchability. This illustrates the concept of multi-path gain, which is a good thing as long as the equalizer can make use of the collected rays. It could be that the equalizer in your receiver just isn't very good in dynamic conditions, like the wind blowing the reflectors and antenna around. Usually, though, the gain of a good directive antenna is higher than the loss in multipath gain, so a net gain in SNR can often be expected. It is usually not the case, though, that using a 10dB gain antenna, for example, in a rich multipath environment to replace an omni results in 10dB higher margin. It's often much, much less than that. Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org
Eric Jacobsen wrote:
>> Then I might need a precision rotor... > > And you might get an even less reliable signal. > > Multipath helps if your equalizer is good enough to take advantage of > it. > > Think of it this way, if 80% of the impinging power at the antenna > location is in the strongest ray and 10% of the power is in the second > strongest, an omnidirectional or wide-beam antenna that admits both, > along with an equalizer that integrates them, will be able to exploit > at -least- 90% of the available energy (plus however many other > smaller rays can be integrated). > > If the high-gain antenna rejects all of the reflections but the > strongest ray, i.e., you've done a good job of pointing the horn at > the strongest reflection, if no other reflections come from that > direction you only have 80% of the available energy to use. This > might reduce the SNR enough to put you closer to or below the > threshold of watchability. > > This illustrates the concept of multi-path gain, which is a good thing > as long as the equalizer can make use of the collected rays. It > could be that the equalizer in your receiver just isn't very good in > dynamic conditions, like the wind blowing the reflectors and antenna > around.
For many people the wind blowing trees around is a much more significant thing. Equalisers tend to perform poorly with such rapidly changing reflections.
> Usually, though, the gain of a good directive antenna is higher than > the loss in multipath gain, so a net gain in SNR can often be > expected. It is usually not the case, though, that using a 10dB gain > antenna, for example, in a rich multipath environment to replace an > omni results in 10dB higher margin. It's often much, much less than > that.
Steve
John O'Flaherty wrote:
> On Thu, 03 Jan 2008 18:01:04 -0500, Jerry Avins <jya@ieee.org> wrote: > > >>Richard Owlett wrote: >> >>>HardySpicer wrote: >>> >>>>On Jan 4, 5:27 am, Jerry Avins <j...@ieee.org> wrote: >>>> >>>> >>>>>I was in a "warehouse" store recently where there were a few dozen TV >>>>>sets on display, fed in banks from three different canned feeds. All >>>>>suffered from ghost images and the ghosts from any one feed seemed >>>>>identical. Can there be digital ghosts? If yes, how? Were the ghosts >>>>>originally analog, then digitized? If yes, do producers of TV demos >>>>>typically do it so sloppily? >>>>> >>>>>Jerry >>>>>-- >>>>>Engineering is the art of making what you want from things you can get. >>>>>&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295; >>>> >>>> >>>>Multi-path doesn't care whether you transmit analog or digital. There >>>>are some digital systems that pretend to have fixed the problem but as >>>>you see it is still a major problem. OFDM is supposed to have it fixed >>>>but I hear that isn't true either. >>>> >>>> >>>>Hardy >>> >>>Does that imply that digital TV is no _more_ susceptible to multipath >>>related problems than analog. That is, currently having an acceptable >>>picture, will I have an acceptable picture without upgrading my antenna? >> >>That depends on what you're willing to accept. If you now get a snowy >>and heavily ghosted picture, a digital transmission won't likely produce >>anything you can recognize. If your analog picture if fairly clean with >>only faint ghosts, you will probably get a perfect digital picture. > > > I've bought a digital HDTV, and am trying to get off-air digital > because I don't want to be ripped off by a cable company. I live in a > valley about 25 miles south of St. Louis, MO. I'm at the north end of > the valley. Without a directional antenna, I get stronger reflected TV > signals from the south wall of the valley than I do right from the > station, at about a 20 us delay, and there can be very strong ghosts, > worse in winter than summer because the reflections aren't absorbed by > foliage. The UHF stations are worst, and, unfortunately, all the > digital broadcasts are in the UHF band. > My experience with receiving digital signals is this - whenever I > can get anything at all, the picture is perfect except for occasional > breakup. I'm about as likely to get a good digital signal pointing the > antenna at the reflected signal as at the direct signal. The problem > is that there is multi-path either way, and while I can get a stable > picture by re-aiming the antenna for each station in calm weather, if > there is any wind, the multi-path is re-shuffled enough that the > signal is lost every few seconds. > There is no ghosting on digital, of course, since the video is > compressed* and there's no simple mapping from signal delay to video > delay, and there's no snow, per se. When I can get a stable signal, > the picture is perfect and beautiful, and when it's actually a high > definition source, it's really impressive. > I'm thinking of buying a tower and putting a couple of antennas on > it, maybe with a rotor. > > > * In fact, several stations broadcast two to four channels on one UHF > carrier. >
From yours and Jerry's description, I should be in pretty good shape. I've got good signal strength on all but one channel (3 at low vhf). Of two best channels, one is vhf (10) and one uhf (27). I believe all the transmitters are in the same area, never figured out why channel 3 was always the worst.
On Fri, 04 Jan 2008 00:13:14 -0700, Eric Jacobsen
<eric.jacobsen@ieee.org> wrote:
>On Thu, 03 Jan 2008 22:08:56 -0600, John O'Flaherty ><quiasmox@yeeha.com> wrote: > >>On Thu, 03 Jan 2008 21:17:00 -0500, Randy Yates <yates@ieee.org> >>wrote: >> >>>John O'Flaherty <quiasmox@yeeha.com> writes: >>> >>>> On Thu, 03 Jan 2008 18:01:04 -0500, Jerry Avins <jya@ieee.org> wrote: >>>> >>>>>Richard Owlett wrote: >>>>>> HardySpicer wrote: >>>>>>> On Jan 4, 5:27 am, Jerry Avins <j...@ieee.org> wrote: >>>>>>> >>>>>>>> I was in a "warehouse" store recently where there were a few dozen TV >>>>>>>> sets on display, fed in banks from three different canned feeds. All >>>>>>>> suffered from ghost images and the ghosts from any one feed seemed >>>>>>>> identical. Can there be digital ghosts? If yes, how? Were the ghosts >>>>>>>> originally analog, then digitized? If yes, do producers of TV demos >>>>>>>> typically do it so sloppily? >>>>>>>> >>>>>>>> Jerry >>>>>>>> -- >>>>>>>> Engineering is the art of making what you want from things you can get. >>>>>>>> &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295; >>>>>>> >>>>>>> >>>>>>> Multi-path doesn't care whether you transmit analog or digital. There >>>>>>> are some digital systems that pretend to have fixed the problem but as >>>>>>> you see it is still a major problem. OFDM is supposed to have it fixed >>>>>>> but I hear that isn't true either. >>>>>>> >>>>>>> >>>>>>> Hardy >>>>>> >>>>>> Does that imply that digital TV is no _more_ susceptible to multipath >>>>>> related problems than analog. That is, currently having an acceptable >>>>>> picture, will I have an acceptable picture without upgrading my antenna? >>>>> >>>>>That depends on what you're willing to accept. If you now get a snowy >>>>>and heavily ghosted picture, a digital transmission won't likely produce >>>>>anything you can recognize. If your analog picture if fairly clean with >>>>>only faint ghosts, you will probably get a perfect digital picture. >>>> >>>> I've bought a digital HDTV, and am trying to get off-air digital >>>> because I don't want to be ripped off by a cable company. I live in a >>>> valley about 25 miles south of St. Louis, MO. I'm at the north end of >>>> the valley. Without a directional antenna, I get stronger reflected TV >>>> signals from the south wall of the valley than I do right from the >>>> station, at about a 20 us delay, and there can be very strong ghosts, >>>> worse in winter than summer because the reflections aren't absorbed by >>>> foliage. The UHF stations are worst, and, unfortunately, all the >>>> digital broadcasts are in the UHF band. >>>> My experience with receiving digital signals is this - whenever I >>>> can get anything at all, the picture is perfect except for occasional >>>> breakup. I'm about as likely to get a good digital signal pointing the >>>> antenna at the reflected signal as at the direct signal. The problem >>>> is that there is multi-path either way, and while I can get a stable >>>> picture by re-aiming the antenna for each station in calm weather, if >>>> there is any wind, the multi-path is re-shuffled enough that the >>>> signal is lost every few seconds. >>>> There is no ghosting on digital, of course, since the video is >>>> compressed* and there's no simple mapping from signal delay to video >>>> delay, and there's no snow, per se. When I can get a stable signal, >>>> the picture is perfect and beautiful, and when it's actually a high >>>> definition source, it's really impressive. >>>> I'm thinking of buying a tower and putting a couple of antennas on >>>> it, maybe with a rotor. >>> >>>How about a UHF horn? :) >> >>Then I might need a precision rotor... > >And you might get an even less reliable signal. > >Multipath helps if your equalizer is good enough to take advantage of >it. > >Think of it this way, if 80% of the impinging power at the antenna >location is in the strongest ray and 10% of the power is in the second >strongest, an omnidirectional or wide-beam antenna that admits both, >along with an equalizer that integrates them, will be able to exploit >at -least- 90% of the available energy (plus however many other >smaller rays can be integrated). > >If the high-gain antenna rejects all of the reflections but the >strongest ray, i.e., you've done a good job of pointing the horn at >the strongest reflection, if no other reflections come from that >direction you only have 80% of the available energy to use. This >might reduce the SNR enough to put you closer to or below the >threshold of watchability. > >This illustrates the concept of multi-path gain, which is a good thing >as long as the equalizer can make use of the collected rays. It >could be that the equalizer in your receiver just isn't very good in >dynamic conditions, like the wind blowing the reflectors and antenna >around. > >Usually, though, the gain of a good directive antenna is higher than >the loss in multipath gain, so a net gain in SNR can often be >expected. It is usually not the case, though, that using a 10dB gain >antenna, for example, in a rich multipath environment to replace an >omni results in 10dB higher margin. It's often much, much less than >that.
As far as I know, there's no SNR problem, since I can get good signal in calm wind conditions after pointing the antenna. Is there some rating spec for equalizer performance? I'm stuck with the HDTV I bought, but since it has no video outputs, I'll probably be buying a converter for some old TVs, and I'd like to get a better one, if possible. -- John
> On Thu, 03 Jan 2008 22:08:56 -0600, John O'Flaherty > <quiasmox@yeeha.com> wrote: > >> On Thu, 03 Jan 2008 21:17:00 -0500, Randy Yates <yates@ieee.org> >> wrote: >> >>> John O'Flaherty <quiasmox@yeeha.com> writes:
>>>> I'm thinking of buying a tower and putting a couple of antennas on >>>> it, maybe with a rotor. >>> How about a UHF horn? :) >> Then I might need a precision rotor... > > And you might get an even less reliable signal. > > Multipath helps if your equalizer is good enough to take advantage of > it. > > Think of it this way, if 80% of the impinging power at the antenna > location is in the strongest ray and 10% of the power is in the second > strongest, an omnidirectional or wide-beam antenna that admits both, > along with an equalizer that integrates them, will be able to exploit > at -least- 90% of the available energy (plus however many other > smaller rays can be integrated). > > If the high-gain antenna rejects all of the reflections but the > strongest ray, i.e., you've done a good job of pointing the horn at > the strongest reflection, if no other reflections come from that > direction you only have 80% of the available energy to use. This > might reduce the SNR enough to put you closer to or below the > threshold of watchability.
The usual goal isn't the highest signal, but the highest SNR. A very directional antenna can reject noise as well as reflections. As the New York lottery ads go, "Hey, you never know!" Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
On Fri, 04 Jan 2008 08:55:05 -0600, John O'Flaherty
>On Fri, 04 Jan 2008 00:13:14 -0700, Eric Jacobsen ><eric.jacobsen@ieee.org> wrote: > >>On Thu, 03 Jan 2008 22:08:56 -0600, John O'Flaherty >><quiasmox@yeeha.com> wrote: >> >>>On Thu, 03 Jan 2008 21:17:00 -0500, Randy Yates <yates@ieee.org> >>>wrote: >>> >>>>John O'Flaherty <quiasmox@yeeha.com> writes: >>>> >>>>> On Thu, 03 Jan 2008 18:01:04 -0500, Jerry Avins <jya@ieee.org> wrote: >>>>> >>>>>>Richard Owlett wrote: >>>>>>> HardySpicer wrote: >>>>>>>> On Jan 4, 5:27 am, Jerry Avins <j...@ieee.org> wrote: >>>>>>>> >>>>>>>>> I was in a "warehouse" store recently where there were a few dozen TV >>>>>>>>> sets on display, fed in banks from three different canned feeds. All >>>>>>>>> suffered from ghost images and the ghosts from any one feed seemed >>>>>>>>> identical. Can there be digital ghosts? If yes, how? Were the ghosts >>>>>>>>> originally analog, then digitized? If yes, do producers of TV demos >>>>>>>>> typically do it so sloppily? >>>>>>>>> >>>>>>>>> Jerry >>>>>>>>> -- >>>>>>>>> Engineering is the art of making what you want from things you can get. >>>>>>>>> &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295; >>>>>>>> >>>>>>>> >>>>>>>> Multi-path doesn't care whether you transmit analog or digital. There >>>>>>>> are some digital systems that pretend to have fixed the problem but as >>>>>>>> you see it is still a major problem. OFDM is supposed to have it fixed >>>>>>>> but I hear that isn't true either. >>>>>>>> >>>>>>>> >>>>>>>> Hardy >>>>>>> >>>>>>> Does that imply that digital TV is no _more_ susceptible to multipath >>>>>>> related problems than analog. That is, currently having an acceptable >>>>>>> picture, will I have an acceptable picture without upgrading my antenna? >>>>>> >>>>>>That depends on what you're willing to accept. If you now get a snowy >>>>>>and heavily ghosted picture, a digital transmission won't likely produce >>>>>>anything you can recognize. If your analog picture if fairly clean with >>>>>>only faint ghosts, you will probably get a perfect digital picture. >>>>> >>>>> I've bought a digital HDTV, and am trying to get off-air digital >>>>> because I don't want to be ripped off by a cable company. I live in a >>>>> valley about 25 miles south of St. Louis, MO. I'm at the north end of >>>>> the valley. Without a directional antenna, I get stronger reflected TV >>>>> signals from the south wall of the valley than I do right from the >>>>> station, at about a 20 us delay, and there can be very strong ghosts, >>>>> worse in winter than summer because the reflections aren't absorbed by >>>>> foliage. The UHF stations are worst, and, unfortunately, all the >>>>> digital broadcasts are in the UHF band. >>>>> My experience with receiving digital signals is this - whenever I >>>>> can get anything at all, the picture is perfect except for occasional >>>>> breakup. I'm about as likely to get a good digital signal pointing the >>>>> antenna at the reflected signal as at the direct signal. The problem >>>>> is that there is multi-path either way, and while I can get a stable >>>>> picture by re-aiming the antenna for each station in calm weather, if >>>>> there is any wind, the multi-path is re-shuffled enough that the >>>>> signal is lost every few seconds. >>>>> There is no ghosting on digital, of course, since the video is >>>>> compressed* and there's no simple mapping from signal delay to video >>>>> delay, and there's no snow, per se. When I can get a stable signal, >>>>> the picture is perfect and beautiful, and when it's actually a high >>>>> definition source, it's really impressive. >>>>> I'm thinking of buying a tower and putting a couple of antennas on >>>>> it, maybe with a rotor. >>>> >>>>How about a UHF horn? :) >>> >>>Then I might need a precision rotor... >> >>And you might get an even less reliable signal. >> >>Multipath helps if your equalizer is good enough to take advantage of >>it. >> >>Think of it this way, if 80% of the impinging power at the antenna >>location is in the strongest ray and 10% of the power is in the second >>strongest, an omnidirectional or wide-beam antenna that admits both, >>along with an equalizer that integrates them, will be able to exploit >>at -least- 90% of the available energy (plus however many other >>smaller rays can be integrated). >> >>If the high-gain antenna rejects all of the reflections but the >>strongest ray, i.e., you've done a good job of pointing the horn at >>the strongest reflection, if no other reflections come from that >>direction you only have 80% of the available energy to use. This >>might reduce the SNR enough to put you closer to or below the >>threshold of watchability. >> >>This illustrates the concept of multi-path gain, which is a good thing >>as long as the equalizer can make use of the collected rays. It >>could be that the equalizer in your receiver just isn't very good in >>dynamic conditions, like the wind blowing the reflectors and antenna >>around. >> >>Usually, though, the gain of a good directive antenna is higher than >>the loss in multipath gain, so a net gain in SNR can often be >>expected. It is usually not the case, though, that using a 10dB gain >>antenna, for example, in a rich multipath environment to replace an >>omni results in 10dB higher margin. It's often much, much less than >>that. > >As far as I know, there's no SNR problem, since I can get good signal >in calm wind conditions after pointing the antenna. Is there some >rating spec for equalizer performance? I'm stuck with the HDTV I >bought, but since it has no video outputs, I'll probably be buying a >converter for some old TVs, and I'd like to get a better one, if >possible.
AFAIK there aren't anything but rudimentary acceptance tests for ATSC receiver performance, which isn't unusual for applications with channels with high multipath and dynamic fading. The real world will always be a bit different than whatever models are cooked up, anyway. There are some basic ATSC channel models, but the spec really only defines the air interface. How to build the receiver is up to the implementers. So receiver and equalizer performance are always implementation specific, and since EQs are waaay beyond the realm of understanding for most consumers manufacturers don't provide spec info for them. I don't know of any way short of field A/B testing or building a lab with a channel simulator to sort out how well the various receivers perform in dynamic fading, so we're kind of stuck making buying decisions based on other metrics and just hoping for the best. Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org
