Thank you for your reply, Andor.>On 20 Jul., 14:06, Terry wrote: >> Hi Folks, >> >> I came across this thread while searching for an alternative to theMatlab>> function iirgrpdelay. I don't have MATLAB, but use Octave instead. >> Unfortunately, iirgrpdelay uses a compiled MATLAB MEX file for itsguts.>> >> I tried Greg's cool function (which is 100% Octave compatible!), butit>> doesn't give me quite what I need. I need a true allpass filter(numerator>> coefficients same as reversed denominator coefficients), likeiirgrpdelay>> produces. Putting in all 1's for magnitude does not yield this. > >Hi Terry > >It is quite easy to modify Greg's FDLS to design proper allpass >filters. Remember that the underlying equations are of the form > >A_m cos(w_m + phi_m) = - A_m sum_{k=1}^p a_k cos(-w_m*k + phi_m) + sum_ >{k=0}^z b_k cos(-w_m*k) > >where w_m, m=1,2,...M, are the frequencies where you sample the >allpass frequncy response, A_m the amplitude and phi_m the phase at >that frequency (p is the order of the recursive part, z the order of >the transversal part). For an allpass filter of order p, the above >equation becomes > >cos(w_m + phi_m) = -sum_{k=1}^p a_k cos(-w_m*k + phi_m) + sum_{k=0}^p >a_{p-k} cos(-w_m*k), > >so you get > >cos(w_m + phi_m) - cos(-w_m*p) = sum_{k=1}^p a_k ( cos(-w_m*k + phi_m) >+ cos(-w_k*(p-k)) ) > >and now solve for the allpass coefficients a_k. > >Regards, >AndorIsn't this the same as setting all the A_m coefficients to 1, which can be done without modifying the program? Or am I not understanding something fundamental here? I have already tried this, and got no phase match and unrelated numerator and denominator coefficients. Also, I am confused about the proper usage of the argument "artificial delay" (the variable named "delta") in this program. I used the M=8 FDLS Example written up by Greg Berchin and Richard Lyons. I found that the accuracy of the result was very dependent on the value of delta. A value of 0.001 seemed to give reasonably good accuracy. But other values did not. How does one choose the correct value a priori? Thanks, Terry
group delay equalizer
Started by ●January 13, 2008
Reply by ●July 21, 20092009-07-21
On Tue, 21 Jul 2009 09:45:23 -0500, "montlick" <terry@tmlaboratories.com> wrote:>Isn't this the same as setting all the A_m coefficients to 1, which can be >done without modifying the program? Or am I not understanding something >fundamental here? I have already tried this, and got no phase match and >unrelated numerator and denominator coefficients.I didn't quite follow Andor's explanation because of nomenclature problems in this fixed text format. But basically, you should be able to start with the fundamental FDLS transfer function, -1 -n b + b z + ... + b z y(z) 0 1 n ---- = ----------------------- u(z) -1 -d 1 + a z + ... + a z 1 d and CONSTRAIN the coefficients to be of the form you desire (numerator coefficients the same as denominator coefficients, but in reverse order): -1 -n a + a z + ... + z y(z) d d-1 ---- = ----------------------- u(z) -1 -d 1 + a z + ... + a z 1 d Then just follow the rest of the procedure exactly as described in the article, except instead of there being "a" and "b" coefficients, there will just be "a" coefficients used in both the denominator and the numerator. I suspect that this is what Andor was trying to say.>Also, I am confused about the proper usage of the argument "artificial >delay" (the variable named "delta") in this program. I used the M=8 FDLS >Example written up by Greg Berchin and Richard Lyons. I found that the >accuracy of the result was very dependent on the value of delta. A value of >0.001 seemed to give reasonably good accuracy. But other values did not. >How does one choose the correct value a priori?First, make certain that you have version 2.00 of the Matlab code. Earlier versions implemented the delay in a slightly different manner that can lead to unstable models being created from stable transfer functions. Now as to the "artificial delay"; when formulated using cosine waves, as in the magazine article and the Matlab code, the algorithm only models the real part of the frequency response. Similarly, if formulated using sine waves instead of cosine waves, it only models the imaginary part. (Unfortunately, a sine formulation has some stability problems related to the fact that sine waves whose frequency is close to half the sampling frequency are sampled very close to the zero crossings, so creating a sine formulation is a nontrivial task.) The easiest way to make some of the imaginary part of the frequency response real (and some of the real part imaginary) is to add a small amount of delay to the transfer function. That's what the "artificial delay" parameter is for. Many times you'll get a good fit without it. Other times one or two samples of delay will give you a better fit. If you need more than a few samples of delay, then something else is probably wrong. By the way, the value of "delta" was intended to be an integer (a value of "1" representing a delay of one sample period, for example), but now that you mention it there is no mathematical reason that it HAS to be. Greg
>Now as to the "artificial delay"; when formulated using cosine waves, >as in the magazine article and the Matlab code, the algorithm only >models the real part of the frequency response. Similarly, if >formulated using sine waves instead of cosine waves, it only models >the imaginary part. (Unfortunately, a sine formulation has some >stability problems related to the fact that sine waves whose frequency >is close to half the sampling frequency are sampled very close to the >zero crossings, so creating a sine formulation is a nontrivial task.) >The easiest way to make some of the imaginary part of the frequency >response real (and some of the real part imaginary) is to add a small >amount of delay to the transfer function. That's what the "artificial >delay" parameter is for. Many times you'll get a good fit without it. >Other times one or two samples of delay will give you a better fit. If >you need more than a few samples of delay, then something else is >probably wrong. >Ah, this explains a great deal, Greg. Thank you! - Terry
