hi everyone, i have some problems when i use dsp/bios. i want to use a software interrupt to contrule a task, when something have met, software send a interrupt signal and boot task. the task need to be booted peridicly. the problem is that how can i do this through bios. thanks!
dm642 multitask
Started by ●January 14, 2008
Reply by ●January 14, 20082008-01-14
On 1��14��, ����7ʱ46��, rbmm...@gmail.com wrote: hi everyone, i have some problems when i use dsp/bios. i want to use a software interrupt to control a task, when something have met, software send a interrupt signal and boot task. the problem is that how can i do this through bios. thanks!
rbmm756@gmail.com wrote:> On 1��14��, ����7ʱ46��, rbmm...@gmail.com wrote: > hi everyone, > i have some problems when i use dsp/bios. i want to use a software > interrupt to control a task, when something have met, software send a > interrupt signal and boot task. the problem is that how can i do this > through bios. > thanks!OK. Send me money. VLV
Reply by ●January 25, 20082008-01-25
rbmm756@gmail.com wrote:> hi everyone, > i have some problems when i use dsp/bios. i want to use a software > interrupt to contrule a task, when something have met, software send a > interrupt signal and boot task. the task need to be booted peridicly. > the problem is that how can i do this through bios. > thanks!You can do this in BIOS using the software interrupt module (SWI). Details are in the BIOS User Guide and API Guide. Brad
