The receiver performs the FFT on the duration of one symbol. Hence, unless the symbol is cyclically extended, the dispersion in the channel will destroy the orthogonality. If the prefix is set to zero, then you have to perform some sort of equalization prior to the FFT. It is possible, however it is totally missing the whole point of OFDM: reduced complexity. VLV "Eric Jacobsen" <eric.jacobsen@ieee.org> wrote in message news:8043p390v9lj7160lnb4ic248m9u07pp1j@4ax.com...> Vlad, the zero prefix doesn't eliminate the prefix, it replaces it > with dead time. i.e., transmit no energy during the CP time. > > In the receiver the dead time after the symbol is sampled, so that the > tail due to the channel memory can be added back to the beginning of > the FFT vector so that the channel convolution is still circular. > > It does mean that you're not transmitting any energy during the CP, it > also means that the PA is turning OFF for the CP duration every > symbol. Depending on how the PA is made that could be good for energy > consumption and spectral flattening or it could royally screw up the > PA behavior. > > On Sat, 19 Jan 2008 02:52:40 GMT, "Vladimir Vassilevsky" > <antispam_bogus@hotmail.com> wrote: > > > > >The cyclic prefix is essential. Otherwise the dispersion in the channelwill> >result in the loss of the orthogonality. > > > >VLV > > > > > > > >"Eric Jacobsen" <eric.jacobsen@ieee.org> wrote in message > >news:o9d2p31hhho7oas00n9svmembcp20o67bn@4ax.com... > >> On Fri, 18 Jan 2008 10:18:04 -0800 (PST), karthikbalaguru > >> <karthikbalaguru79@gmail.com> wrote: > >> > >> >On Jan 18, 10:31 pm, Eric Jacobsen <eric.jacob...@ieee.org> wrote: > >> >> On Fri, 18 Jan 2008 09:16:45 -0800 (PST), karthikbalaguru > >> >> > >> >> <karthikbalagur...@gmail.com> wrote: > >> >> >Hi, > >> >> > >> >> >I understand that zero prefix reduces the transmit power in OFDMbased> >> >> >systems. Then, why is cyclic prefix(CP) used widely and is more > >> >> >popular ? > >> >> >Why has WiMAX opted for Cyclic Prefix ? > >> >> >Any ideas . > >> >> > >> >> >Thx in advans, > >> >> >Karthik Balaguru > >> >> > >> >> Could you clarify what you mean by zero prefix? Do you mean not > >> >> transmitting any energy during the guard interval? > >> >> > >> >> If that's what you mean I don't know of any OFDM systems that work > >> >> that way. If that's not what you mean, please clarify. > >> >> > >> > > >> >I find that, Zero prefix constitutes a null guard band. > >> >Futher, here, the transmitter will be sending a prefix of null data. > >> >That is - send nothing in the guard interval and at the > >> >receiver end, copy to the front of OFDM symbol, the received tail. > >> > >> >But, I find its use in Ultrawideband (UWB) multiband OFDM. > >> >Also refer, > >http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=4577&objectType=file> >> > >> I had to do some reading to catch up, but I think I get it now. > >> > >> Yes, it will require less total transmit power, and since a goal for > >> UWB and 802.15 devices in general is low power consumption, I suppose > >> that helps a little bit. According to one reference I found it may > >> also reduce ripple in the Tx spectrum a bit, but the value of that may > >> be questionable in many cases. UWB has some pretty tight psd limits, > >> so perhaps that was part of the motivation. > >> > >> >Any ideas - why Zero Prefix is not preferred in WiMAX ? > >> > > >> >Karthik Balaguru > >> > >> There are some significant downsides to Zero Prefix for a lot of > >> applications. PAPR is problematic for OFDM in general, and turning > >> the Power Amplifier off for a small amount of time in a high-power > >> application is generally pretty difficult. The power levels in UWB > >> are quite low since the range is miniscule compared to WiMAX, and the > >> PA technology for UWB is evidently tolerant of the on-off cycles. > >> Getting a WiMAX PA to do that, or any PA that's transmitting very much > >> power, is much harder to do. Controlling the PA on/off cycle is > >> important in keeping it from splattering energy into adjacent bands, > >> and turning it on and off every OFDM symbol would create a lot more > >> problems than it solves. > >> > >> That's my guess, anyway. > >> > >> Eric Jacobsen > >> Minister of Algorithms > >> Abineau Communications > >> http://www.ericjacobsen.org > > > Eric Jacobsen > Minister of Algorithms > Abineau Communications > http://www.ericjacobsen.org
Zero Prefix and the CP
Started by ●January 18, 2008
Reply by ●January 19, 20082008-01-19
On Jan 18, 11:53�pm, Oli Charlesworth <ca...@olifilth.co.uk> wrote:> On Jan 18, 6:18 pm, karthikbalaguru <karthikbalagur...@gmail.com> > wrote: > > > > > > > On Jan 18, 10:31 pm, Eric Jacobsen <eric.jacob...@ieee.org> wrote: > > > > On Fri, 18 Jan 2008 09:16:45 -0800 (PST), karthikbalaguru > > > > <karthikbalagur...@gmail.com> wrote: > > > >Hi, > > > > >I understand that zero prefix reduces the transmit power in OFDM based > > > >systems. Then, why is cyclic prefix(CP) used widely and is more > > > >popular ? > > > >Why has WiMAX opted for Cyclic Prefix ? > > > >Any ideas . > > > > >Thx in advans, > > > >Karthik Balaguru > > > > Could you clarify what you mean by zero prefix? � Do you mean not > > > transmitting any energy during the guard interval? > > > > If that's what you mean I don't know of any OFDM systems that work > > > that way. � If that's not what you mean, please clarify. > > > I find that, Zero prefix constitutes a null guard band. > > Futher, here, the transmitter will be sending a prefix of null data. > > That is - send nothing in the guard interval and at the > > receiver end, copy to the front of OFDM symbol, the received tail. > > > But, I find its use in Ultrawideband (UWB) multiband OFDM. > > Also refer,http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objec... > > > Any ideas - why Zero Prefix is not preferred in WiMAX ? > > Because using a cyclic-prefix makes each OFDM easy to equalise; the > whole circular-convolution thing. > > --Interesting !! Thx . Karthik Balaguru
On Jan 19, 3:50�am, Jerry Avins <j...@ieee.org> wrote:> karthikbalaguru wrote: > > On Jan 18, 11:53 pm, Oli Charlesworth <ca...@olifilth.co.uk> wrote: > >> On Jan 18, 6:18 pm, karthikbalaguru <karthikbalagur...@gmail.com> > >> wrote: > > >>> On Jan 18, 10:31 pm, Eric Jacobsen <eric.jacob...@ieee.org> wrote: > >>>> On Fri, 18 Jan 2008 09:16:45 -0800 (PST), karthikbalaguru > >>>> <karthikbalagur...@gmail.com> wrote: > >>>>> Hi, > >>>>> I understand that zero prefix reduces the transmit power in OFDM based > >>>>> systems. Then, why is cyclic prefix(CP) used widely and is more > >>>>> popular ? > >>>>> Why has WiMAX opted for Cyclic Prefix ? > >>>>> Any ideas . > >>>>> Thx in advans, > >>>>> Karthik Balaguru > >>>> Could you clarify what you mean by zero prefix? � Do you mean not > >>>> transmitting any energy during the guard interval? > >>>> If that's what you mean I don't know of any OFDM systems that work > >>>> that way. � If that's not what you mean, please clarify. > >>> I find that, Zero prefix constitutes a null guard band. > >>> Futher, here, the transmitter will be sending a prefix of null data. > >>> That is - send nothing in the guard interval and at the > >>> receiver end, copy to the front of OFDM symbol, the received tail. > >>> But, I find its use in Ultrawideband (UWB) multiband OFDM. > >>> Also refer,http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objec... > >>> Any ideas - why Zero Prefix is not preferred in WiMAX ? > >> Because using a cyclic-prefix makes each OFDM easy to equalise; the > >> whole circular-convolution thing. > > > Thx for that info !! But, i still have some queries based on this . > > It looks like, zero prefix reduces the transmit power in OFDM based > > systems. > > Transmit power also plays an important role. > > So, why is cyclic prefix(CP) used instead of Zero Prefix ? > > Any other reasons ? > > In the end, it's bit error rate that matters. Turning the transmitter > off saves power, but it doesn't help send good bits through. >Logical point :):) !!. Thx, Karthik Balaguru
On Jan 19, 5:02�am, Eric Jacobsen <eric.jacob...@ieee.org> wrote:> On Fri, 18 Jan 2008 10:18:04 -0800 (PST), karthikbalaguru > > > > > > <karthikbalagur...@gmail.com> wrote: > >On Jan 18, 10:31�pm, Eric Jacobsen <eric.jacob...@ieee.org> wrote: > >> On Fri, 18 Jan 2008 09:16:45 -0800 (PST), karthikbalaguru > > >> <karthikbalagur...@gmail.com> wrote: > >> >Hi, > > >> >I understand that zero prefix reduces the transmit power in OFDM based > >> >systems. Then, why is cyclic prefix(CP) used widely and is more > >> >popular ? > >> >Why has WiMAX opted for Cyclic Prefix ? > >> >Any ideas . > > >> >Thx in advans, > >> >Karthik Balaguru > > >> Could you clarify what you mean by zero prefix? � Do you mean not > >> transmitting any energy during the guard interval? > > >> If that's what you mean I don't know of any OFDM systems that work > >> that way. � If that's not what you mean, please clarify. > > >I find that, Zero prefix constitutes a null guard band. > >Futher, here, the transmitter will be sending a prefix of null data. > >That is - send nothing in the guard interval and at the > >receiver end, copy to the front of OFDM symbol, the received tail. > >But, I find its use in Ultrawideband (UWB) multiband OFDM. > >Also refer,http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objec... > > I had to do some reading to catch up, but I think I get it now. > > Yes, it will require less total transmit power, and since a goal for > UWB and 802.15 devices in general is low power consumption, I suppose > that helps a little bit. � According to one reference I found it may > also reduce ripple in the Tx spectrum a bit, but the value of that may > be questionable in many cases. � UWB has some pretty tight psd limits, > so perhaps that was part of the motivation. > > >Any ideas - why Zero Prefix is not preferred in WiMAX ? > > >Karthik Balaguru > > There are some significant downsides to Zero Prefix for a lot of > applications. � PAPR is problematic for OFDM in general, and turning > the Power Amplifier off for a small amount of time in a high-power > application is generally pretty difficult. �The power levels in UWB > are quite low since the range is miniscule compared to WiMAX, and the > PA technology for UWB is evidently tolerant of the on-off cycles. > Getting a WiMAX PA to do that, or any PA that's transmitting very much > power, is much harder to do. � Controlling the PA on/off cycle is > important in keeping it from splattering energy into adjacent bands, > and turning it on and off every OFDM symbol would create a lot more > problems than it solves. > > That's my guess, anyway. >Interesting Info !! :):) Thx, Karthik Balaguru
As I mentioned, the receiver samples the guard interval (which has no transmitted energy) after the FFT window and obtains any energy dispersed by the channel. Adding that energy back to the beginning of the FFT window has exactly the same effect of allowing the energy to disperse from a cyclic prefix. This makes the convolution cyclic and preserves orthogonality. From that standpoint there's no loss of performance of channel robustness and the complexity increase is small, if any. It does, however, restrict options on PA management, which is critical for many OFDM applications. On Sat, 19 Jan 2008 08:35:03 -0600, "Vladimir Vassilevsky" <antispam_bogus@hotmail.com> wrote:>The receiver performs the FFT on the duration of one symbol. Hence, unless >the symbol is cyclically extended, the dispersion in the channel will >destroy the orthogonality. If the prefix is set to zero, then you have to >perform some sort of equalization prior to the FFT. It is possible, however >it is totally missing the whole point of OFDM: reduced complexity. > >VLV > > >"Eric Jacobsen" <eric.jacobsen@ieee.org> wrote in message >news:8043p390v9lj7160lnb4ic248m9u07pp1j@4ax.com... >> Vlad, the zero prefix doesn't eliminate the prefix, it replaces it >> with dead time. i.e., transmit no energy during the CP time. >> >> In the receiver the dead time after the symbol is sampled, so that the >> tail due to the channel memory can be added back to the beginning of >> the FFT vector so that the channel convolution is still circular. >> >> It does mean that you're not transmitting any energy during the CP, it >> also means that the PA is turning OFF for the CP duration every >> symbol. Depending on how the PA is made that could be good for energy >> consumption and spectral flattening or it could royally screw up the >> PA behavior. >> >> On Sat, 19 Jan 2008 02:52:40 GMT, "Vladimir Vassilevsky" >> <antispam_bogus@hotmail.com> wrote: >> >> > >> >The cyclic prefix is essential. Otherwise the dispersion in the channel >will >> >result in the loss of the orthogonality. >> > >> >VLV >> > >> > >> > >> >"Eric Jacobsen" <eric.jacobsen@ieee.org> wrote in message >> >news:o9d2p31hhho7oas00n9svmembcp20o67bn@4ax.com... >> >> On Fri, 18 Jan 2008 10:18:04 -0800 (PST), karthikbalaguru >> >> <karthikbalaguru79@gmail.com> wrote: >> >> >> >> >On Jan 18, 10:31 pm, Eric Jacobsen <eric.jacob...@ieee.org> wrote: >> >> >> On Fri, 18 Jan 2008 09:16:45 -0800 (PST), karthikbalaguru >> >> >> >> >> >> <karthikbalagur...@gmail.com> wrote: >> >> >> >Hi, >> >> >> >> >> >> >I understand that zero prefix reduces the transmit power in OFDM >based >> >> >> >systems. Then, why is cyclic prefix(CP) used widely and is more >> >> >> >popular ? >> >> >> >Why has WiMAX opted for Cyclic Prefix ? >> >> >> >Any ideas . >> >> >> >> >> >> >Thx in advans, >> >> >> >Karthik Balaguru >> >> >> >> >> >> Could you clarify what you mean by zero prefix? Do you mean not >> >> >> transmitting any energy during the guard interval? >> >> >> >> >> >> If that's what you mean I don't know of any OFDM systems that work >> >> >> that way. If that's not what you mean, please clarify. >> >> >> >> >> > >> >> >I find that, Zero prefix constitutes a null guard band. >> >> >Futher, here, the transmitter will be sending a prefix of null data. >> >> >That is - send nothing in the guard interval and at the >> >> >receiver end, copy to the front of OFDM symbol, the received tail. >> >> >> >> >But, I find its use in Ultrawideband (UWB) multiband OFDM. >> >> >Also refer, >> >>http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=45 >77&objectType=file >> >> >> >> I had to do some reading to catch up, but I think I get it now. >> >> >> >> Yes, it will require less total transmit power, and since a goal for >> >> UWB and 802.15 devices in general is low power consumption, I suppose >> >> that helps a little bit. According to one reference I found it may >> >> also reduce ripple in the Tx spectrum a bit, but the value of that may >> >> be questionable in many cases. UWB has some pretty tight psd limits, >> >> so perhaps that was part of the motivation. >> >> >> >> >Any ideas - why Zero Prefix is not preferred in WiMAX ? >> >> > >> >> >Karthik Balaguru >> >> >> >> There are some significant downsides to Zero Prefix for a lot of >> >> applications. PAPR is problematic for OFDM in general, and turning >> >> the Power Amplifier off for a small amount of time in a high-power >> >> application is generally pretty difficult. The power levels in UWB >> >> are quite low since the range is miniscule compared to WiMAX, and the >> >> PA technology for UWB is evidently tolerant of the on-off cycles. >> >> Getting a WiMAX PA to do that, or any PA that's transmitting very much >> >> power, is much harder to do. Controlling the PA on/off cycle is >> >> important in keeping it from splattering energy into adjacent bands, >> >> and turning it on and off every OFDM symbol would create a lot more >> >> problems than it solves. >> >> >> >> That's my guess, anyway. >> >> >> >> Eric Jacobsen >> >> Minister of Algorithms >> >> Abineau Communications >> >> http://www.ericjacobsen.org >> > >> Eric Jacobsen >> Minister of Algorithms >> Abineau Communications >> http://www.ericjacobsen.org >Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org
Yes, it is possible to sample the guard interval and then add from the beginning of the FFT. However if the guard interval is set to zero initially, there wouldn't be much of energy there. So, this operation mostly adds noise to the signal. Apparently, the SNR is equal for the zero guard interval and for the cyclic preffix if the total energy per symbol is the same. So the zero guard interval only creates the additional complexity. VLV The sultan of the Rocket Science at somewhere.com "Eric Jacobsen" <eric.jacobsen@ieee.org> wrote in message news:nbb4p3hmeirjhbiuupm42lueq1v4sf0rd8@4ax.com...> > As I mentioned, the receiver samples the guard interval (which has no > transmitted energy) after the FFT window and obtains any energy > dispersed by the channel. Adding that energy back to the beginning > of the FFT window has exactly the same effect of allowing the energy > to disperse from a cyclic prefix. This makes the convolution cyclic > and preserves orthogonality. > > From that standpoint there's no loss of performance of channel > robustness and the complexity increase is small, if any. It does, > however, restrict options on PA management, which is critical for many > OFDM applications. > > On Sat, 19 Jan 2008 08:35:03 -0600, "Vladimir Vassilevsky" > <antispam_bogus@hotmail.com> wrote: > > >The receiver performs the FFT on the duration of one symbol. Hence,unless> >the symbol is cyclically extended, the dispersion in the channel will > >destroy the orthogonality. If the prefix is set to zero, then you have to > >perform some sort of equalization prior to the FFT. It is possible,however> >it is totally missing the whole point of OFDM: reduced complexity. > > > >VLV > > > > > >"Eric Jacobsen" <eric.jacobsen@ieee.org> wrote in message > >news:8043p390v9lj7160lnb4ic248m9u07pp1j@4ax.com... > >> Vlad, the zero prefix doesn't eliminate the prefix, it replaces it > >> with dead time. i.e., transmit no energy during the CP time. > >> > >> In the receiver the dead time after the symbol is sampled, so that the > >> tail due to the channel memory can be added back to the beginning of > >> the FFT vector so that the channel convolution is still circular. > >> > >> It does mean that you're not transmitting any energy during the CP, it > >> also means that the PA is turning OFF for the CP duration every > >> symbol. Depending on how the PA is made that could be good for energy > >> consumption and spectral flattening or it could royally screw up the > >> PA behavior. > >> > >> On Sat, 19 Jan 2008 02:52:40 GMT, "Vladimir Vassilevsky" > >> <antispam_bogus@hotmail.com> wrote: > >> > >> > > >> >The cyclic prefix is essential. Otherwise the dispersion in thechannel> >will > >> >result in the loss of the orthogonality. > >> > > >> >VLV > >> > > >> > > >> > > >> >"Eric Jacobsen" <eric.jacobsen@ieee.org> wrote in message > >> >news:o9d2p31hhho7oas00n9svmembcp20o67bn@4ax.com... > >> >> On Fri, 18 Jan 2008 10:18:04 -0800 (PST), karthikbalaguru > >> >> <karthikbalaguru79@gmail.com> wrote: > >> >> > >> >> >On Jan 18, 10:31 pm, Eric Jacobsen <eric.jacob...@ieee.org> wrote: > >> >> >> On Fri, 18 Jan 2008 09:16:45 -0800 (PST), karthikbalaguru > >> >> >> > >> >> >> <karthikbalagur...@gmail.com> wrote: > >> >> >> >Hi, > >> >> >> > >> >> >> >I understand that zero prefix reduces the transmit power in OFDM > >based > >> >> >> >systems. Then, why is cyclic prefix(CP) used widely and is more > >> >> >> >popular ? > >> >> >> >Why has WiMAX opted for Cyclic Prefix ? > >> >> >> >Any ideas . > >> >> >> > >> >> >> >Thx in advans, > >> >> >> >Karthik Balaguru > >> >> >> > >> >> >> Could you clarify what you mean by zero prefix? Do you mean not > >> >> >> transmitting any energy during the guard interval? > >> >> >> > >> >> >> If that's what you mean I don't know of any OFDM systems thatwork> >> >> >> that way. If that's not what you mean, please clarify. > >> >> >> > >> >> > > >> >> >I find that, Zero prefix constitutes a null guard band. > >> >> >Futher, here, the transmitter will be sending a prefix of nulldata.> >> >> >That is - send nothing in the guard interval and at the > >> >> >receiver end, copy to the front of OFDM symbol, the received tail. > >> >> > >> >> >But, I find its use in Ultrawideband (UWB) multiband OFDM. > >> >> >Also refer, > >> > >>http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=45> >77&objectType=file > >> >> > >> >> I had to do some reading to catch up, but I think I get it now. > >> >> > >> >> Yes, it will require less total transmit power, and since a goal for > >> >> UWB and 802.15 devices in general is low power consumption, Isuppose> >> >> that helps a little bit. According to one reference I found it may > >> >> also reduce ripple in the Tx spectrum a bit, but the value of thatmay> >> >> be questionable in many cases. UWB has some pretty tight psdlimits,> >> >> so perhaps that was part of the motivation. > >> >> > >> >> >Any ideas - why Zero Prefix is not preferred in WiMAX ? > >> >> > > >> >> >Karthik Balaguru > >> >> > >> >> There are some significant downsides to Zero Prefix for a lot of > >> >> applications. PAPR is problematic for OFDM in general, and turning > >> >> the Power Amplifier off for a small amount of time in a high-power > >> >> application is generally pretty difficult. The power levels in UWB > >> >> are quite low since the range is miniscule compared to WiMAX, andthe> >> >> PA technology for UWB is evidently tolerant of the on-off cycles. > >> >> Getting a WiMAX PA to do that, or any PA that's transmitting verymuch> >> >> power, is much harder to do. Controlling the PA on/off cycle is > >> >> important in keeping it from splattering energy into adjacent bands, > >> >> and turning it on and off every OFDM symbol would create a lot more > >> >> problems than it solves. > >> >> > >> >> That's my guess, anyway. > >> >> > >> >> Eric Jacobsen > >> >> Minister of Algorithms > >> >> Abineau Communications > >> >> http://www.ericjacobsen.org > >> > > >> Eric Jacobsen > >> Minister of Algorithms > >> Abineau Communications > >> http://www.ericjacobsen.org > > > Eric Jacobsen > Minister of Algorithms > Abineau Communications > http://www.ericjacobsen.org
Actually, I hadn't thought of that, that you'd be adding a little noise into the FFT window by copying the dispersed tail back into the front of the window. In that portion of the FFT there'd be double the noise than in the rest of the FFT window...hmmm, and since the CP length tends to be as much as 1/3 the length the of the FFT vector, that could be a substantial (or at least noticable) reduction in SNR. On Sat, 19 Jan 2008 12:50:39 -0600, "Vladimir Vassilevsky" <antispam_bogus@hotmail.com> wrote:>Yes, it is possible to sample the guard interval and then add from the >beginning of the FFT. However if the guard interval is set to zero >initially, there wouldn't be much of energy there. So, this operation mostly >adds noise to the signal. Apparently, the SNR is equal for the zero guard >interval and for the cyclic preffix if the total energy per symbol is the >same. So the zero guard interval only creates the additional complexity. > >VLV >The sultan of the Rocket Science at somewhere.com > > > >"Eric Jacobsen" <eric.jacobsen@ieee.org> wrote in message >news:nbb4p3hmeirjhbiuupm42lueq1v4sf0rd8@4ax.com... >> >> As I mentioned, the receiver samples the guard interval (which has no >> transmitted energy) after the FFT window and obtains any energy >> dispersed by the channel. Adding that energy back to the beginning >> of the FFT window has exactly the same effect of allowing the energy >> to disperse from a cyclic prefix. This makes the convolution cyclic >> and preserves orthogonality. >> >> From that standpoint there's no loss of performance of channel >> robustness and the complexity increase is small, if any. It does, >> however, restrict options on PA management, which is critical for many >> OFDM applications. >> >> On Sat, 19 Jan 2008 08:35:03 -0600, "Vladimir Vassilevsky" >> <antispam_bogus@hotmail.com> wrote: >> >> >The receiver performs the FFT on the duration of one symbol. Hence, >unless >> >the symbol is cyclically extended, the dispersion in the channel will >> >destroy the orthogonality. If the prefix is set to zero, then you have to >> >perform some sort of equalization prior to the FFT. It is possible, >however >> >it is totally missing the whole point of OFDM: reduced complexity. >> > >> >VLV >> > >> > >> >"Eric Jacobsen" <eric.jacobsen@ieee.org> wrote in message >> >news:8043p390v9lj7160lnb4ic248m9u07pp1j@4ax.com... >> >> Vlad, the zero prefix doesn't eliminate the prefix, it replaces it >> >> with dead time. i.e., transmit no energy during the CP time. >> >> >> >> In the receiver the dead time after the symbol is sampled, so that the >> >> tail due to the channel memory can be added back to the beginning of >> >> the FFT vector so that the channel convolution is still circular. >> >> >> >> It does mean that you're not transmitting any energy during the CP, it >> >> also means that the PA is turning OFF for the CP duration every >> >> symbol. Depending on how the PA is made that could be good for energy >> >> consumption and spectral flattening or it could royally screw up the >> >> PA behavior. >> >> >> >> On Sat, 19 Jan 2008 02:52:40 GMT, "Vladimir Vassilevsky" >> >> <antispam_bogus@hotmail.com> wrote: >> >> >> >> > >> >> >The cyclic prefix is essential. Otherwise the dispersion in the >channel >> >will >> >> >result in the loss of the orthogonality. >> >> > >> >> >VLV >> >> > >> >> > >> >> > >> >> >"Eric Jacobsen" <eric.jacobsen@ieee.org> wrote in message >> >> >news:o9d2p31hhho7oas00n9svmembcp20o67bn@4ax.com... >> >> >> On Fri, 18 Jan 2008 10:18:04 -0800 (PST), karthikbalaguru >> >> >> <karthikbalaguru79@gmail.com> wrote: >> >> >> >> >> >> >On Jan 18, 10:31 pm, Eric Jacobsen <eric.jacob...@ieee.org> wrote: >> >> >> >> On Fri, 18 Jan 2008 09:16:45 -0800 (PST), karthikbalaguru >> >> >> >> >> >> >> >> <karthikbalagur...@gmail.com> wrote: >> >> >> >> >Hi, >> >> >> >> >> >> >> >> >I understand that zero prefix reduces the transmit power in OFDM >> >based >> >> >> >> >systems. Then, why is cyclic prefix(CP) used widely and is more >> >> >> >> >popular ? >> >> >> >> >Why has WiMAX opted for Cyclic Prefix ? >> >> >> >> >Any ideas . >> >> >> >> >> >> >> >> >Thx in advans, >> >> >> >> >Karthik Balaguru >> >> >> >> >> >> >> >> Could you clarify what you mean by zero prefix? Do you mean not >> >> >> >> transmitting any energy during the guard interval? >> >> >> >> >> >> >> >> If that's what you mean I don't know of any OFDM systems that >work >> >> >> >> that way. If that's not what you mean, please clarify. >> >> >> >> >> >> >> > >> >> >> >I find that, Zero prefix constitutes a null guard band. >> >> >> >Futher, here, the transmitter will be sending a prefix of null >data. >> >> >> >That is - send nothing in the guard interval and at the >> >> >> >receiver end, copy to the front of OFDM symbol, the received tail. >> >> >> >> >> >> >But, I find its use in Ultrawideband (UWB) multiband OFDM. >> >> >> >Also refer, >> >> >> >>>http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objectId=4 >5 >> >77&objectType=file >> >> >> >> >> >> I had to do some reading to catch up, but I think I get it now. >> >> >> >> >> >> Yes, it will require less total transmit power, and since a goal for >> >> >> UWB and 802.15 devices in general is low power consumption, I >suppose >> >> >> that helps a little bit. According to one reference I found it may >> >> >> also reduce ripple in the Tx spectrum a bit, but the value of that >may >> >> >> be questionable in many cases. UWB has some pretty tight psd >limits, >> >> >> so perhaps that was part of the motivation. >> >> >> >> >> >> >Any ideas - why Zero Prefix is not preferred in WiMAX ? >> >> >> > >> >> >> >Karthik Balaguru >> >> >> >> >> >> There are some significant downsides to Zero Prefix for a lot of >> >> >> applications. PAPR is problematic for OFDM in general, and turning >> >> >> the Power Amplifier off for a small amount of time in a high-power >> >> >> application is generally pretty difficult. The power levels in UWB >> >> >> are quite low since the range is miniscule compared to WiMAX, and >the >> >> >> PA technology for UWB is evidently tolerant of the on-off cycles. >> >> >> Getting a WiMAX PA to do that, or any PA that's transmitting very >much >> >> >> power, is much harder to do. Controlling the PA on/off cycle is >> >> >> important in keeping it from splattering energy into adjacent bands, >> >> >> and turning it on and off every OFDM symbol would create a lot more >> >> >> problems than it solves. >> >> >> >> >> >> That's my guess, anyway. >> >> >> >> >> >> Eric Jacobsen >> >> >> Minister of Algorithms >> >> >> Abineau Communications >> >> >> http://www.ericjacobsen.org >> >> > >> >> Eric Jacobsen >> >> Minister of Algorithms >> >> Abineau Communications >> >> http://www.ericjacobsen.org >> > >> Eric Jacobsen >> Minister of Algorithms >> Abineau Communications >> http://www.ericjacobsen.org >Eric Jacobsen Minister of Algorithms Abineau Communications http://www.ericjacobsen.org
On Jan 19, 11:50�pm, "Vladimir Vassilevsky" <antispam_bo...@hotmail.com> wrote:> Yes, it is possible to sample the guard interval and then add from the > beginning of the FFT. However if the guard interval is set to zero > initially, there wouldn't be much of energy there. So, this operation mostly > adds noise to the signal. Apparently, the SNR is equal for the zero guard > interval and for the cyclic preffix if the total energy per symbol is the > same. So the zero guard interval only creates the additional complexity. >Nice point !! :):). Thx. Karthik Balaguru
On Jan 19, 11:50�pm, "Vladimir Vassilevsky" <antispam_bo...@hotmail.com> wrote:> Yes, it is possible to sample the guard interval and then add from the > beginning of the FFT. However if the guard interval is set to zero > initially, there wouldn't be much of energy there. So, this operation mostly > adds noise to the signal.Noise added here :(:( !!!. That is a nice point and it answers many of my queries that i had in my mind. Interesting to note that noise power increases because of this additional noise from the received symbols while adding it back.> Apparently, the SNR is equal for the zero guard > interval and for the cyclic preffix if the total energy per symbol is the > same. So the zero guard interval only creates the additional complexity. >Karthik Balaguru
Reply by ●January 20, 20082008-01-20
On Jan 19, 7:35 pm, "Vladimir Vassilevsky" <antispam_bo...@hotmail.com> wrote:> The receiver performs the FFT on the duration of one symbol. Hence, unless > the symbol is cyclically extended, the dispersion in the channel will > destroy the orthogonality. If the prefix is set to zero, then you have to > perform some sort of equalization prior to the FFT. It is possible, however > it is totally missing the whole point of OFDM: reduced complexity. > > VLV > > "Eric Jacobsen" <eric.jacob...@ieee.org> wrote in message > > news:8043p390v9lj7160lnb4ic248m9u07pp1j@4ax.com... > > > Vlad, the zero prefix doesn't eliminate the prefix, it replaces it > > with dead time. i.e., transmit no energy during the CP time. > > > In the receiver the dead time after the symbol is sampled, so that the > > tail due to the channel memory can be added back to the beginning of > > the FFT vector so that the channel convolution is still circular. > > > It does mean that you're not transmitting any energy during the CP, it > > also means that the PA is turning OFF for the CP duration every > > symbol. Depending on how the PA is made that could be good for energy > > consumption and spectral flattening or it could royally screw up the > > PA behavior. > > > On Sat, 19 Jan 2008 02:52:40 GMT, "Vladimir Vassilevsky" > > <antispam_bo...@hotmail.com> wrote: > > > >The cyclic prefix is essential. Otherwise the dispersion in the channel > will > > >result in the loss of the orthogonality. > > > >VLV > > > >"Eric Jacobsen" <eric.jacob...@ieee.org> wrote in message > > >news:o9d2p31hhho7oas00n9svmembcp20o67bn@4ax.com... > > >> On Fri, 18 Jan 2008 10:18:04 -0800 (PST), karthikbalaguru > > >> <karthikbalagur...@gmail.com> wrote: > > > >> >On Jan 18, 10:31 pm, Eric Jacobsen <eric.jacob...@ieee.org> wrote: > > >> >> On Fri, 18 Jan 2008 09:16:45 -0800 (PST), karthikbalaguru > > > >> >> <karthikbalagur...@gmail.com> wrote: > > >> >> >Hi, > > > >> >> >I understand that zero prefix reduces the transmit power in OFDM > based > > >> >> >systems. Then, why is cyclic prefix(CP) used widely and is more > > >> >> >popular ? > > >> >> >Why has WiMAX opted for Cyclic Prefix ? > > >> >> >Any ideas . > > > >> >> >Thx in advans, > > >> >> >Karthik Balaguru > > > >> >> Could you clarify what you mean by zero prefix? Do you mean not > > >> >> transmitting any energy during the guard interval? > > > >> >> If that's what you mean I don't know of any OFDM systems that work > > >> >> that way. If that's not what you mean, please clarify. > > > >> >I find that, Zero prefix constitutes a null guard band. > > >> >Futher, here, the transmitter will be sending a prefix of null data. > > >> >That is - send nothing in the guard interval and at the > > >> >receiver end, copy to the front of OFDM symbol, the received tail. > > > >> >But, I find its use in Ultrawideband (UWB) multiband OFDM. > > >> >Also refer, > > >http://www.mathworks.com/matlabcentral/fileexchange/loadFile.do?objec... > 77&objectType=file > > > >> I had to do some reading to catch up, but I think I get it now. > > > >> Yes, it will require less total transmit power, and since a goal for > > >> UWB and 802.15 devices in general is low power consumption, I suppose > > >> that helps a little bit. According to one reference I found it may > > >> also reduce ripple in the Tx spectrum a bit, but the value of that may > > >> be questionable in many cases. UWB has some pretty tight psd limits, > > >> so perhaps that was part of the motivation. > > > >> >Any ideas - why Zero Prefix is not preferred in WiMAX ? > > > >> >Karthik Balaguru > > > >> There are some significant downsides to Zero Prefix for a lot of > > >> applications. PAPR is problematic for OFDM in general, and turning > > >> the Power Amplifier off for a small amount of time in a high-power > > >> application is generally pretty difficult. The power levels in UWB > > >> are quite low since the range is miniscule compared to WiMAX, and the > > >> PA technology for UWB is evidently tolerant of the on-off cycles. > > >> Getting a WiMAX PA to do that, or any PA that's transmitting very much > > >> power, is much harder to do. Controlling the PA on/off cycle is > > >> important in keeping it from splattering energy into adjacent bands, > > >> and turning it on and off every OFDM symbol would create a lot more > > >> problems than it solves. > > > >> That's my guess, anyway. > > > >> Eric Jacobsen > > >> Minister of Algorithms > > >> Abineau Communications > > >>http://www.ericjacobsen.org > > > Eric Jacobsen > > Minister of Algorithms > > Abineau Communications > >http://www.ericjacobsen.orgHi The technique employed for equalization is to add the transient in the following guard interval back to the first CP samples of the symbol. (As there is no transient from the guard into the symbol of interest). This will be essentially same as having transmitted the CP portion in the first place, except that the receiver needs to reconstruct the CP transient using the transient it sees at the end of the symbol. The only signal processing disadvantage (apart from PA problems) I see is that now you have a small portion (CP portion) of the OFDM symbol which 2*sigma^2 noise variance, where as the remaining portion (N -CP) has the sigma^2 noise variance. This will affect BER. subbu
