Zero Prefix and the CP
Started by karthikbalaguru ●January 18, 2008
There is a technique call "time-domain synchronous OFDM" (or TDS-OFDM) that
does not have a CP. Instead of using a CP,  a PN sequence is added between
OFDM symbols. This PN sequence is used for frame synchronization,
carrier/symbol tracking and channel estimation. This is the modulation
scheme selected for digital HDTV in China.
You will find a large number of current papers in the IEEE publications.
LM
"karthikbalaguru" <karthikbalaguru79@gmail.com> wrote in message
news:5397de59-cac2-4254-9f7e-cb55ff92305f@s8g2000prg.googlegroups.com...
> Hi, > > I understand that zero prefix reduces the transmit power in OFDM based > systems. Then, why is cyclic prefix(CP) used widely and is more > popular ? > Why has WiMAX opted for Cyclic Prefix ? > Any ideas . > > Thx in advans, > Karthik Balaguru
There  is  way of reducing the 2*sigma^2 noise in the CP portion that
is added back in case of zero
suffix.
One can do a FFT of N+CP size (essentially the full received symbol)
and if we were to know the channel
do an FFT of the channel also of N+CP size with padded zeros, and do a
zero forcing equalization by simply doing
Yeq(f) = Y(f)./H(f). The IFFT of Yeq (size N+CP) would then give back
the perfectly equalized time domain signal, on which
we can do a regular N point FFT and no equalization to get back the
transmitted signal + noise.
It involves more computation, don't know if there is a easier way. But
this then throws up the possibility of equalizing any Multi-carrier
system that not just uses sin/cosine as basis but any set of
orthogonal functions as basis (Wavelet basis for ex.),
as the last FFT-N-pt was just incidental.
subbu
> Hi > > The technique employed for equalization is to add the transient in the > following guard interval > back to the first CP samples of the symbol. (As there is no transient > from the guard into the symbol of interest). This will be essentially > same as having transmitted the CP portion in the > first place, except that the receiver needs to reconstruct the CP > transient using the transient it sees at the end of the symbol. > The only signal processing disadvantage (apart from PA problems) I see > is that now you have > a small portion (CP portion) of the OFDM symbol which 2*sigma^2 noise > variance, where as > the remaining portion (N -CP) has the sigma^2 noise variance. This > will affect BER. > > subbu
On Jan 21, 6:13&#4294967295;am, subbu...@gmail.com wrote:
> There &#4294967295;is &#4294967295;way of reducing the 2*sigma^2 noise in the CP portion that > is added back in case ofzero > suffix. > > One can do a FFT of N+CP size (essentially the full received symbol) > and if we were to know the channel > do an FFT of the channel also of N+CP size with padded zeros, and do azeroforcing equalization by simply doing > Yeq(f) = Y(f)./H(f). The IFFT of Yeq (size N+CP) would then give back > the perfectly equalized time domain signal, on which > we can do a regular N point FFT and no equalization to get back the > transmitted signal + noise. > > It involves more computation, don't know if there is a easier way. But > this then throws up the possibility of equalizing any Multi-carrier > system that not just uses sin/cosine as basis but any set of > orthogonal functions as basis (Wavelet basis for ex.), > as the last FFT-N-pt was just incidental. >
Interesting info !! Karthik Balaguru
