To my knowledge there is no formal definition of block diagramming "languages" outside of such proprietary applications such as Simulink and it's ilk, or such things as ladder diagrams (which I'm going to claim isn't the same thing). One sees minor variations of block diagramming style within a discipline like control systems engineering, and there can be severe divergences between disciplines (the common x in a circle that denotes a summation block in control, for instance, usually denotes a multiplier or other frequency mixing function in a radio). This makes sense, because block diagrams seem to work best if one has a bit of flexibility with the way one shows things. It would be difficult to design one "language" that would work as well for radio as it does for control loops. None the less, do any of you know of any attempt (or success) to develop a standard, formal system of block diagramming outside of the proprietary ones mentioned? I'm writing a document that claims this ain't so; I'd like to have some hope of being correct. Thanks in advance. -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
Block Diagramming
Started by ●April 26, 2004
Reply by ●April 26, 20042004-04-26
Tim, You first have to tell us what type of block diagram you are talking about. The term is used for a vast variety of situation. But ladder diagrams is DEFINITELY not one of them. I do block diagrams to define the functionality of the process units of a complete refinery. I use them to the interconnectivity of a control network. I use them to build organization charts. The only thing all these have in common is that they connect rectangles with lines. Any standards concerning block diagrams must necessarily reflect the requirements of a given technology in a given industry. Walter. "Tim Wescott" <tim@wescottnospamdesign.com> wrote in message news:108r5ghmbpj7759@corp.supernews.com...> To my knowledge there is no formal definition of block diagramming > "languages" outside of such proprietary applications such as Simulink > and it's ilk, or such things as ladder diagrams (which I'm going to > claim isn't the same thing). One sees minor variations of block > diagramming style within a discipline like control systems engineering, > and there can be severe divergences between disciplines (the common x in > a circle that denotes a summation block in control, for instance, > usually denotes a multiplier or other frequency mixing function in aradio).> > This makes sense, because block diagrams seem to work best if one has a > bit of flexibility with the way one shows things. It would be difficult > to design one "language" that would work as well for radio as it does > for control loops. > > None the less, do any of you know of any attempt (or success) to develop > a standard, formal system of block diagramming outside of the > proprietary ones mentioned? I'm writing a document that claims this > ain't so; I'd like to have some hope of being correct. > > Thanks in advance. > > -- > > Tim Wescott > Wescott Design Services > http://www.wescottdesign.com >
Reply by ●April 27, 20042004-04-27
Walter Driedger wrote:> Tim, > > You first have to tell us what type of block diagram you are talking about. > The term is used for a vast variety of situation. But ladder diagrams is > DEFINITELY not one of them. I do block diagrams to define the functionality > of the process units of a complete refinery. I use them to the > interconnectivity of a control network. I use them to build organization > charts. The only thing all these have in common is that they connect > rectangles with lines. > > Any standards concerning block diagrams must necessarily reflect the > requirements of a given technology in a given industry. > > Walter. > > "Tim Wescott" <tim@wescottnospamdesign.com> wrote in message > news:108r5ghmbpj7759@corp.supernews.com... > >>To my knowledge there is no formal definition of block diagramming >>"languages" outside of such proprietary applications such as Simulink >>and it's ilk, or such things as ladder diagrams (which I'm going to >>claim isn't the same thing). One sees minor variations of block >>diagramming style within a discipline like control systems engineering, >>and there can be severe divergences between disciplines (the common x in >>a circle that denotes a summation block in control, for instance, >>usually denotes a multiplier or other frequency mixing function in a > > radio). >Ahh, my thoughts are being clarified already. Control systems block diagrams, as one would use to define (or illustrate) the structure of a control system so that you can intelligently extract transfer functions and/or devise controllers. My experience with these specifically pertains to diagramming the controller and plant structure in a motion control system or something similar, and with designing radios (which uses a surprisingly similar set of blocks). It would be interesting for me to get a feel for what you put in such a diagram. Given that I've generally done production systems with fixed-tune controllers there's usually enough information in my initial block diagram that I can be 90% confident that my system will be stable when I first turn it on (and 10% of the time it really is!). As you've stated before your situation is quite different, with many more unknowns at start-up. If I were in your shoes I would still indicate roughly what a plant is expected to do -- integrate, low-pass, lead-lag, etc. -- do you find it useful to do this in your environment? Unrelated question: When you are using a block diagram to define the interconnectivity of a control network, is it largely what you'd do if you were defining an office network, or is there a large amount of information that's specific to the control problem? -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
"Tim Wescott" <tim@wescottnospamdesign.com> wrote in message news:108rn5tp459jjb1@corp.supernews.com...> > Unrelated question: When you are using a block diagram to define the > interconnectivity of a control network, is it largely what you'd do if > you were defining an office network, or is there a large amount of > information that's specific to the control problem?Hehe... sometimes it *includes* designing an office network (ie. Ethernet LAN). Cameron:-)
Tim Wescott wrote:> To my knowledge there is no formal definition of block diagramming > "languages" outside of such proprietary applications such as Simulink > and it's ilk, or such things as ladder diagrams (which I'm going to > claim isn't the same thing). One sees minor variations of block > diagramming style within a discipline like control systems engineering, > and there can be severe divergences between disciplines (the common x in > a circle that denotes a summation block in control, for instance, > usually denotes a multiplier or other frequency mixing function in a > radio). > > This makes sense, because block diagrams seem to work best if one has a > bit of flexibility with the way one shows things. It would be difficult > to design one "language" that would work as well for radio as it does > for control loops. > > None the less, do any of you know of any attempt (or success) to develop > a standard, formal system of block diagramming outside of the > proprietary ones mentioned? I'm writing a document that claims this > ain't so; I'd like to have some hope of being correct. >There is a properly designed graphical programming languaga called Prograph. It was designed and implemented by a bunch of Canadian academics about 15 or so years ago and there was at least one commercial implementation of the language (on the Macintosh, which was probably the only suitable platform in that era). It is a data flow object oriented language. Googling for Prograph may still turn something up (although you'll probably also get a lot of hits for Prograph monitors !). FWIW there's also a graphical programming language built in to LabView - I think it's called "Z". There was also another block diagram type language for DSP developed at Berkeley, whose name escapes me. This was also late 1980's/early 1990's. Paul
Reply by ●April 28, 20042004-04-28
On Mon, 26 Apr 2004 23:07:09 UTC, Tim Wescott <tim@wescottnospamdesign.com> wrote:> To my knowledge there is no formal definition of block diagramming > "languages" outside of such proprietary applications such as Simulink > and it's ilk, or such things as ladder diagrams (which I'm going to > claim isn't the same thing). One sees minor variations of block > diagramming style within a discipline like control systems engineering, > and there can be severe divergences between disciplines (the common x in > a circle that denotes a summation block in control, for instance, > usually denotes a multiplier or other frequency mixing function in a radio). >There is Grafcet, a language developped by the French in the second half of the 1970s. It borrows concepts from finite-state machines and Petri nets. It is used to describe sequential systems. I use it to discuss such systems with customers, and then I derive the ladder programs for programmable logic controllers. Some PLCs of French design accept Grafcet directly. The OMRONs blissfully ignore it so I have to manually tranlate my Grafcets to ladder programs. Grafcet is a high-level language while ladder programs are assembly-like languages. -- Jean Castonguay �lectrocommande Pascal
Reply by ●May 1, 20042004-05-01
Tim, Well, I see a series of blocks connected by lines. Each block has one or more inputs and one output. Each line represents a signal, product or other 'thing' which is transferred to other point(s) in the system. Blocks carry out functions. They are the micro-plant. In the block goes an identifier and some form of transfer function. It could be Boolean, LaPlace, a computer program, the simulation of a collapsing super nova or even text such as "compares expense forms with company policies and issue instructions to accounting if approved." A block with multiple outputs is really several parallel blocks with the same inputs, i./e. "compares expense forms with company policies and returns to employee if not approved." They can be flush, adjacent if they are carried out by the same plant (or supervisor). Lines come in two varieties, information and matter/energy. The difference is that matter/energy can only go to a single destination. If it goes to more than one, two blocks need to used at the split point. One multiplies by x% and sends it one way, the other by (100-x%) and sends it another way. Information lines can split off into as many directions as required as information is not consumed. Perhaps the two lines could be called 'consumables' and 'non-consumables'. For ease of reading in particular applications, special line symbols can be used but there are fundamentally only two types. Every line carries an identification. Lines can only come together at blocks because there must be an explanation of the rules of combination. Matter/energy lines usually come together at a function block that is nothing other than a simple addition, unless, of course, chemical reactions occur. Signal lines can be added, subtracted, ANDed or merged in some other way to form a new type. (Interesting note, when I review P&IDs any time two signal lines come together without some function at the junction, I know there is a mistake. But piping can come together at any time. Matter simply adds. That is understood.) Blocks need not be rectangles. For well known math functions such as ADD/SUB, a simple circle with +s and -s on each signal line is simpler. For ANDs and ORs, I like the US MIL Boolean symbols. (I do NOT like the European custom of making every symbol a rectangle with text inside.) A system of blocks and lines is called a 'network'. A block can be drawn around an entire network and defined as a block of its own. A separate, parallel block is needed for every individual output. Now you've got me thinking. Can the concept outlined above be applied to all the various systems, including chemical processes, office organization, logic diagrams, and communications networks? Can the technique really be defined in an application independent way? Can it be attached to a graphics platform such as MS Visio? Can I get rich and famous from being involved in the development of such a product? I have trouble applying the concept to an electrical schematic at the detailed level. the block diagram is a lot more complex than the schematic. The example I'm trying to diagram consists of a battery supplying a resistor in series with two parallel resistors. Everything influences everything else! Another question: Am I describing a universal simulator? The basic logic engine handles the connectivity. Specialized packages handle transfer functions, Boolean, process models, etc. It would be hard to develop a model that handles office politics but you could still draw the diagram. Walter. "Tim Wescott" <tim@wescottnospamdesign.com> wrote in message news:108rn5tp459jjb1@corp.supernews.com...> Ahh, my thoughts are being clarified already. > > Control systems block diagrams, as one would use to define (or > illustrate) the structure of a control system so that you can > intelligently extract transfer functions and/or devise controllers. My > experience with these specifically pertains to diagramming the > controller and plant structure in a motion control system or something > similar, and with designing radios (which uses a surprisingly similar > set of blocks). > > It would be interesting for me to get a feel for what you put in such a > diagram. Given that I've generally done production systems with > fixed-tune controllers there's usually enough information in my initial > block diagram that I can be 90% confident that my system will be stable > when I first turn it on (and 10% of the time it really is!). As you've > stated before your situation is quite different, with many more unknowns > at start-up. If I were in your shoes I would still indicate roughly > what a plant is expected to do -- integrate, low-pass, lead-lag, etc. -- > do you find it useful to do this in your environment? > > Unrelated question: When you are using a block diagram to define the > interconnectivity of a control network, is it largely what you'd do if > you were defining an office network, or is there a large amount of > information that's specific to the control problem? > > Tim Wescott > Wescott Design Services > http://www.wescottdesign.com> Walter Driedger wrote:> > Tim, > > > > You first have to tell us what type of block diagram you are talkingabout.> > The term is used for a vast variety of situation. But ladder diagramsis> > DEFINITELY not one of them. I do block diagrams to define thefunctionality> > of the process units of a complete refinery. I use them to the > > interconnectivity of a control network. I use them to buildorganization> > charts. The only thing all these have in common is that they connect > > rectangles with lines. > > > > Any standards concerning block diagrams must necessarily reflect the > > requirements of a given technology in a given industry. > > > > Walter. > > > > "Tim Wescott" <tim@wescottnospamdesign.com> wrote in message > > news:108r5ghmbpj7759@corp.supernews.com... > > > >>To my knowledge there is no formal definition of block diagramming > >>"languages" outside of such proprietary applications such as Simulink > >>and it's ilk, or such things as ladder diagrams (which I'm going to > >>claim isn't the same thing). One sees minor variations of block > >>diagramming style within a discipline like control systems engineering, > >>and there can be severe divergences between disciplines (the common x in > >>a circle that denotes a summation block in control, for instance, > >>usually denotes a multiplier or other frequency mixing function in a > > > > radio). > > >
Walter Driedger wrote:> Tim, > > Well, I see a series of blocks connected by lines. Each block has one or > more inputs and one output. Each line represents a signal, product or other > 'thing' which is transferred to other point(s) in the system. > > Blocks carry out functions. They are the micro-plant. In the block goes an > identifier and some form of transfer function. It could be Boolean, > LaPlace, a computer program, the simulation of a collapsing super nova or > even text such as "compares expense forms with company policies and issue > instructions to accounting if approved." A block with multiple outputs is > really several parallel blocks with the same inputs, i./e. "compares expense > forms with company policies and returns to employee if not approved." They > can be flush, adjacent if they are carried out by the same plant (or > supervisor).This is the variety of block diagram that I'm considering.> Lines come in two varieties, information and matter/energy. The difference > is that matter/energy can only go to a single destination. If it goes to > more than one, two blocks need to used at the split point. One multiplies > by x% and sends it one way, the other by (100-x%) and sends it another way. > Information lines can split off into as many directions as required as > information is not consumed. Perhaps the two lines could be called > 'consumables' and 'non-consumables'. For ease of reading in particular > applications, special line symbols can be used but there are fundamentally > only two types. Every line carries an identification.Good distinction. Do you actually note them that way, or do you just keep in in mind? I'm working on some tutorial material that's primarily aimed at signal processing block diagrams where everything is assumed to be information, but sooner or later that signal processing is going to turn a shaft, and you can't really call it a "signal" any more. This has always bugged me on my block diagrams, where I measure reality, convert it to a number, wring it out with fancy software, apply it to a DAC and drive a big thermally sensitive motor with it. On the one hand it unifies the math to show it all the same way, but it sure makes a difference when you start sticking your hands on the real thing.> Lines can only come together at blocks because there must be an explanation > of the rules of combination. Matter/energy lines usually come together at a > function block that is nothing other than a simple addition, unless, of > course, chemical reactions occur. Signal lines can be added, subtracted, > ANDed or merged in some other way to form a new type. (Interesting note, > when I review P&IDs any time two signal lines come together without some > function at the junction, I know there is a mistake. But piping can come > together at any time. Matter simply adds. That is understood.)Unless one is the fresh water pipe and the other is waste -- then you may want to ask a question or two :).> Blocks need not be rectangles. For well known math functions such as > ADD/SUB, a simple circle with +s and -s on each signal line is simpler. For > ANDs and ORs, I like the US MIL Boolean symbols. (I do NOT like the > European custom of making every symbol a rectangle with text inside.)I've taken to using a circle for any operation that combines two numbers in a predictable way -- certainly addition and multiplication both get a circle, with a symbol inside showing which is which. I've also done this with controlled limiters where you want to take the maximum of two signals (fixed limiters get a rectangular box).> A system of blocks and lines is called a 'network'. A block can be drawn > around an entire network and defined as a block of its own. A separate, > parallel block is needed for every individual output. > > Now you've got me thinking. Can the concept outlined above be applied to > all the various systems, including chemical processes, office organization, > logic diagrams, and communications networks? Can the technique really be > defined in an application independent way? Can it be attached to a graphics > platform such as MS Visio? Can I get rich and famous from being involved in > the development of such a product?Well, that's what got _me_ started. I do control loops and (to a small extent) radios. Both radio engineers and control engineers know that a block with "f(.)" means "apply function f to the input", and "k/s" means "integrator with gain k", etc. What really set me off, though, is that if you see a circle with an X in it on a radio block diagram it's a mixer that's essentially multiplying it's inputs, but if you see the same thing in a control block diagram it's a summation, and somebody forgot to note the signs of the input lines. That means that you can severely misinterpret a block diagram unless you know what "dialect" it is. I started took to avoiding a circle with an "X" in it, but putting a "+" or a "x" in my blocks. Now I'm using a capital sigma (summation) or pi (product). Pi is admittedly obscure, but at least no one is going to look at it and assume that they know what it is!> I have trouble applying the concept to an electrical schematic at the > detailed level. the block diagram is a lot more complex than the schematic. > The example I'm trying to diagram consists of a battery supplying a resistor > in series with two parallel resistors. Everything influences everything > else!I can't find the #$%@ thing, but the "The Control Handbook" by the IEEE has an article on an alternate form of block diagramming for simulating real systems. It models _everything_ as an energy transfer, and each block has to specify what form the energy is coming in, how much is wasted, how it may be stored (or discharged), and the form of the energy coming out. Thus, for instance, a motor is nothing but a transformer that converts volts and amps into torque and RPM with a little bit of wasted heat and stored rotational energy. The nice thing about it is that the generator model is built in: turn the shaft and it becomes the input and the electrical side is now the output.> Another question: Am I describing a universal simulator? The basic logic > engine handles the connectivity. Specialized packages handle transfer > functions, Boolean, process models, etc. It would be hard to develop a > model that handles office politics but you could still draw the diagram.Just don't show it to the boss! -- snip -- -- Tim Wescott Wescott Design Services http://www.wescottdesign.com
I don't know if it is applicable here, but when I'm doing block diagrams, straight or smooth lines on the blocks indicate known functions, and wavy lines indicate unknowns or "unsures". As the system becomes better defined, wavy lines are replaced with the straight ones. On a typical four sided block, the number of sides still wavy would be indicative of how much isn't known about the block. In some cases, wavy lines will indicate information passing in an unknown way to a block. It is possible to define the four or so sides of a block to be indicative of certain standard properties. Making the appropriate side wavy lets you know what part of the block to work on or have someone else look at. Its proven handy in database and data flow diagrams. Naturally, if your systems are all well defined, then straight lines will do. Michael "Tim Wescott" <tim@wescottnospamdesign.com> wrote in message news:10969qreoafuida@corp.supernews.com...> Walter Driedger wrote: > > > Tim, > > > > Well, I see a series of blocks connected by lines. Each block has oneor> > more inputs and one output. Each line represents a signal, product orother> > 'thing' which is transferred to other point(s) in the system. > > > > Blocks carry out functions. They are the micro-plant. In the blockgoes an> > identifier and some form of transfer function. It could be Boolean, > > LaPlace, a computer program, the simulation of a collapsing super novaor> > even text such as "compares expense forms with company policies andissue> > instructions to accounting if approved." A block with multiple outputsis> > really several parallel blocks with the same inputs, i./e. "comparesexpense> > forms with company policies and returns to employee if not approved."They> > can be flush, adjacent if they are carried out by the same plant (or > > supervisor). > > This is the variety of block diagram that I'm considering. > > > Lines come in two varieties, information and matter/energy. Thedifference> > is that matter/energy can only go to a single destination. If it goesto> > more than one, two blocks need to used at the split point. Onemultiplies> > by x% and sends it one way, the other by (100-x%) and sends it anotherway.> > Information lines can split off into as many directions as required as > > information is not consumed. Perhaps the two lines could be called > > 'consumables' and 'non-consumables'. For ease of reading in particular > > applications, special line symbols can be used but there arefundamentally> > only two types. Every line carries an identification. > > Good distinction. Do you actually note them that way, or do you just > keep in in mind? I'm working on some tutorial material that's primarily > aimed at signal processing block diagrams where everything is assumed to > be information, but sooner or later that signal processing is going to > turn a shaft, and you can't really call it a "signal" any more. This > has always bugged me on my block diagrams, where I measure reality, > convert it to a number, wring it out with fancy software, apply it to a > DAC and drive a big thermally sensitive motor with it. On the one hand > it unifies the math to show it all the same way, but it sure makes a > difference when you start sticking your hands on the real thing. > > > Lines can only come together at blocks because there must be anexplanation> > of the rules of combination. Matter/energy lines usually come togetherat a> > function block that is nothing other than a simple addition, unless, of > > course, chemical reactions occur. Signal lines can be added,subtracted,> > ANDed or merged in some other way to form a new type. (Interestingnote,> > when I review P&IDs any time two signal lines come together without some > > function at the junction, I know there is a mistake. But piping cancome> > together at any time. Matter simply adds. That is understood.) > > Unless one is the fresh water pipe and the other is waste -- then you > may want to ask a question or two :). > > > Blocks need not be rectangles. For well known math functions such as > > ADD/SUB, a simple circle with +s and -s on each signal line is simpler.For> > ANDs and ORs, I like the US MIL Boolean symbols. (I do NOT like the > > European custom of making every symbol a rectangle with text inside.) > > I've taken to using a circle for any operation that combines two numbers > in a predictable way -- certainly addition and multiplication both get a > circle, with a symbol inside showing which is which. I've also done > this with controlled limiters where you want to take the maximum of two > signals (fixed limiters get a rectangular box). > > > A system of blocks and lines is called a 'network'. A block can bedrawn> > around an entire network and defined as a block of its own. A separate, > > parallel block is needed for every individual output. > > > > Now you've got me thinking. Can the concept outlined above be appliedto> > all the various systems, including chemical processes, officeorganization,> > logic diagrams, and communications networks? Can the technique reallybe> > defined in an application independent way? Can it be attached to agraphics> > platform such as MS Visio? Can I get rich and famous from beinginvolved in> > the development of such a product? > > Well, that's what got _me_ started. I do control loops and (to a small > extent) radios. Both radio engineers and control engineers know that a > block with "f(.)" means "apply function f to the input", and "k/s" means > "integrator with gain k", etc. What really set me off, though, is that > if you see a circle with an X in it on a radio block diagram it's a > mixer that's essentially multiplying it's inputs, but if you see the > same thing in a control block diagram it's a summation, and somebody > forgot to note the signs of the input lines. That means that you can > severely misinterpret a block diagram unless you know what "dialect" it > is. > > I started took to avoiding a circle with an "X" in it, but putting a "+" > or a "x" in my blocks. Now I'm using a capital sigma (summation) or pi > (product). Pi is admittedly obscure, but at least no one is going to > look at it and assume that they know what it is! > > > I have trouble applying the concept to an electrical schematic at the > > detailed level. the block diagram is a lot more complex than theschematic.> > The example I'm trying to diagram consists of a battery supplying aresistor> > in series with two parallel resistors. Everything influences everything > > else! > > I can't find the #$%@ thing, but the "The Control Handbook" by the IEEE > has an article on an alternate form of block diagramming for simulating > real systems. It models _everything_ as an energy transfer, and each > block has to specify what form the energy is coming in, how much is > wasted, how it may be stored (or discharged), and the form of the energy > coming out. Thus, for instance, a motor is nothing but a transformer > that converts volts and amps into torque and RPM with a little bit of > wasted heat and stored rotational energy. The nice thing about it is > that the generator model is built in: turn the shaft and it becomes the > input and the electrical side is now the output. > > > Another question: Am I describing a universal simulator? The basiclogic> > engine handles the connectivity. Specialized packages handle transfer > > functions, Boolean, process models, etc. It would be hard to develop a > > model that handles office politics but you could still draw the diagram. > > Just don't show it to the boss! > > -- snip -- > > -- > > Tim Wescott > Wescott Design Services > http://www.wescottdesign.com
On Sat, 01 May 2004 03:41:07 +0000, Walter Driedger wrote:> A block with multiple outputs is > really several parallel blocks with the same inputs, i./e. "compares expense > forms with company policies and returns to employee if not approved." They > can be flush, adjacent if they are carried out by the same plant (or > supervisor).[snip]> A system of blocks and lines is called a 'network'. A block can be > drawn around an entire network and defined as a block of its own. A > separate, parallel block is needed for every individual output.Why is this restriction to single outputs useful for a diagramming technique? Seems darn painful to me. Sure, if you have some proof or simulation engine underneath, then it might very well behave as though that were the case, but you wouldn't really want to have to draw it that way! Lots of common processes produce multiple outputs. Take your matter splitter, for example. Wouldn't that be more convenient as one box, with one input and two outputs, one was the k% leg and the other the (100-k)% leg? You can label it, then, as a two-way splitter. What if you'd built it as two separate gain blocks, as you described, but you wanted to wrap the whole thing inside a system block? Maybe I missed something from earlier in the thread. This is the first post in the thread that I've seen. Cheers, -- Andrew
