On Jan 27, 1:50 pm, Rick Lyons <R.Lyons@_BOGUS_ieee.org> wrote:> On Sat, 26 Jan 2008 21:30:32 -0800 (PST), dbd <d...@ieee.org> wrote: > >On Jan 24, 1:27 pm, "John E. Hadstate" <jh113...@hotmail.com> wrote: > > >> Is it possible to generate a scalar sampled data stream from a > >> sampled complex data stream without losing information? > > >> For example, can I take complex data that was sampled at 100 > >> Hz. with a bandwidth of +/- 50 Hz around 0 Hz. and convert it > >> to a scalar data stream that is sampled (effectively) at 200 Hz > >> and preserve all the information between 0 and 100 Hz? > > >Take your complex data array: > >real0, imag0, real1, imag1, real2, imag2, real3, imag3, ... > >Multiply alternate pairs by -1: > >real0, imag0, -real1, -imag1, real2, imag2, -real3, -imag3, ... > >Interpret that array as reals: > >real0, real1, real2, real3, real4, real5, real6, real7, ... > > >Since this is reversible, barring errors due to multiplying by -1, no > >information is destroyed. It is equivalent to upsampling by 2 by > >duplicating each complex sample and complex demodulating by Fs/2 > >where Fs is the original complex sampling frequency, and taking the > >real part. (Or inserting zeros and filtering by [1,1] then > >demodulating, etc.) > > (snipped by Lyons) > > > > >Dale B. Dalrymple > >http://dbdimages.com > >http;//stores.lulu.com/dbd > > Hi Dale, > your scheme is interesting. I don't > recall seeing this notion, this process, before. > (I'm gonna study this, as time allows.) > > Dale will you tell me what you mean by the > words "complex demodulating"? > Thanks. > > [-Rick-]Rick "Complex demodulation" is simply multiplying by a complex exponential time sequence. "Demodulation' from it's use to bring a frequency band of interest to DC before filtering and desampling in receivers and spectrum analyzers. harris uses "full complex heterodyne" in his "Multirate DSP" book. Dale B. Dalrymple
Generating Scalar Data from Complex Data
Started by ●January 24, 2008
Reply by ●January 28, 20082008-01-28
