Hi all, At the moment I am working on interpolation filters for bandlimited signals. I was wondering whether anyone knows if there is a generalization of the sinc based interpolation method for a recurrent sampling error. For example the sampling times could look like t = [0.99 2.02 3.03 3.99 5.02 6.03 6.99 ...] It is quite easy to compute the sinc coefficients if you want to delay all the samples by always the same fraction of the sampling period. I know how to calculate the filter coefficients for the Lagrange interpolation (which is some kind of sinc filter as well) which can do the job and works with non-uniform sampling instants. I was wondering how that is supposed to work for a sinc interpolation (for the purpose of comparison). Any help (e.g. link to a paper) would be very appreciated. Thank you, Michael
Sinc Non-uniform Filtering
Started by ●January 28, 2008
Reply by ●January 28, 20082008-01-28
Michael wrote:> Hi all, > > At the moment I am working on interpolation filters for bandlimited > signals. I was wondering whether anyone knows if there is a generalization > of the sinc based interpolation method for a recurrent sampling error. > For example the sampling times could look like > > t = [0.99 2.02 3.03 3.99 5.02 6.03 6.99 ...] > > It is quite easy to compute the sinc coefficients if you want to delay all > the samples by always the same fraction of the sampling period. I know how > to calculate the filter coefficients for the Lagrange interpolation (which > is some kind of sinc filter as well) which can do the job and works with > non-uniform sampling instants. > I was wondering how that is supposed to work for a sinc interpolation (for > the purpose of comparison). > > Any help (e.g. link to a paper) would be very appreciated.Hello Michael There is an article in the IEEE Signal Processing Magazine (Volume 24, Issue 6, November 2007) that is concerned with interpolation of recurrent non-uniformly sampled signals. For your sampling scheme, the ideal interpolation works as follows: Because the sampling times are recurrent with period 3, the ideal interpolation uses 3 kernels (instead of only one sinc-kernel for the uniform sampling case). Each kernel is used for the subsequences you get by subsampling by a factor of 3. To be more specific: assume you sampled the bandlimited signal x(t) as follows (I shifted your sampling scheme by 0.99 to start with t=0): x[0] = x(0) x[1] = x(1.03) x[2] = x(2.04) x[3] = x(3.00) x[4] = x(4.03) ... Subsampling by a factor of 3 gives three sequences: first sequence: x[0], x[3], x[6], ..., x[3 n], ... second sequence: x[1], x[4], x[7], ..., x[3 n+1], ... third sequence: x[2], x[5], x[8], ...., x[3 n+2], ... The reconstruction formula then is: infinity x(t) = sum x[3 n] k0(t-3 n) n=-infinity infinity + sum x[3 n+1] k1(t-3 n) n=-infinity infinity + sum x[3 n+2] k2(t-3 n) n=-infinity The interpolation kernels are: k0(t) = sinc(t/3) sin(pi/3 (t-1.03))/sin(pi/3 (-1.03)) sin(pi/3 (t-2.04))/sin(pi/3 (-2.04)) k1(t) = sinc((t-1.03)/3) sin(pi/3 t)/sin(pi/3 1.03) sin(pi/3 (t-2.04))/ sin(pi/3 (1.03-2.04)) k2(t) = sinc((t-2.04)/3) sin(pi/3 t)/sin(pi/3 2.04) sin(pi/3 (t-1.03))/ sin(pi/3 (2.04-1.03)) You can download some demo Matlab code and a derivation of the interoplation kernels are defined here: http://apollo.ee.columbia.edu/spm/?i=external/tipsandtricks Look for the article "Recovering Periodically-Spaced Missing Samples". The interpolation kernels are defined in equation (3) in the PDF that you can download from this link. Some references are at the end of this post. Come back if you have more questions. Regards, Andor [1] J. L. Yen, "On Nonuniform Sampling of Bandwidth-Limited Signals," IRE Trans. Circuit Theory, vol. 3, pp. 251-257, Dec. 1956. [2] P. P. Vaidyanathan, V. C. Liu, "Efficient Reconstruction of Band- Limited Sequences from Nonuniformly Decimated Versions by Use of Polyphase Filter Banks," IEEE Trans. ASSP, vol. 38, pp. 1927-1936, Nov. 1990. [3] Y. C. Eldar, A. V. Oppenheim, "Filterbank Reconstruction of Bandlimited Signals from Nonuniform and Generalized Samples," IEEE Trans. Signal Processing, vol. 48, pp. 2864-2875, Oct. 2000. [4] R. S. Prendergast, B. C. Levy, P. J. Hurst, "Reconstruction of Band- Limited Periodic Nonuniformly Sampled Signals Through Multirate Filter Banks," IEEE Trans. Circuits Systems - I: Regular Papers, vol. 51, pp. 1612-1622, Aug. 2004. [6] A. Bariska, "Recovering Periodically-Spaced Missing Samples," IEEE Signal Process. Mag., DSP Tips and Tricks column, vol. 24, Nov. 2007.
