MLE : Random Vs Deterministic
Started by junoexpress ●January 30, 2008
Hi,
I am coming across a number of papers in signal processing where they
discuss using the Maximum Likelihood method with either a
deterministic or random signal model.
I can understand the deterministic signal model: you have some known
number of stationary signals with fixed, but unknown parameters which
has an additive noise component. From a physical point of view, this
makes absolute sense to me.
OTOH, I am having a difficult time grasping the concept behind the
random signal model. Is there a simple *intuitive* explanation that
someone might be able to offer me or perhaps a decent text/paper that
explains what is behind it?
MTIA,
Matt
On Jan 31, 4:40 am, junoexpress <MTBrenne...@gmail.com> wrote:
> Hi, > > I am coming across a number of papers in signal processing where they > discuss using the Maximum Likelihood method with either a > deterministic or random signal model. > > I can understand the deterministic signal model: you have some known > number of stationary signals with fixed, but unknown parameters which > has an additive noise component. From a physical point of view, this > makes absolute sense to me. > > OTOH, I am having a difficult time grasping the concept behind the > random signal model. Is there a simple *intuitive* explanation that > someone might be able to offer me or perhaps a decent text/paper that > explains what is behind it? > > MTIA, > > Matt
Dear Matt I will explain you the probabilistic model, as I understand it, I beg the group to correct me where I am wrong. In the case of a deterministic signal, you have a fully deterministic function that determines how each element of the function domain is mapped onto the codomain. Example, the sine funcion, maps x from 0 to infinite as sin(x). This is done deterministically. In the case of a random signal, you are talking about a sampling space. One of the most simple examples is a function sin(x+phi(x)), where phi(x) is random variable that represents an aleatory phase, for this particular example. The output probability of this random variable is determined by its distribution function. In that case, we say "phi(x) has a normal distrubution", or whatever distribution. Usually these distributions have parameters by themselves, for example, the gaussian distribution has an average mu and a deviation sigma. You can find a simple introduction in http://cnx.org/content/m10649/latest/. Also, you can get the book Fundamentals of Statistical Processing, Volume I: Estimation Theory, by Steven Kay, quite complete though a little bit difficult. If I am incorrect, I beg the group to correct me. Hope this helps. Juan Pablo
Start with your own explanation of the deterministic model above, and note in particular the word "known." If you have a situation where you *know* what type of signals you will get, then deterministic methods might work. However, that's a powerful constraint. Popular methods to analyze the sum-of-sines model, like MUSIC and ESPRIT, will fail if you pretend to *know* the number of sinusoidals present, but for some reason or another get it wrong. This particular case is conveniantly handled by inserting an order estimator like Akaikes Information Criterion or Rissanen and Scwartz' Minimum Description Length in the computations. The order estimators use internal results of the MUSIC and ESPRIT routines and try to estimate the actual number of sinusoidals present. But do note that this still reqires that the sum-of-sines model is valid, which may or may not be the case. Once you start questioning the fundamental assumptions like that, and modify the philosophy (and computations) accordingly, you end up with the stochastic model. Rune
Hello.
> Start with your own explanation of the deterministic model above, > and note in particular the word "known." > > If you have a situation where you *know* what type of signals > you will get, then deterministic methods might work. However, > that's a powerful constraint. Popular methods to analyze the > sum-of-sines model, like MUSIC and ESPRIT, will fail if you > pretend to *know* the number of sinusoidals present, but for > some reason or another get it wrong. This particular case > is conveniantly handled by inserting an order estimator > like Akaikes Information Criterion or Rissanen and Scwartz' > Minimum Description Length in the computations. The order > estimators use internal results of the MUSIC and ESPRIT > routines and try to estimate the actual number of sinusoidals > present.
Rune, you can find the order in a mathematically consistent way by using the orthogonality property of MUSIC and the shift-invariance property of ESPRIT by observing that those properties only hold for the right order. Both work under some mild conditions regardless of the noise pdf. There's no need for the statistical methods that require knowledge of the noise pdf. Regards, Mads
On 31 Jan, 13:21, Mads Gr&#4294967295;sb&#4294967295;ll Christensen <m...@nospam.es.aau.dk>
wrote:
> Rune, you can find the order in a mathematically consistent way by using > the orthogonality property of MUSIC and the shift-invariance property of > ESPRIT by observing that those properties only hold for the right order. > Both work under some mild conditions regardless of the noise pdf.
The 'mild' conditions being 1) That the data comply to the sum-of-sines model 2) That the designer has specified a valid range where to search for the 'true' order Both will get you into serious trouble in real-life applications. I don't know of any real-life scenarios where these methods are actually used. Rune
>> Rune, you can find the order in a mathematically consistent way by using >> the orthogonality property of MUSIC and the shift-invariance property of >> ESPRIT by observing that those properties only hold for the right order. >> Both work under some mild conditions regardless of the noise pdf. > > The 'mild' conditions being > > 1) That the data comply to the sum-of-sines model > 2) That the designer has specified a valid range where to > search for the 'true' order > > Both will get you into serious trouble in real-life applications. > I don't know of any real-life scenarios where these methods > are actually used.
Rune, you already stated that those were the assumptions behind MUSIC and ESPRIT and those are not the conditions I was referring to. I was addressing the issue of selecting the right order, not the validity of the model. Regards, Mads
On 31 Jan, 13:30, Mads Gr&#4294967295;sb&#4294967295;ll Christensen <m...@nospam.es.aau.dk>
wrote:
> >> Rune, you can find the order in a mathematically consistent way by using > >> the orthogonality property of MUSIC and the shift-invariance property of > >> ESPRIT by observing that those properties only hold for the right order. > >> Both work under some mild conditions regardless of the noise pdf. > > > The 'mild' conditions being > > > 1) That the data comply to the sum-of-sines model > > 2) That the designer has specified a valid range where to > > &#4294967295; &#4294967295;search for the 'true' order > > > Both will get you into serious trouble in real-life applications. > > I don't know of any real-life scenarios where these methods > > are actually used. > > Rune, you already stated that those were the assumptions behind MUSIC > and ESPRIT and those are not the conditions I was referring to. I was > addressing the issue of selecting the right order, not the validity of > the model.
But selecting the order doesn't make sense unless the model fits the data. From a numerical point of view both MUSIC and ESPRIT are rather robust wrt both noise and certain types of model mismatch. I happened to work interactively with full-scale seismic surveys with arrays containing hundreds or thousands of elements. The scale of the surveys ensured that there were sufficient numbers or sensors for my array analysis, and by checking everything interactively I could see what data sets were (not) fit for analysis, as well as what parameter ranges to use. My conclusion, after having tested these methods in seismic data processing, was that the system designer needs ridiculously detailed prior knowledge of what the output of these methods would be, before specifying the analysis parameters. I got access to that information because of the redundancy of data and the interactive way of working, but I can't see any other real-life setting where these sorts of methods would work. Rune
> But selecting the order doesn't make sense unless the model > fits the data. From a numerical point of view both MUSIC > and ESPRIT are rather robust wrt both noise and certain types > of model mismatch. > > I happened to work interactively with full-scale seismic surveys > with arrays containing hundreds or thousands of elements. The > scale of the surveys ensured that there were sufficient numbers > or sensors for my array analysis, and by checking everything > interactively I could see what data sets were (not) fit for > analysis, as well as what parameter ranges to use. > > My conclusion, after having tested these methods in seismic > data processing, was that the system designer needs ridiculously > detailed prior knowledge of what the output of these methods > would be, before specifying the analysis parameters. > I got access to that information because of the redundancy > of data and the interactive way of working, but I can't see > any other real-life setting where these sorts of methods > would work. > > Rune
I know. You have written this many times before. This was not the point of my post. I just commented that you don't need to involve the methods you wrote about. I have no idea why you seek to make this discussion about something else. Both MUSIC and ESPRIT are in my experience helpful methods for analysis, modeling, etc., of speech and audio signals which is my area. There are certain problems that one needs to be aware of, though. But that goes for any method, even non-parametric ones. Regards, Mads.
On 31 Jan, 13:46, Mads Gr&#4294967295;sb&#4294967295;ll Christensen <m...@nospam.es.aau.dk>
wrote:
> I just commented that you don't need to involve the methods > you wrote about.
The AIC and the MDL? I can't imagine anything simpler for estimating the order. For MUSIC and ESPRIT they are basically weighted sums of eigenvalues of the data ovariance matrix. The hard part is not to compute them, but to ensure that the order of the covariance matrix is larger than the number of sinusoids present.
> I have no idea why you seek to make this discussion > about something else.
The details don't make sense unless one already use the correct model. 'A known model' is a far cry from a more cautious 'hypothesis testing based on statistics' approach. Which was where this thread started. Rune
>> I just commented that you don't need to involve the methods >> you wrote about. > > The AIC and the MDL? I can't imagine anything simpler for > estimating the order. For MUSIC and ESPRIT they are basically > weighted sums of eigenvalues of the data ovariance matrix. > The hard part is not to compute them, but to ensure that > the order of the covariance matrix is larger than the > number of sinusoids present.
You cannot evaluate the likelihood of those eigenvalues without making additional assumptions on the noise pdf, assumptions that are not required by ESPRIT and MUSIC. The fewer and less restrictive assumptions the better, no?
>> I have no idea why you seek to make this discussion >> about something else. > > The details don't make sense unless one already use the > correct model. 'A known model' is a far cry from a more > cautious 'hypothesis testing based on statistics' approach. > Which was where this thread started.
Where did I write anything to the contrary? It has nothing to do with what I wrote. Regards, Mads
