seeking formula for Fourier xform of Hamming family of windowing functions
Started by Unknown February 5, 2008
On Feb 6, 1:50 am, Rune Allnor <all...@tele.ntnu.no> wrote:
> While these are interesting facts, I wonder if they are relevant > from a practical point of view? > > Wouldn't it make a lot more sense to go straight for the > Parks-McClellan method if one has an application where > textbook (simplified) formulas come up short? > > Rune
P-M makes sense if: 1) Time, code and calculation resources are available to run the method after the window size is determined. AND 2) Storage is available for the P-M derived coefficients AND 3) Windowing can be performed (efficiently for the application) in the time domain. AND 4) There are no conflicting requirements (such as monotonicity) Often, these constraints are met and P-M is useful. Often they aren't. A good designer should always have P-M in the toolkit AND know when not to use it. Dale B. Dalrymple http://dbdimages.com http://stores.lulu.com/dbd
On 6 Feb, 17:01, dbd <d...@ieee.org> wrote:
> On Feb 6, 1:50 am, Rune Allnor <all...@tele.ntnu.no> wrote: > ... > > > While these are interesting facts, I wonder if they are relevant > > from a practical point of view? > > > Wouldn't it make a lot more sense to go straight for the > > Parks-McClellan method if one has an application where > > textbook (simplified) formulas come up short? > > > Rune > > P-M makes sense if: > 1) Time, code and calculation resources are available to run the > method after the window size is determined. > AND > 2) Storage is available for the P-M derived coefficients > AND > 3) Windowing can be performed (efficiently for the application) in the > time domain. > AND > 4) There are no conflicting requirements (such as monotonicity) > > Often, these constraints are met and P-M is useful. Often they aren't. > A good designer should always have P-M in the toolkit AND know when > not to use it.
Those are valid considerations regarding PM, but I still can't see why or how a modified Hamming type window would be useful? That goes for comparisions with either PM or the 'usual' window functions. Rune
On Feb 6, 8:13 am, Rune Allnor <all...@tele.ntnu.no> wrote:
> On 6 Feb, 17:01, dbd <d...@ieee.org> wrote: > > > > > On Feb 6, 1:50 am, Rune Allnor <all...@tele.ntnu.no> wrote: > > ... > > > > While these are interesting facts, I wonder if they are relevant > > > from a practical point of view? > > > > Wouldn't it make a lot more sense to go straight for the > > > Parks-McClellan method if one has an application where > > > textbook (simplified) formulas come up short? > > > > Rune > > > P-M makes sense if: > > 1) Time, code and calculation resources are available to run the > > method after the window size is determined. > > AND > > 2) Storage is available for the P-M derived coefficients > > AND > > 3) Windowing can be performed (efficiently for the application) in the > > time domain. > > AND > > 4) There are no conflicting requirements (such as monotonicity) > > > Often, these constraints are met and P-M is useful. Often they aren't. > > A good designer should always have P-M in the toolkit AND know when > > not to use it. > > Those are valid considerations regarding PM, but I still can't see > why or how a modified Hamming type window would be useful? > That goes for comparisions with either PM or the 'usual' window > functions. > > Rune
Rectangular, Von Hann and Hamming windows are all 'usual' windows that fall in the modified Hamming family. Modified Hamming windows can be appropriately applied to trade off between mainlobe width and sidelobe region rejections. The generalized Hamming family allows a finer grained tradeoff. It's easy to 'see' how they could be useful. I've just never had a reason to use any but the 3. By the same token, I've never seen an RFQ for a system including windowing in spectrum analysis that allowed for PM. I think the 'usual' windows were considered the only ones suitable to generate data for comparison to data previously generated by 'accepted' methods. That's an historical rather than a technological artifact, but a real one nonetheless. Dale B. Dalrymple Dale B. Dalrymple
On Feb 5, 1:38&#4294967295;pm, robert bristow-johnson <r...@audioimagination.com>
wrote:
> > i'm curious what is meant by "family". &#4294967295;would that be different sizes > of the "pedestal" that the Hann part of the Hamming sits upon? >
If you hold your mouth just right, you can see that a Hamming window is in the same "family" as the Blackman window and the Blackman-Harris windows. They are all derived from the same basic notion of cancelling Gibbs by adding out-of-phase ripples.
On 6 Feb, 18:11, dbd <d...@ieee.org> wrote:
> On Feb 6, 8:13 am, Rune Allnor <all...@tele.ntnu.no> wrote: > > > > > > > On 6 Feb, 17:01, dbd <d...@ieee.org> wrote: > > > > On Feb 6, 1:50 am, Rune Allnor <all...@tele.ntnu.no> wrote: > > > ... > > > > > While these are interesting facts, I wonder if they are relevant > > > > from a practical point of view? > > > > > Wouldn't it make a lot more sense to go straight for the > > > > Parks-McClellan method if one has an application where > > > > textbook (simplified) formulas come up short? > > > > > Rune > > > > P-M makes sense if: > > > 1) Time, code and calculation resources are available to run the > > > method after the window size is determined. > > > AND > > > 2) Storage is available for the P-M derived coefficients > > > AND > > > 3) Windowing can be performed (efficiently for the application) in the > > > time domain. > > > AND > > > 4) There are no conflicting requirements (such as monotonicity) > > > > Often, these constraints are met and P-M is useful. Often they aren't. > > > A good designer should always have P-M in the toolkit AND know when > > > not to use it. > > > Those are valid considerations regarding PM, but I still can't see > > why or how a modified Hamming type window would be useful? > > That goes for comparisions with either PM or the 'usual' window > > functions. > > > Rune > > Rectangular, Von Hann and Hamming windows are all 'usual' windows that > fall in the modified Hamming family. Modified Hamming windows can be > appropriately applied to trade off between mainlobe width and sidelobe > region rejections. The generalized Hamming family allows a finer > grained tradeoff. It's easy to 'see' how they could be useful. I've > just never had a reason to use any but the 3.
OK, let me rephrase: What would the justification be for using an 'unusual' Hamming-type window and not one of the 'usual' ones or a PM filter?
> By the same token, I've > never seen an RFQ for a system including windowing in spectrum > analysis that allowed for PM. I think the 'usual' windows were > considered the only ones suitable to generate data for comparison to > data previously generated by 'accepted' methods. That's an historical > rather than a technological artifact, but a real one nonetheless.
Agreed. Rune
M.Aramini@verizon.net wrote:
> > On second thought, there is supposed to be a null at alpha=5*pi > (*not*, as I erroneously > previously posted, at 5*pi/2) when a=25/46. Substituting 5*pi for > alpha and 25/46 for a > in the formula for F(alpha) in my previous posting does in fact yield > 0. >
If by Fourier transform you are asking about DFT of your Window function where the DFT length and the Window length are the same and the window function consists of the sum of a constant and a sinusoid (that sinusoid has a period that is the same as the window length and DFT length) then the result of your DFT better be all zeroes except the 3 bins centered at f0. -jim
> ... > OK, let me rephrase: What would the justification be for > using an 'unusual' Hamming-type window and not one of > the 'usual' ones or a PM filter? > ... > Rune
A system requirement for a mode with sidelobe rejection that didn't match a 'usual' and a desire to minimize the mainlobe width subject to that constraint in an implementation with identical structure to the 'usual' implementation structure. B&K did this at the 5 coefficient point with some instruments by implementing all windows, including a 'Kaiser' window by approximating with a 5 coefficient kernel, including user specified windows. Dale B. Dalrymple
On Feb 6, 9:26 am, Jubilation_T_Cornpone_...@hotmail.com wrote:
> On Feb 5, 1:38 pm, robert bristow-johnson <r...@audioimagination.com> > wrote:
> If you hold your mouth just right, you can see that a Hamming window > is in the same "family" as the Blackman window and the Blackman-Harris > windows. They are all derived from the same basic notion of > cancelling Gibbs by adding out-of-phase ripples.
If I open my mouth far enough I would see these as examples of the odd number of coefficient subset of the 'small frequency domain kernel' (also called 'cosine-summed') windows. Von Hann set the response at the adjacent bin center to 0.0 with two coefficients. Blackman extended the bin center zeroing to 2 and more adjacent bins. Hamming did an optimization to minimize the peak sidelobe level with 2 coefficients. Harris considered optimizations to minimize peak sidelobe level and to maximize sidelobe rolloff rate. As Nuttal pointed out, the max rolloff case has a closed form solution and harris's 4 term sidelobe minimizing result was off by about 6dB. Other authors have minimized sidelobes with more terms. Every Tom Dick and Harry who comes along feels free to apply some mix of names to ever more general families. I try to limit the blame to what the named person actually did, and use functionally related terms if I have the choice. While many people call 0.42, 0.5, 0.08 the Blackman coefficients, I try to think of them as '2 digit rounded three term Blackman', but try to sell that. Tukey and Blackman published these coefficients in the Bell System Technical Journal in 1958 as 'R. Blackman's not very serious proposal'. Harris misstated 3 term exact Blackman sidelobe rejection as 17 dB worse than the real value and people have taken Blackman's joke seriously ever since. Some authors have noted that von Hann and Blackman's choice of bin center was not the peak of the sinc response being canceled and improved on Blackman's initial ad hoc choice by canceling at the peak. That's still ad hoc, not optimal. But sidelobe canceling is not the only application of cosine-summed windows. There are also flattop window designs and others in this form. Dale B. Dalrymple
On Wed, 6 Feb 2008 09:26:06 -0800 (PST),
Jubilation_T_Cornpone_CSA@hotmail.com wrote:
>On Feb 5, 1:38&#4294967295;pm, robert bristow-johnson <r...@audioimagination.com> >wrote: >> >> i'm curious what is meant by "family". &#4294967295;would that be different sizes >> of the "pedestal" that the Hann part of the Hamming sits upon? >> > >If you hold your mouth just right, you can see that a Hamming window >is in the same "family" as the Blackman window and the Blackman-Harris >windows. They are all derived from the same basic notion of >cancelling Gibbs by adding out-of-phase ripples.
Hello Jubilation, don't be too hard on Robert B-J. He's a DSP expert, pure and simple, and he deserves some respect. As for holding our mouths just right, we generally hold our mouths in just the right position in which to pour beer. The Hamming window is in the "class" of windows formally called "cos^a(x)" windows, which includes Hanning (von Hann), Hamming, and Blackman. Are you a fan of Al Capp? I'll bet that %95 of the guys here do not know who Jubilation_T_Cornpone is. (Of course, Jerry Avins will know.) [-Rick-]
Rick Lyons wrote:
> Are you a fan of Al Capp? I'll bet that %95 of the > guys here do not know who Jubilation_T_Cornpone is. > (Of course, Jerry Avins will know.) > > [-Rick-]
When we fought the Yankees and annihilation was near, Who was there to lead the charge, that took us safe to the rear? Why it was Jubilation T. Cornpone. Old "Toot your own horn pone", Jubilation T. Cornpone, a man who knew no fear. When we almost had 'em but the issue still was in doubt, Who suggested the retreat that turned it into a rout? Why it was Jubilation T. Cornpone. Old "Tattered and Torn Pone", Jubilation T. Cornpone, he kept us hidin' out. With our ammunition gone and faced with utter defeat, Who was it that burned the crops and left us with nothin' to eat? Why it wuz Jubilation T. Cornpone. Old "September Morn-pone", Jubilation T. Cornpone, the pants blown off his seat. Thank you, Ray Charles. Jerry -- Engineering is the art of making what you want from things you can get. &#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;&#4294967295;
