Hi, I would like to design use an equalizer for improving the performance of 4fsk-frequency hopping system in rayleigh fading, I ve seen matlab functions but they all are for linear modulations or is there any function for non linear modulations??. Can any one please guide me on this issue? Is there any particular technique that is useful for this case?? thanks
Equalization for FH-4FSK system
Started by ●February 5, 2008
Reply by ●February 5, 20082008-02-05
On Feb 5, 3:41 pm, "furqee" <fur...@ieee.org> wrote:> Hi, I would like to design use an equalizer for improving the performance > of 4fsk-frequency hopping system in rayleigh fading, I ve seen matlab > functions but they all are for linear modulations or is there any function > for non linear modulations??. Can any one please guide me on this issue? Is > there any particular technique that is useful for this case?? thanksTake a look at the Constant Modulus Algorithm (CMA). John
furqee wrote:> Hi, I would like to design use an equalizer for improving the performance > of 4fsk-frequency hopping system in rayleigh fading,The whole point of the frequency hopping is to decorrelate the fading. Hence every hop has to be equalized independently of the other hops.> I ve seen matlab > functions but they all are for linear modulations or is there any function > for non linear modulations??.Despite of the popular belief, Matlab is not a replacement for the brains.> Can any one please guide me on this issue? Is > there any particular technique that is useful for this case?? thanksTraditional equalizers are not very usefull here because the equalization has to be performed for each hop. The simplest algorithm would be running the LMS by several iterations through the hop; there could be much better solutions depending on the particulars. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Reply by ●February 8, 20082008-02-08
Thanks for replying,John and Vladimir, I have just seen few IEEE papers on the equalization of nonlinear modulations like CPM,FSK etc. What I intend to do in matlab now is to first dehop FH signal to baseband so that its just complex vector having 4 tones of quaternary CPFSK, with continous phase in each hop and then apply equalizer on each hop duration, would you kindly tell me whether its right? and is there any difference between equalizing a simple CP-4FSK signal and equalizing a FH-4FSK after dehopping other than we have to apply equalizer to each hop??> > >furqee wrote: > >> Hi, I would like to design use an equalizer for improving theperformance>> of 4fsk-frequency hopping system in rayleigh fading, > >The whole point of the frequency hopping is to decorrelate the fading. >Hence every hop has to be equalized independently of the other hops. > >> I ve seen matlab >> functions but they all are for linear modulations or is there anyfunction>> for non linear modulations??. > >Despite of the popular belief, Matlab is not a replacement for thebrains.> >> Can any one please guide me on this issue? Is >> there any particular technique that is useful for this case?? thanks > >Traditional equalizers are not very usefull here because the >equalization has to be performed for each hop. The simplest algorithm >would be running the LMS by several iterations through the hop; there >could be much better solutions depending on the particulars. > > >Vladimir Vassilevsky >DSP and Mixed Signal Design Consultant >http://www.abvolt.com > > >
Reply by ●February 9, 20082008-02-09
On Feb 5, 12:41 pm, "furqee" <fur...@ieee.org> wrote:> Hi, I would like to design use an equalizer for improving the performance > of 4fsk-frequency hopping system in rayleigh fading, I ve seen matlab > functions but they all are for linear modulations or is there any function > for non linear modulations??. Can any one please guide me on this issue? Is > there any particular technique that is useful for this case?? thanksIf the 4fsk system is tightly constrained by bandwidth (for maximal spectral efficiency), then a MLSD works well. An MLSD for non-coherent detection will not have the performance of a coherent receiver but will still be beneficial and a lot less complex. This was what was used in Proxim's 10 Mbit WLAN frequency hopping system (homerf 2.0). Without knowing the modulation index (h) of the 4fsk, though it is hard to generalise
