Upsampling real-time data using DFT
Started by John E. Hadstate ●February 12, 2008
Given a complete set of data, one technique for interpolating
it is to one compute a DFT of the data set, pad the DFT
coefficients with enough zeroes to produce the required amount
of up-sampling, and then iDFT the padded spectrum to produce
the interpolated data.  This technique has been known for a
long time (I originally found it in Gold and Rader, "Digital
Processing of Signals" (c) 1969), and is discussed, along with
some of it's limitations in Steven Smith's text, "Digital
Signal Processing."
It is not clear that this technique is applicable for
up-sampling very large data sets (streaming real-time data, for
example) because it is unclear that one can legitimately
process segments of data and then "knit the segments together."
I have developed an ad-hoc technique for "knitting the segments
together" that appears to work well in the few applications in
which I've tried it.  (It works equally well for up-sampling
complex data or scalar data.) I cannot justify it
mathematically, and I am not sure how far it can be abused
without breaking.
In summary, the algorithm is as follows:
1.  Break the data stream into segments of P samples where P is
an even number.  In my experiments, I tested P=16 and P=65536
samples.  Successive segments of incoming data will overlap
each other by 50% (P/2).  Initialize a "save buffer" of N*P/2
points to 0, where N is the desired up-sampling ratio.
2.  For each segment, compute a DFT.  Pad the DFT coefficients
with enough zeroes to yield a total of N*P coefficients.  I
used a ratio of N=2 for all of my testing.
3.  Inverse-DFT the padded coefficients to yield a new segment
of N*P interpolated samples.
4.  Multiply the N*P interpolated samples of the new segment by
a window function.  The Window function I used is
W(K)=[1-cos(2*pi*K/(N*P))]/2 where K=0,1,...,(N*P-1).
5.  Divide the windowed data into two equal sub-segments, each
of length N*P/2.  Add the first sub-segment to the N*P/2 points
in the "save buffer" (initialized to zeroes in step 1).  Append
these N*P/2 points to the output stream.
6.  Copy the second sub-segment of windowed data to the "save
buffer", overwriting what was previously there.  Discard P/2
points from the incoming data stream and get the next P-point
segment.  Return to step 2.
I can't prove that this method is mathematically sound and I
would be interested in hearing from other practitioners who try
it.  I would like to know about any problems you encounter as
well as success stories and any analytical results you can
derive regarding what is actually happening.  I have put it to
work as the X2 upsampler in an application where I'm converting
complex data to scalar data.  I used no low-pass filtering on
the upsampled data, and it appears that there were no
frequency-domain images generated during upsampling (as I
expected).
On Tue, 12 Feb 2008 21:55:21 -0500, "John E. Hadstate"
<jh113355@hotmail.com> wrote:
>Given a complete set of data, one technique for interpolating >it is to one compute a DFT of the data set, pad the DFT >coefficients with enough zeroes to produce the required amount >of up-sampling, and then iDFT the padded spectrum to produce >the interpolated data. This technique has been known for a >long time (I originally found it in Gold and Rader, "Digital >Processing of Signals" (c) 1969), and is discussed, along with >some of it's limitations in Steven Smith's text, "Digital >Signal Processing."
Hi John, will you tell me which of Steve Smith's books you are referring to? Thanks. (If you actually have a copy of the Gold & Rader book, hold onto that guy!!) (snipped by Lyons) John, your scheme sounds like a combination of the "weighted overlap and add" method of spectrum analysis and "fast convolution" FIR filtering. (Although I'm not an expert on either of those processes.) In any case I hope to model your process using MATLAB, as time allows, to see what it can teach me. Regards, [-Rick-]
On 13 Feb, 03:55, "John E. Hadstate" <jh113...@hotmail.com> wrote:
> Given a complete set of data, one technique for interpolating > it is to one compute a DFT of the data set,...
Well, the outline of your method seems very reasonable; problems with the details wouldn't show up until one starts using the thing. I would go on using this method but be *very* aware of these caveats and uncertainties you mention. If any problems ever occur with the method, checking if any of these factors might be the cause would be high on my list for debugging. But until then, just use the method and accumulate experience with it. Rune
"Rick Lyons" <R.Lyons@_BOGUS_ieee.org> wrote in message
news:9138r35na0bhfobed2mc8fqrd5bq94sod7@4ax.com...
> On Tue, 12 Feb 2008 21:55:21 -0500, "John E. Hadstate" > <jh113355@hotmail.com> wrote: > >>Given a complete set of data, one technique for interpolating >>it is to one compute a DFT of the data set, pad the DFT >>coefficients with enough zeroes to produce the required >>amount >>of up-sampling, and then iDFT the padded spectrum to produce >>the interpolated data. This technique has been known for a >>long time (I originally found it in Gold and Rader, "Digital >>Processing of Signals" (c) 1969), and is discussed, along >>with >>some of it's limitations in Steven Smith's text, "Digital >>Signal Processing." > > Hi John, > will you tell me which of Steve Smith's books > you are referring to? Thanks. > (If you actually have a copy of the Gold & Rader book, > hold onto that guy!!)
Hi, Rick. I didn't realize that Steven Smith was so prolific. The particular book I have is: Smith, Steven W., Digital Signal Processing (A Practical Guide...), (c) 2003, ISBN-10: 0-7506-7444-x, ISBN-13: 978-0-7506-7444-7 I have two copies of Gold and Rader (some would call that an "embarrasment of riches"). I found the second copy on some sort of used book network.
> > (snipped by Lyons) > > John, your scheme sounds like a combination of the > "weighted overlap and add" method of spectrum analysis > and "fast convolution" FIR filtering. (Although I'm > not an expert on either of those processes.) > In any case I hope to model your process using MATLAB, > as time allows, to see what it can teach me. >
Thank you. That may lead to a breakthrough in formalizing the description. Best of luck. The somewhat disconnected thought processes that led to this design were: (1) In the interpolated time-domain data, it appears that all the even samples (starting at 0) take on the values of the original data. The odd samples are, of course, interpolated. (This means that the last point, an odd point, is actually extrapolated.) (2) Since the even values are unchanged, it ought to be possible to combine them by weighted adding and not change anything about their contribution. Adding interpolated samples is similar to averaging them, so the result should be "smoother". (3) When joining adding overlapped interpolated segments, it seams like it should be done in such a way as to fade-out the previous segment while fading-in the new segment. It turns out that the window function I chose has the property that the trailing edge of the previous window and the leading edge of the new window sum to 1. (4) Because the input segments are overlapped by 50%, the non-interpolated (even numbered) input samples contribute twice to their corresponding output values, once with a heavier weight and once with a lighter weight, and the sum of their weights is 1. Yet to be determined is what happens if we replace the window function with a constant multiplier.
> Regards, > [-Rick-] >
Thanks again for your help.
"John E. Hadstate" <jh113355@hotmail.com> wrote in message
news:13r85um4m24i6aa@news.supernews.com...
> > Yet to be determined is what happens if we replace the window > function with a constant multiplier. >
I did some experiments today in which I compared a segment size of 16 with a segment size of 64K and a rectangular overlap window with the offset cosine window that I originally used: W(k)=[1-cos(2*pi*k/(N*P))] for k=0,1,...,(N*P-1). When I compared the spectra of the upsampled files, the files processed with the cosine windows looked very similar except that the file processed with 16-sample segments had a somewhat reduced S/N ratio compared to the file processed with 64K segments. The spectrum of the file processed with 64K segments was virtually indistinguishable from the original file except for the effect of sample rate changes. The spectrum of the file processed with the rectangular window and a 16-sample segment size was full of "sniglets" and images that didn't belong there. These were not apparent when the file was processed with a rectangular window and a 64K segment size. However, the spectrum of the file processed with a 64K segment did have a lot of artifacts ("grass") at both ends of the spectrum. These were about 40 dB down from the signal peaks. One other issue surfaced as well. The files processed with 16-sample segments required several hours each. The same files processed with 64K segments required a few minutes each. In summary: Seg Size Window Spectral Quality ========================================= 16 Rectangular Very bad spurs and images ========================================= 16 1-cos() Noisy but other- wise faithful to original ========================================= 64K Rectangular Less Noisy with spectral artifacts at both ends ========================================= 64K 1-cos() Very good =========================================
Hi John,
I think you are on the right track, but may be able to improve the
algorithm.  You comment about the last odd point being an extrapolation is
the key.  It is not an extrapolation-- it is an interpolation.   The DFT
views the time domain signal as being circular, that is, point N-1 is
positioned next to point 0, just as point 105 is positioned next to point
106.  So this last odd point is a Fourier interpolation at location N-0.5
in the sequence:  ...N-3, N-2, N-1, 0, 1, 2 ... .   Of course, this isn't
what you want-- you would like it to be an interpolation between the last
point of this segment and the first point of the next segment.  In short,
the ends of the interpolated sequence are contaminated by this wrap around
effect.
In your solution you break the signal into overlapping segments, and then
add the weighted-interpolated segments together.  This reduces the effect
of the end-contamination by dilution, with bad points being added to good
points.  Here's the suggestion:  Retain the center one-half of each
interpolated segment, and discard the 1/4 on each end.  You can then piece
them together, forming an interpolated signal with all "good" points.  Let
me know if it works!
Regards,
Steve
Hi John,
effect.
Regards,
Steve
