Pulse Shaping using RRC filter (again)
Started by Bob ●February 20, 2008
Eric Jacobsen wrote:
> On Thu, 21 Feb 2008 02:35:33 -0800 (PST), Bob <stenasc@yahoo.com> > wrote: > >> On 21 Feb, 08:14, c...@claysturner.com wrote: >>> On Feb 20, 4:38 pm, Bob <sten...@yahoo.com> wrote: >>> >>> >>> >>> >>> >>>> On 20 Feb, 20:41, Mark <makol...@yahoo.com> wrote: >>>>>> So now I see something,,,notice the small peak to the left of the >>>>>> cursor on the second and fourth traces. Should this not be the same as >>>>>> the peaks beside it? >>>>> remember you are looking at the RRC filter..which is only 1/2 the >>>>> picture >>>>> pass this output though another RRC filter so that you have the full >>>>> RC filter and you will see what the receiver sees... >>>>> the Rx and Tx have matched filters and the NYquist filter is both of >>>>> them in cascade, >>>>> you are looking 1/2 way through the cascade.. >>>>> Mark >>>> Hi Mark, >>>> The pulses you see on the first link is what happens when I pass the >>>> data through the RRC on the TX link. On the demod side links 2 and 3 >>>> are when the data from the modulator is passed through idential RRCs. >>>> So, in effect I already have the RC response at the receiver. But is >>>> it correct...that's what I would like to know? >>>> Bob- Hide quoted text - >>>> - Show quoted text - >>> Hello Bob, >>> >>> The feeding of pulses into the RRC filter (via convolution) assumes >>> your pulses become Kronecker deltas. Don't feed rectangular pulses, >>> instead feed spikes into the RRC filter. Then after going through two >>> of these in sucession, you will see a nice looking signal. You are >>> currenly getting a bunch of ringing resulting from the rectangular >>> pulse's response comingled (convolved) with the RRC's response. For >>> simplifying the testing, just try an RC filter and look at its output. >>> Two RRCs convolved is an RC. Try it! >>> >>> IHTH, >>> >>> Clay- Hide quoted text - >>> >>> - Show quoted text - >> Hi Clay, >> >> I did already try it. I fed the output of one RRC into another and >> you're correct...I did get a nice RC pulse output. >> In the test case, this was done for spikes well seperated. However, >> for real test data, I don't have much choice as I have strings of 1's >> and in most cases very few 0's between them. In this case, what are my >> options? >> >> Regards >> Bob > > I haven't looked at your latest plots, but I'm a little confused by > your last statement. How many samples per symbol are there going > into the transmit RRC filter? If the answer is one, then you don't > have to worry about the rectangular symbol problem. If the answer is > more than one, then only one of those samples per symbol should be > non-zero if you want to avoid an additional sinx/x response in the > filtering.
That really cuts down on the compute too. Isn't it nice when the right approach is actually the lowest compute one. :-) Steve
On 21 Feb, 18:13, Randy Yates <ya...@ieee.org> wrote:
> Bob <sten...@yahoo.com> writes: > > [...] > > Hi Eric, > > > Hi Eric, > > Multipath? > -- > % &#4294967295;Randy Yates &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295;% "So now it's getting late, > %% Fuquay-Varina, NC &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295;% &#4294967295; &#4294967295;and those who hesitate > %%% 919-577-9882 &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295;% &#4294967295; &#4294967295;got no one..." > %%%% <ya...@ieee.org> &#4294967295; &#4294967295; &#4294967295; &#4294967295; &#4294967295; % 'Waterfall', *Face The Music*, ELOhttp://www.digitalsignallabs.com
I and Q branches :)
