FFt phases: software for a neophyte?
Started by SarahB ●February 20, 2008
I'm a biologist and I'm trying to understand why a particular species of
insect responds to some temporal patterns in pulse trains but not to
others.  I've identified 2 peaks in the FFt that must be present and of
similar magnitude to generate a strong response from the insects; if a
stimulus is missing one peak, or if the second peak is lower than the
first, the response of the animal drops.  My problem is that I have a few
outliers in which signals were unattractive despite having the correct
frequency attributes described above.  I'm wondering whether the phases of
the two critical frequency components might be important.  The bioacoustic
software I'm using (Bat Sound) provides neither a phase plot nor the real
and imaginary numbers I'd need to calculate the phases myself.  Can anyone
suggest some simple-to-use software that will either provide the phase
information, or provide the numbers needed to calculate the phases? I have
no background in engineering/computer science and don't know how to use
Matlab. Thanks for your help.
On 20 Feb, 21:57, "SarahB" <bus...@missouri.edu> wrote:
> I'm a biologist and I'm trying to understand why a particular species of > insect responds to some temporal patterns in pulse trains but not to > others. &#4294967295;I've identified 2 peaks in the FFt that must be present and of > similar magnitude to generate a strong response from the insects; if a > stimulus is missing one peak, or if the second peak is lower than the > first, the response of the animal drops. &#4294967295;My problem is that I have a few > outliers in which signals were unattractive despite having the correct > frequency attributes described above. &#4294967295;I'm wondering whether the phases of > the two critical frequency components might be important. &#4294967295;The bioacoustic > software I'm using (Bat Sound) provides neither a phase plot nor the real > and imaginary numbers I'd need to calculate the phases myself. &#4294967295;Can anyone > suggest some simple-to-use software that will either provide the phase > information, or provide the numbers needed to calculate the phases? I have > no background in engineering/computer science and don't know how to use > Matlab. Thanks for your help.
Given the nature of your problem and your stated background and knowledge of computers, I would suggest that USENET might not be the best place to search for help. You might find it more productive to find somebody who has the necessary skills with data analysis and computers and who can work along side with you on a daily basis. Your email address indicates you are with some university, so I would suggest that you try to find somebody in the maths statistics department who works with time series analysis, or somebody in the electrical engineering department who works with DSP. Rune
On Feb 20, 12:57 pm, "SarahB" <bus...@missouri.edu> wrote:
> I'm a biologist and I'm trying to understand why a particular species of > insect responds to some temporal patterns in pulse trains but not to > others. I've identified 2 peaks in the FFt that must be present and of > similar magnitude to generate a strong response from the insects; if a > stimulus is missing one peak, or if the second peak is lower than the > first, the response of the animal drops. My problem is that I have a few > outliers in which signals were unattractive despite having the correct > frequency attributes described above. I'm wondering whether the phases of > the two critical frequency components might be important. The bioacoustic > software I'm using (Bat Sound) provides neither a phase plot nor the real > and imaginary numbers I'd need to calculate the phases myself. Can anyone > suggest some simple-to-use software that will either provide the phase > information, or provide the numbers needed to calculate the phases? I have > no background in engineering/computer science and don't know how to use > Matlab. Thanks for your help.
First some questions: Are the two frequency components of interest related by an integer ratio? Or are the initiations of the two pulse trains synchronized to each other in some manner and of finite duration?
SarahB wrote:
> I'm a biologist and I'm trying to understand why a particular species of > insect responds to some temporal patterns in pulse trains but not to > others. I've identified 2 peaks in the FFt that must be present and of > similar magnitude to generate a strong response from the insects; if a > stimulus is missing one peak, or if the second peak is lower than the > first, the response of the animal drops. My problem is that I have a few > outliers in which signals were unattractive despite having the correct > frequency attributes described above. I'm wondering whether the phases of > the two critical frequency components might be important. The bioacoustic > software I'm using (Bat Sound) provides neither a phase plot nor the real > and imaginary numbers I'd need to calculate the phases myself. Can anyone > suggest some simple-to-use software that will either provide the phase > information, or provide the numbers needed to calculate the phases? I have > no background in engineering/computer science and don't know how to use > Matlab. Thanks for your help. > >
I note that Mizzou has both "Computer Science" and "Electrical & Computer Engineering" degree programs so Rune suggestion is good. I would also suggest looking at _The Scientist and Engineer's Guide to Digital Signal Processing_ ( www.dspguide.com ) for some general background. One advantage you'll find is if you jump into it in the middle and your missing particular background he frequently tells you where in the book to go. For your problem, you will want to look at "Chapter 12: The Fast Fourier Transform" ( www.dspguide.com/ch12.htm ), specifically "FFT Programs" ( www.dspguide.com/ch12/3.htm ). It gives stand alone BASIC code with the real and imaginary components in separate arrays to ease presenting phase data as you wish. I'm not familiar with Matlab, but use Scilab ( www.scilab.org ), a free alternative. Feel free to ask questions if you get stuck with cross-discipline communication problems. My email is valid.
Hi Sarah,
Also, there is prewritten FFT program on my website that reads a text
file, calculates the FFT, and writes the results to a text file.  You
could
view the resulting input and output in Excel.  Run the program for
instructions.  Feel free to e-mail me if you have problems getting it
running.
Regards,
Steve
http://www.dspguide.com/download.htm
Yes, the higher frequency peak is the first harmonic of the lower frequency
peak .  It's actually a single train of pulses, but each pulse contains two
rise-times: the first rise-time takes the pulse to 75% amplitude, then
there's a plateau before the amplitude rises to 100% (followed by a second
plateau and a single fall-time).  I'm going to look into the suggestions
made by the others.  Thanks for the help.
SteveSmith wrote:
> Hi Sarah, > Also, there is prewritten FFT program on my website that reads a text > file, calculates the FFT, and writes the results to a text file. You > could view the resulting input and output in Excel.
Now that would be a bit roundabout. If you already use Excel, you might as well calculate the FFT in Excel. Regards, Andor
Hi Andor,
You can calculate the FFT in Excel?  Cool-- I didn't know that!
Regards,
Steve
SteveSmith wrote:
> Hi Andor, > You can calculate the FFT in Excel? &#4294967295;Cool-- I didn't know that!
I have a German version of Excel 2000 on this computer. I found the FFT function under "Extras -> Analyse Funktionen -> Fourieranalyse". Excel can even handle complex numbers, using a bunch of functions with bizarre names ... For example "imabs()" computes the absolute value of a complex number, whereas "abs()" computes the absolute value of a real number. Regards, Andor
Thanks a lot-- very good to know.
Steve
