Steve Underwood wrote:> There is probably a 10000:1 ratio between the number of people who can > quote you a few concepts from their college course on DSP, and those who > can build a real physical system. However, its pretty much the same > ratio between those who can quote the course and those that put together > a real working application on a PC. > > Its real ability that is priceless.Don't be lost in reverie. The real abilities have their value, however it is not priceless by any means :) Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Free or low-cost DSP tools for the hobbyist?
Started by ●February 22, 2008
Reply by ●February 25, 20082008-02-25
Vladimir Vassilevsky <antispam_bogus@hotmail.com> writes:> Steve Underwood wrote: > > >> There is probably a 10000:1 ratio between the number of people who >> can quote you a few concepts from their college course on DSP, and >> those who can build a real physical system. However, its pretty much >> the same ratio between those who can quote the course and those that >> put together a real working application on a PC. >> >> Its real ability that is priceless. > > Don't be lost in reverie. The real abilities have their value, however > it is not priceless by any means :)I agree. The engineer who can be adept simultaneously in engineering, math, business/economics acumen, hardware, software, theory, implementation, design, test, and integration is the real winner. I'm having a hard time being adept (and maintaining it) in any one!... -- % Randy Yates % "Bird, on the wing, %% Fuquay-Varina, NC % goes floating by %%% 919-577-9882 % but there's a teardrop in his eye..." %%%% <yates@ieee.org> % 'One Summer Dream', *Face The Music*, ELO http://www.digitalsignallabs.com
Vladimir Vassilevsky wrote:> > > Steve Underwood wrote: > > >> There is probably a 10000:1 ratio between the number of people who can >> quote you a few concepts from their college course on DSP, and those >> who can build a real physical system. However, its pretty much the >> same ratio between those who can quote the course and those that put >> together a real working application on a PC. >> >> Its real ability that is priceless. > > Don't be lost in reverie. The real abilities have their value, however > it is not priceless by any means :)Quite true. I only used that word, as its the one the original poster used. Its more accurate to say it has a high value, though an all too often unrecognised one. Steve
Reply by ●February 26, 20082008-02-26
Steve Underwood wrote:> Vladimir Vassilevsky wrote: >> Steve Underwood wrote: >> >>> There is probably a 10000:1 ratio between the number of people who >>> can quote you a few concepts from their college course on DSP, and >>> those who can build a real physical system. However, its pretty much >>> the same ratio between those who can quote the course and those that >>> put together a real working application on a PC. >>> >>> Its real ability that is priceless. >> >> >> Don't be lost in reverie. The real abilities have their value, however >> it is not priceless by any means :) > > > Quite true. I only used that word, as its the one the original poster > used. Its more accurate to say it has a high value, though an all too > often unrecognised one.The common corporate problem is that those who can judge about the abilities of a person do not have enough of power to encourage that person. This creates a situation of the adverse selection. So the creative folks either have start on their own or put their zeal into hobbies, contributing to the free opensource world. Vladimir Vassilevsky DSP and Mixed Signal Design Consultant http://www.abvolt.com
Steve Underwood <steveu@dis.org> wrote in news:fpo2oh$11o$1 @nnews.pacific.net.hk:> What you do mostly, though, is > spend time with the messy ins and outs of a chip that will be obsolete > before graduation. >You'll learn how to learn how to interface with a chip, and that experience will be quite valuable for the next chip. You'll learn how to interface with the real world. You'll learn what the drivers on data acquisition boards are really doing, without Windows hiding all the good stuff that you only need to know if a driver isn't doing what you want it to do. Couple this with a good knowledge of digital signal processing technique, and tag on the fact that the whole shebang demonstrates in spades your ability to teach yourself, your motivation, the fact that you're a "self starter". Go for it. It will pay for itself. -- Scott Reverse name to reply
Scott Seidman wrote:> Steve Underwood <steveu@dis.org> wrote in news:fpo2oh$11o$1 > @nnews.pacific.net.hk: > >> What you do mostly, though, is >> spend time with the messy ins and outs of a chip that will be obsolete >> before graduation. >> > > You'll learn how to learn how to interface with a chip, and that experience > will be quite valuable for the next chip. You'll learn how to interface > with the real world. You'll learn what the drivers on data acquisition > boards are really doing, without Windows hiding all the good stuff that you > only need to know if a driver isn't doing what you want it to do.How accurate is that when you really get down to it? Most kits have all the hardware interfacing done for 90% of the things people will try. They probably have some basic interface code, too. If you built a board from scratch you would start to find all the pain involved in getting a nice quiet layout from an economical 2 layer board, and other nastiness of getting a real application out the door. However, the time needed to do that probably makes it a no-no for most people. Especially since the learning process will probably require multiple spins of the board. I think that in the end I think the experience of using kits is a pretty sterile one. It takes a lot longer than working with a PC, but adds surprisingly little to the experience.> Couple this with a good knowledge of digital signal processing technique, > and tag on the fact that the whole shebang demonstrates in spades your > ability to teach yourself, your motivation, the fact that you're a "self > starter".You sound like the evaluation board marketing department - "Use our evaluation board, and jump tall buildings with a single bound". :-\ Such a basic step as running simple (all you'll have time for) code on an embedded chip is not going to change your life.> Go for it. It will pay for itself.If you set your sights in life low enough, I guess maybe it does. If you set your sights higher, you might use the time to address some of the things Randy mentioned as important in an engineering career: "The engineer who can be adept simultaneously in engineering, math, business/economics acumen, hardware, software, theory, implementation, design, test, and integration is the real winner." Regards, Steve
Steve Underwood <steveu@dis.org> wrote in news:fq2b7e$gpv$1@nnews.pacific.net.hk:> I think that in the end I think the experience of using kits is a > pretty sterile one. It takes a lot longer than working with a PC, but > adds surprisingly little to the experience.My own experience is that you use a kit for a few days, and then if you're going to continue with a real circuit: layout, autorouter, and PCB. Believe it or not, layout and autorouter are free these days, and two-sided boards are about $30 each. For implementing DSP on a chip, though, the kits probably don't add that much value. You need an analog in and an analog out. It doesn't make that much of a difference if you need to wire in your own clock. If you want to have some real fun, get yourself a motor with a quad encoder, and write a position controller with analog input. Decode your quad, control the motor with an H-bridge and PWM, and write a PID. Output motor position on a DAC. Write yourself an RS232 port, and use it to put in control parameter from a terminal emulator. Light up an LED or two for giggles. Limit yourself to fixed point math. All this sounds more complicated than it is, especially with a good compiler. You would learn register-level programming (depending upon how much your compiler does for you, but nobody's forcing you to invoke the higher level functions!), A/D, D/A, driving high power analog circuits from a low current digital output, PID control, PWM (well, sort of), fixed point math, basic electronics, board layout, serial communications, quadrature decoding, board stuffing and soldering, maybe SMT soldering, speccing out parts, using the right connectors, embedded C, circuit troubleshooting, etc. This stuff is valuable, reachable, and practical-- and when you roll up your sleeves like this, hardly sterile. Each component is fairly modular. The toughest part would be the interrupt-driven handling of the quad inputs, so it won't be too long before you upgrade to a ucontroller that handles quad on its own. With a coupla hours here or there, and a few full-time weekends, I think this is a 3-4 month project, from the day you receive your kit and compiler. The last month or so would be learning to use the free layout and autorouter tools, packaging your output up nice for a board house, and waiting to receive the boards. Personally, I'd start with a microcontroller before going to a DSP, but you could just use a DSP without calling any the DSP stuff -- and its probably good to take on something not simple with fixed point math before you get too used to having and FPU around. By the time you're done, stepping up to a DSP will feel like untying your hands. -- Scott Reverse name to reply
