Hi, I come accross a patent found by Russell. The below is the link. http://www.freepatentsonline.com/6298363.html I try to find more information on the Adaptive windowing method but did got any luck. May I know does any one has any opinion or information about the Adapative Windowing method? Regards, BC
Adaptive windowing to improve FFT resolution and side lobes rejection
Started by ●February 26, 2008
Reply by ●February 26, 20082008-02-26
On Feb 26, 5:37�am, "boon chun" <boon-chun_...@agilent.com> wrote:> Hi, > � �I come accross a patent found by Russell. The below is the link.http://www.freepatentsonline.com/6298363.html > I try to find more information on the Adaptive windowing method but did > got any luck. May I know does any one has any opinion or information about > the Adapative Windowing method? > > Regards, > BCThe link and the site don't tell you very much. Go to www.uspto.gov and search on the patent number 6298363 to get the details. Dirk
On Feb 26, 2:37 am, "boon chun" <boon-chun_...@agilent.com> wrote:> Hi, > I come accross a patent found by Russell. The below is the link.http://www.freepatentsonline.com/6298363.html > I try to find more information on the Adaptive windowing method but did > got any luck. May I know does any one has any opinion or information about > the Adapative Windowing method? > > Regards, > BCYou might try searching on the spatially variant apodization (SVA) term used in your citation. There is literature on it. Another approach is to simply apply multiple windows and take the outputs from the windowed data having the least magnitude at each bin. You may or may not consider this 'adaptive'. It is computationally straightforward, has predictable processing cost, and the performance envelope can be calculated from the selected windows. Dale B. Dalrymple http://dbdimages.com
